How can the front wiper washer...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sheepdog, Jun 3, 2008.
  1. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    How can the front wiper washers not spray the windsheild if the back one works? The tank has fluid in it I checked. It used to work fine. Now nothing at all. drat.:(
  2. rfruth
    rfruth Member
    394
    Houston, Tx
    two pump motors (?) front 1 crapped out :confused:
  3. Sheepdog
    1,125
    Sanford FLorida
    maybe. It's warranty covered Im sure but it still stinks! I hate when stuff happens and thats why I always get new cars!
  4. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Are we talking about "Lil Rachel" here?
    ZC1
  5. Sheepdog
    1,125
    Sanford FLorida
    yes. The front washers quit working
  6. VenicePrius
    VenicePrius Junior Member
    Venice, CA
    Probably pump - could be the line got clogged OR all the nozzles got clogged, but doubtful.
  7. ZC1
    711
    Metro Detroit
    Did you have someone run the pump, both front and rear, while you had your head stuck inside the hood, near the washer fluid container. I can't see the pump, but I know it's nearby.
    Just wondering if it's attempting to pump the front wipers?
    ZC1
  8. Sheepdog
    1,125
    Sanford FLorida
    I ran it low on fluid. In fact I must have run it close to dry. When I refilled the tank the rears works fine but the front not. Hope is not pump. I imagine I can get it covered under warranty anyway when I take it in for its 5K service. I keep the car so clean I almost never use them anyway. *sigh*
  9. qbee42
    3,079
    You could have lost the prime on the front pump. Have you cycled it a bunch of times to make sure the fluid is up to the pump?
  10. sendconroymail
    sendconroymail One Mean SOB
    256
    I had this happen on my last car. I had gotten wax inside the holes where the fluid comes out. I never was able to get the wax out and just went without it. Maybe this happened to you? Needless to say I stay well clear of the nozzles when waxing the Prius.
  11. Sheepdog
    1,125
    Sanford FLorida
    Yes Tom I did. A bunch of times. nothin. I will look see if the hose got piched. It isnt dire as my service is either this week or next probably, but I hate to see anything go wrong you know.
  12. Sheepdog
    1,125
    Sanford FLorida
    Dont use wax. Zaino guy here. Clogs aint it from the polish anyway. I got it low on fluid so maybe gunk from bottom of tank?
  13. notch
    notch New Member
    Pomona
    just disconnect the hose pour some water in and blast with a small air compressor- other then that put some CLR in the washer tank
  14. Sheepdog
    1,125
    Sanford FLorida
    its a new car notch. Their is no calcium lime or rust in the tank! And that stuff may not be so nice to the car finish anyway but thanks for the thought.
