Number of computers in Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by Russ33, May 30, 2008.
  1. Russ33
    Russ33 Older Junior Member
    Long Neck, DE.
    Anyone know how many computers are in a Prius?
  2. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Someone will post the complete list again, but I believe it's 13 (14 if you have Navigation).
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I tell people about the 12-14 computers all the time, but feel uncomfortable doing so. In reality most of them are "microcontrollers". Yes they have microprocessors inside, but no, they don't run an operating system, don't boot up, don't have external memory or external storage, etc. Only one or two do so.
    Which is good. You never hear of a "Computer crash" in a Prius. ;)
  4. b11101100
    b11101100 Spectra Blue Mica Driver
    58
    Arizona
    Wow, only 14! I would have guessed many times more than that.
    For comparision, a 1999 BMW 7-series can have 65 microprocessors.
  5. racerbob
    racerbob Member
    138
    S Florida
    I believe my Auto Enginuity scanner recognizes 16 or 17 seperate "systems". A few controllers have more than one system in a chassis.
  6. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    When I went to the new-owner reception last summer, they told us the reason the battery could die after several weeks of not starting the car was that it was maintaining 16 different computers while the car was turned off.
  7. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Oh yeah, 11 milliamps for the whole shootin' match. To me, that's
    pretty dern good standby state on the part of all the ECUs...
    _H*
  8. racerbob
    racerbob Member
    138
    S Florida
    Absolutely, considering an average domestic vehicle hovers around 30mA after the anti-theft and body controller go to sleep.
  9. Solarman44
    Solarman44 Junior Member
    78
    Largo, FL
    I'm not sure how long a Prius can stand idle without being started before the battery dies. Last summer my wife and I went to Eastern Europe and our Prius sat in our garage for a month with no problems. Next week it'll be sitting in the garage for another month while we venture off to Italy. We never really thought of having any problems with the batteries after all everything is just sitting there in standby waiting for the power up.
  10. racerbob
    racerbob Member
    138
    S Florida
  11. Patrick Wong
    18,210
    6,514
    Hobbit has a base model Prius. Using his figure of 0.011A parasitic current draw: 24 hours/day x 30 days/month x 0.011A = 7.9 AH
    Since the base model Prius battery has a 28 AH capacity, it should be fine when parked for a month. However, a Smart Entry/Smart Start-equipped Prius will have a higher parasitic current drain if that feature is not turned off. I haven't gone to the trouble to measure that yet.
    Toyota's advice is to disconnect the 12V battery if the car is left stored for 10 days or more.
