Is there anyway to Turn off the Screen Beep?
Discussion in 'Gen 2 Prius Main Forum' started by TimeFor, Oct 26, 2004.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Hi Berkley.
    Are you sure you and I are reading the same thread?
    It's not that we got bored with the idea in the last 3.5 years. It's that it's just . . . not . . . possible.
    Ask again in 2011.
  2. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    So there's no turn beep on/off button in the 2005 like there is in the 2008? That sux :smash:
    One solution: Trade in for the 2008, but that may be an expensive fix. :)
  3. TonyPSchaefer
    14,816
    2,501
    66
    Someone will correct me if I'm wrong but I believe the [on/off] button was introduced in 2006 when Toyota added a few other things like the side badging, hi-def MFD and the slightly-different taillights. And yeah, we '04/'05 drivers are still sucking it up with our beeping, lo-def MFD.
    (No offense to the true early adapters still driving the Gen Is.)
  4. jjksutton
    jjksutton New Member
    97
    Tampa
    The beep on my 04 stopped...unfortunately that was a result of the MFD dying.
  5. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    With the aftermarket sound system, I haven't heard the beep in 3 years.
  6. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Well, somebody's got to do it.
    :D
    ZC1
  7. priusuk2008
    priusuk2008 New Member
    289
    CAMBRIDGESHIRE
    I fancy one that an earlier poster said about Darth Vader, but wasn't it ... "By your Command "...in a voice talking in a tin can , now that would be really cool and I'd change the screen all the time to listen to that. :p
  8. BDDave
    BDDave New Member
    76
    Iowa
    On my 2008 MFD, under screen setting there is an option that says "beep off". Push it and there isn't any more beep. I don't like being "beepless in Iowa" so I turned it on again. It probably tells you this in the owners manual too.
  9. kenkneeb
    kenkneeb Member
    120
    So. Central, Pacific SouthWest Oregon
    Only by disconnecting the factory JBL amp under the passenger's seat. That's where the 3.02Khz beep originates from and goes out thru the rest of the audio system.
    I had a new stereo installed, disconnected the factory amp and haven't heard a freakin' beep in 3 years now.
    ah, the freedom from beepdom.
    Good luck.
    Ken
