Next Gen relase date - April 2009
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by etyler88, Jun 4, 2008.
  1. Aviator_Guy
    Aviator_Guy Junior Member
    45
    Los Angeles
    This article claims the next generation of Toyota hybrid will get 40KM per 1 Liter of fuel??? That’s not an increase in fuel economy, that’s one giant leap for mankind!!
    Please check my math, but I think that comes to 94mpg!!??
    1 Liter = .2617 Gallons
    40KM = 24.85 Miles
    1 Gallon = 3.785 Liters
    3.785 Liters x 24.85 Miles per Liter = 94.057 MPG
    With a 11.9 gallon tank, that’s a range of over 1000 miles!! LOL, I could drive from Los Angeles to our second home in Arizona and back to LA on one tank of gas!! Either my math is incorrect or their MPG claims are too good to be true!! If the MPG is true, I will get one for sure!
  2. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    ^sounds good on paper...but how will it hold up on its first run???^
  3. bob2780
    bob2780 Junior Member
    HI Everyone,
    Sorry my Post needed to be clarified
    Don't Get excited over 80+ possible MPG for GenIII Maybe a 6-7mile EV Range
    According to the Link at the top of the post it stated for the Gen III Prius will have a 1.8 Liter engine and an improved economy 40km/L (96.5MPG) using the old Japanese 10-15 mode test cycle
    See link Emission Test Cycles: Japanese 10-15 Mode
    Explaining the test procedure
    Very generous to hybrids more so then the pre-2007 USA EPA of 60/51 Figure MPG for Gen II, as a comparison 35.5 km /L or (83.5)MPG Using Japanese 10-15 mode test cycle figure
    Using purposed Gen III economy 96.5- Gen II economy 83.5 =13mpg performance increase or 13.47% 13/96.5 =0.1347*100
    Extrapolating the 13.47% performance increase of GEN III using the established new 2007 Gen II USA EPA mpg figure 48/45MPG =6.46+48=54.46 MPG/6.06 +45=51.06 MPG City/Hwy
    Also here is a link explaining the new jc08 2015 Japanese standard containing info for Gen II specs
    Green Car Congress: Prius Certified to Japanese 2015 Fuel Economy Standards with JC08 Test Cycle
    This is just for fun
    Bob2780
  4. prius12306
    prius12306 2018 prime advanced - Stella
    116
    rotterdam ny
    2018 Prius Prime
    Thanks for clearing that up. It really bothers me that people see these numbers and then get disappointed when the car gets exactly what it realisticly should. Personally I'm just thrilled to be getting around 48 MPG with my 2008 prius vs the 32 MPG I was getting on the 2004 camry.
  5. Tideland Prius
    16,602
    What Bob said. It's under the Japanese 1-15 cycle. It's an increase from 35.5 to 40km/L.
    So that probably means the combined will go from 46 to 50ish mpg.
  6. Aviator_Guy
    45
    Los Angeles
    I haven’t seen much info on the 2010 Generation III Hybrid other than rumors. I’m sure Toyota will begin releasing info on their new 2010 Hybrid soon. The one rumor I like the most is being able to run on pure electric up to 50 mph for approximately 5 to 10 miles or so. If this is true, I will trade my FJ cruiser in for this new 2010 Hybrid and keep my Prius as a second car. I think it would be way cool to charge up a Hybrid using home generated wind / solar and then drive down to the mall and back using absolutely no fossil fuel, totally off the Grid!!! That would be Awesome!! :cool::cool:
  7. daniel
    14,487
    1,519
    Spokane, WA
    Normally, getting on a list involves giving a refundable $500 deposit in return for a promise that you'll have a specific place in the selling order. If you change your mind before the car comes in, you get your deposit back.
    However, you need to verify this with the dealer, because any dealer can operate his waiting list any way he likes. The above is normal. It is not universal. Some dealers give you a written promise, which is effectively a contract. Some don't. Some respect their own list, others don't.
    This is true of many auto makers and all American auto makers. Toyota, however, is a cut above on quality. I bought my 2004 Prius in January of 2004 (having ordered it two months earlier) and I've had no serious problems with it. There were a couple of minor issues, but I have no regrets, considering that waiting a year would have meant a year of not driving a Prius.
    Salespeople are the single most unreliable sources of information on the planet!!!
  8. CAPTAIN_JAMES
    CAPTAIN_JAMES New Member
    Atlanta, Ga
    ROTFL :peep:
  9. stevecaz
    stevecaz New Member
    77
    Massachusetts
  10. KandyRedCoi
    860
    SoCal/AZ/NV
    yea those big 18" wheels will not make production LOL im pretty sure of that haha
  11. prius12306
    116
    rotterdam ny
    2018 Prius Prime
    Wow - you drive a ZAP! that is so cool - where do you drive it? I have looked into it for a second car for my spouse, but I didn't think it would work where we live. The roads here are a total mix of speed limits - and one section is 45 max and all drive 60.
  12. prius12306
    116
    rotterdam ny
    2018 Prius Prime
    OOPS - that response was meant for daniel.
  13. stevecaz
    stevecaz New Member
    77
    Massachusetts
    No matter how big the rims, the outer wheel size is always the same anyway. The only reason it normally wouldn't/couldn't support large rims is weight. So if Toyota makes a lightweight (and strong) rim that has the same total weight with tire and the 15", then there is no issue.
  14. drees
    drees Senior Member
    1,782
    247
    You forget inertia. With a bigger wheel/tire, even if the overall weight and diameter is the same as a smaller wheel/tire, the bigger wheel/tire will be harder to accelerate and decelerate because more of the mass is located further away from the center of the wheel.
    To get the same acceleration/braking performance with a larger wheel/tire combo as the smaller wheel/tire combo, you would need a wheel/tire combo that is lighter than the one you are replacing.
  15. KandyRedCoi
    860
    SoCal/AZ/NV
    ^correct, i didnt want to make this thread an engineering discussion thread...so i left it that, ive modified enough cars in my past, but i agree 100%
  16. destro23
    destro23 New Member
    Jersey
    just got an email reply from a local Toyota dealer that said
    "Any orders palced now may end up being a 2009, which has a larger engine and price increase" 12-16 weeks
  17. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    Hmmmmm ... wonder if I could get my dealer to hold off a few months for the larger engine ... thought for sure that rumor was false ... still not sure I'm buying it.
  18. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    ERROR..ERROR..ERROR. Check around here more and find the real truth.
