Broke my undercarriage plastic thing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by footprintx, Jun 8, 2008.
  1. footprintx
    footprintx New Member
    Riverside, CA
    I broke that plastic piece that runs along the front part of the undercarriage of the car, and now it hangs a little down and catches on speed bumps and such. I took it in to my local Toyota Dealer and the dealer said a new plastic piece would cost $345, but he could jerry rig it for $40 and if it didn't work he'd apply that $40 to the cost of the re-do.
    Well, it didn't work, this was a few days ago and as soon as I hit 75 on the freeway, it came down and started dragging.
    Any ideas on what I should do? Is that piece even necessary or will not having it significantly decrease my mpg? Do you think they'd have one on the local pick-a-part? Could I just bolt on a large piece of graphite to the plastic that's still stable down there? It's up near the front and the holes where the clips attach are busted except for one of them.
  2. Neicy
    Neicy Member
    834
    Wakefield, MA.
    You mean like this, only worse? I got some fender washers but haven't gotten under it to see if it works yet. I think I will duct tape mine before I would put out $345.00 to get it replaced.
  3. footprintx
    Riverside, CA
    Yes, exactly! Only ... worse. It used to look like that. Look out, once it starts hanging like that it starts getting caught on everything: speed-bumps, steep-driveways. Should I just duct-tape it?
  4. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    Did you take it to a Toyota dealer or a different type dealer? I would try and shop around. $345 seems much for that. A local dealer might be able to drill holes and fix it flush to the rest of the undercarriage. Good luck and let us know if you get it fixed.
  5. Scott_R
    Scott_R Member
    437
    Long Island
    2024 Prius Prime
    When I did something similar to my car, I used some epoxy (the two-part putty stuff) to fix it.
    I removed the bolt, kneaded up some putty, and smoothed it over the area, overlapping it over the existing plastic on the top and bottom and smoothing it relatively flat. I pushed the screw through a bit, just enough to make a modest hole. When it dried, I reattached it. Worked perfectly.
  6. GatorJZ
    GatorJZ Member
    285
    17
    Just to make it easier for you, it is called a "splash guard".
    Pris likes this.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    PriusChat Shop, get the alloy undertray. It will cost a little more but is much tougher for next time.
  8. footprintx
    Riverside, CA
    @patsparks: couldn't seem to find that on PriusChat Shop, by search or browsing. :(
  9. GatorJZ
    GatorJZ Member
    285
    17
    Search for BT Tech Skid Plate.
  10. Syclone
    Syclone Member
    540
    I just had mine replaced. It was 61.00 plus labor ( dealer did it free because one of the mechanics had screwed up a service item). Find another dealer!!
  11. Neicy
    Neicy Member
    834
    Wakefield, MA.
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I also suggest the skid plate...it doesn't hang down like the plastic one and it adds the benefit of added protection to the underside....and is cheaper than the plastic replacement to boot.
    kidfried likes this.
  13. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    If you have all the pieces, there is an inexpensive but extremely durable solution in two words:
    JB Weld
    It's not only for metal but plastic too. Find it in your autoparts store.
    ZC1
  14. footprintx
    Riverside, CA
    so ... i have it taped now, and am seriously leaning towards that skid plate, more from a lack of options than anything else. I've read the two reviews about the skid plate, efusco and fboyle2000s.
    i talked to the guy at the Toyota Dealership, and he said he'd install it for me, since his jerry-rig didn't work.
    Has anybody else bought this thing? What do they think? Efusco, once you got more clearance, did that help with the noise (ie: was it the plate reflecting the road noise, or was it the part of yours that was rubbing up against the plate?) is there anything i should tell them to save them some time / incorrect installation?
    thanks for all y'alls advice.
  15. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    $345?! Holy crap. Twist a short sheet-metal screw into it and call it done. Duct tape will work, but only until the first rain.
    Screaming Red likes this.
  16. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Forget the duct tape. Try Gorilla Tape -- Home Depot has it. Black, opaque,
    very high tack, lots of fibers.
    Just as good as the "300 MPH" mil spec duct tape that a Marine buddy
    "liberated" and gave me some while back.
  17. Allanwboston
    Allanwboston Junior Member
    Wakefield, Ma
    CF Advance For 04-09 Toyota Prius Rear Exterior Tailgate Liftgate Handle Garnish Non Painted Black NPB 2004 2005 2006 2007 2008 2009
    ALSO AVAILABLE PAINT FINISHED TO MATCH VEHICLE
    AMAZON
  18. eljefino
    eljefino Junior Member
    43
    25
    Maine
    Drill some holes and run zip ties through. You're never going to make $300 back in gas doing this correctly.
