Which Of These Gas 87, 89, 91 Do You Guy Use?
Discussion in 'Gen 2 Prius Fuel Economy' started by 08Prius, May 30, 2008.
  1. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    Is this a trick question?
    Which one's cheaper?
  2. bac
    bac Active Member
    863
    52
    Pennsylvania
    Ding ding .... we have a winner!
    When autos had distributor caps, it was easy to simply tune it (advance the timing) to work better with a higher octane gas. With today's computer controlled autos, this is not an option.
    ... Brad
  3. icarus
    icarus Senior Member
    4,884
    976
    earth
    Read my thread about mileage increase with 83-85ROM gas in Montana.
    I get much better mileage using LOWER octane.
    Icarus
    PS. I assume that the knock sensor allows the lower octane without risk.
  4. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    How do you disable that reverse beep again?
    :peep:
