Possible to carry 4x8 sheet of plywood on roof rack?
Discussion in 'Gen 2 Prius Main Forum' started by zuehls, Jun 10, 2008.
  1. zuehls
    zuehls New Member
    Does anyone have experience carrying sheet goods on a Prius roof rack?
  2. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Not on a prius, but I have on other cars. I wouldn't recommend it. Unless you are planning to drive only slightly faster than walking speed, you will find that the plywood tends to act like a giant sail and is just as likely to rip the roof rack off your car.
  3. fcc
    fcc New Member
    245
    Nashua NH
    i agree with that. Can you cut the wood to smaller units? that would help
    a lot.
    otherwise in situations like that i have rented a home depot truck for an hour
    or i borrowed a friends truck for an hour. I would also be worried about damage
    to the vehicle if it was new or newer.
    i am sure we all have seen people on the side of the road adjusting their
    loads, retying it down, or picking it off the road due to the reason listed above.
    better to spend 30 dollars to rent then to pull your hair out when you damage
    the wood due to an accident.
  4. bwilson4web
    16,348
    In this case the distance was 1/2 mile through parking lots and neighborhood streets. I now use a light weight trailer to transport plywood ... much, much safer and faster.
  5. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    No problem, I do it all the time.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Prius is for driving, trucks are for deliveries. Not those toy truck wankers drive but real truck blokes get paid to drive.
    Why risk damage to a $20,000+ Prius to save a few bucks on a delivery?
    I want you to practise this phrase,
    "Can you deliver that to <insert address here> please?"
    It can save a lot of heartache.
    Toyota don't even recommend fitting roof racks to Prius.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    NO NO NO,
    Of course thats why my 4Runner is still sitting in the back yard with a Solar Battery charger on it!!!! It only makes runs to Home Depot etc!!!
    YOU CAN NOT HAUL A PIECE OF PLYWOOD ON A PRIUS.
    Well unless you have a death wish!!!
    Or you could have the store cut it up in 2 ft. X 4 FT. pieces, then yes it will fit!!!
    Pat KK6PD
  8. tochatihu
    tochatihu Senior Member
    9,850
    3,809
    Kunming Yunnan China
    2001 Prius
    Well, you can of course, it is simply necessary to tie down in such a way that the rack is dissuaded from sailing away.
    For a particular project, I was constrained to only use plywood of I guess about 7 mm thickness because that was the heaviest I could lift into position by myself.
    The minimalist roof rack is two truck-tire tubes, fore and aft. They deflate for storage and have a secondary recreational purpose at the lake.
    However, the advantages of other means of hauling have been presented above. Suit yourself.
    What 'gets' me is people tailgating behind me when I have a roof load. I mean, I know my tiedowns are fine, but they don't know it, and in some sense are risking their lives.
  9. Nords
    Nords Member
    101
    Oahu
    Even our surfboards move around a good bit with a HandiRack. It's not the sail area as much as it's the crosswinds & gusts...
  10. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    Love it! Thanks for sharing! It bightened my day!
  11. Blue
    Blue New Member
    46
    Alexandria, VA
    Just FYI....if you rip the 4x8' sheets (i.e. two 2x8' sheets), they will fit in the Prius. You will have to lower the back seat, as well as the front passenger seat (which can be done after removing the headrest). Lowes/Home Depot usually charge about $.50 per rip.
