What's the biggest flat screen television that could fit in a Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Ichiro, May 25, 2008.
  1. jetlaw
    jetlaw New Member
    West Palm Beach, FL
    The general rule of thumb among professional installers is that you need at least 5 times the vertical height of the screen between the screen and the seating position for standard-definition sources. Therefore, if room you have has a seating position 120" from the position where the TV will go, the max VERTICAL (not diagonal) screen size would be 24".
  2. Sezy
    Sezy Active Member
    440
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    60" Samsung flat screen, had to push my seat up. I'll look for the pic.
  3. a_gray_prius
    2,927
    783
    IL
    I think the sizes of the boxes that the flat screens come in have shrunk a lot since 08, so you can fit a bigger TV in these days.
