prius scratches + magnetic grey + toyota touchup paint question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fcc, Jun 12, 2008.
  1. fcc
    fcc New Member
    245
    Nashua NH
    Hi all,
    I found my first small scratch on the left hand side bumper. It is a light
    scratch that shows the white colored primer below it. I have an idea who
    did it but i suppose that is irrelevant at this point in time :mad:
    I might as well pick up some magnetic gray touch up paint from toyota and
    practice underneath the hood or what not but does anyone have any experience
    with the product or any other product?
    Yea, it is not that bad and most people will not notice it but if I can become
    proficient at concealing this effectively I might as well learn!
    So many products on the market it is confusing and I would rather trust
    toyota to get an exact match of the color but one never knows if this
    forum has good experience on the topic.
    I did a search of a few pages of older posts but nothing definitive popped up due to my vague search term of "scratch".
    Any advice, comments, or thoughts would be very appreciated!
    thank you.
  2. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    You can get a vial of Toyota touch up paint for less than $10. Make sure you give them the correct paint code for your Mag Grey.
    I've touched up mine in several places. I've also painted over my hybrid badges on the side and the Toyota emblems with it. :)
  3. fcc
    fcc New Member
    245
    Nashua NH
    I gave them a call and I they told me the paint will cost 6 bucks with my
    10% discount included in. So that is cool.
    I had some time to examine the scratches and they are very fine line
    scratches that are not terribly long just terribly annoying when you know
    your car so well and was basically watching just for this type of incident.
    I do understand every car over time will get scratches but darn it, i will
    try my best to not get them or cover them up.
    Any good techniques to putting the paint on? Getting a better paint brush?
    Diluting the paint to make it easier to apply? Any sort of tip like that would
    be appreciated!
    thanks
  4. zenMachine
    3,355
    300
    There are two tips, a pen tip and a small brush tip. Use whichever one makes most sense in your case. The paint itself is thick and dries quickly. Do not dilute it though.
  5. fcc
    fcc New Member
    245
    Nashua NH
    interesting. i would have never thought of a pen tip. it makes me think applying it
    with a needle for example could result in filling the scratch lines very effectively if
    you move slowly along the scratch doing a 1/4 inch at a time. after all you do not
    want a big glob of paint on the tip. you just want to cover the primer/scratch areas.
    thanks!
  6. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    GS27 or something similar if the scratch is minor.
  7. fcc
    fcc New Member
    245
    Nashua NH
    i think the problem with the prius and dark colors is that the primer is
    white underneath. that product would handle scratches in the paint
    that do not make it to the metal nor the primer. sorta of like swirls from
    washing the car wrong.. that would handle.
    i can actually see the white primer underneath due to the angle of the
    scratch and I looking down. i simply need something to cover the white
    and it will be almost unnoticeable.
    thanks for the tip though and i am assuming i read the product website
    correctly!
    GS27 Scratch Remover can get rid of most surface scratches quickly, easily, and without those expensive repair bills.
  8. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    I've used the Toyota touch up paint and it's darker. Scratches now look like dark squiggly lines on my car. I'm ok with it, but some people may not be happy with it.
  9. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    The color code for Magnetic Gray is 1G3.
    I have used touch-up paint on my Magnetic Gray Prius, but it's difficult for me to do a smooth, seamless touch-up. It's hard to control touch-up paint -- the paint pen is runny, and the brush on paint (like nail polish) is goopy. When I use touch-up paint I try to smooth out the paint with scratch remover or wax.
    I actually prefer to use a Sharpie or a PrismaColor artist marker because you can be very precise with them -- near pin point precision. Sometimes I use an ordinary black Sharpie. Other times I use a PrismaColor artist marker in one of the many shades of gray that they come in (I think artist markers typically come in 20 or 30 shades of gray).
  10. Patrick Wong
    18,200
    6,500
    Before you start painting over the scratch, may I suggest that you visit your discount auto parts store and look for swirl remover or a light rubbing compound. Perhaps all that has happened is that the clear coat is scratched and appears white. If polished, the scratches may go away.
  11. fcc
    fcc New Member
    245
    Nashua NH
    very good idea! i will consider that. i bought the toyota paint though in the
    exact color by going by the code. I will of course verify right on the inside
    door frame again before using.. but i will practice first and if i do not like the
    results in a hidden area i will consider this idea. thank you.
  12. fcc
    fcc New Member
    245
    Nashua NH
    what color prius and what color touch up paint? i am assuming you have the
    exact match and shook the tube of paint for a few minutes? i do not like what
    you are referring too :(
  13. fcc
    fcc New Member
    245
    Nashua NH
    i misread your post at first and now it makes perfect sense now that i own
    a tube of the toyota paint. indeed it does have two tips. a brush and a pen.
    thank you!
  14. fcc
    fcc New Member
    245
    Nashua NH
    I also thought of that and it was my very first reaction to it. But after feeling
    the scratch and seeing how it raised the paint in the scratch areas on the sides and using a wet paper towel to rub an area... it is indeed a scratch
    that has moved the paint showing the primer underneath. I am just thankful
    it is minor.
  15. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    For small scratches I usually use a toothpick instead of the brush or even the pen tip which applies too much paint. Just put a very little paint on the toothpick place it on the ding or scrath and let the paint flow into it, sometimes a second coat is needed if it is a deep scratch.
  16. fcc
    fcc New Member
    245
    Nashua NH
    this is absolutely correct in my opinion. the paint is a bit darker. i only used it sparingly
    in one or two areas on the bumper to see how it looks.
    of course i washed the car first and used the ?maguires? 1st step product to clean
    the paint. after applying it sparingly to the worst area i then used the other two steps
    in the product line. i forgot how much work it was to do those 3 step products with
    a wash! geez louise.
    too bad it got dark as i was wiping off the last of the dried wax.. and i will report back
    tomorrow how it looks in the daytime.
    can i see the darker toyota paint touch up stuff after a solid shine/waxing on top and
    would i use it again! wait for the report! ;)
  17. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I don't have the talent/patience to touch up tiny scratches but have worked on a couple bigger ones. At some light angles the touch-up is invisible while at others it is very visible. Put a clear bra on before any more damge occurs.
  18. fcc
    fcc New Member
    245
    Nashua NH
    you know i have thought about that but for example while waxing the car
    i noticed a minor scratch by the back wheel well area on the driver's side.
    of course the clear bra would not have protected that from happening and
    i think that minor scratch occured at the same time the front bumper ones
    did. i have a feeling a yet to be named person living in this household was
    taking out the trash or carrying something at knee level... and was very
    careless. living in the city always has tight spaces parking wise and i suppose
    it was bound to happen when people around the car just do not care as much
    as i do.
    for 500-600 dollars it might be wise to do it but i have a feeling this was just
    something i had to get past. my baby got its first wound and from now on
    i just have to realize cars do not stay perfect when you drive 15000-20000
    miles a year. that money could be used to pay it off that much quicker.
    i really do not want to keep throwing money at a car that during the NH winter
    will really see some tough times.. clear bra or not.. on all parts of the body.
    i will have to simply think about it.
  19. clayfree
    clayfree Junior Member
    69
    Frisco, Texas
    I second the scratch remover option. I had a black Mazda with what looked like scratches down to the primer. I watched in amazement as the body shop buffed them out. Many times you are seeing the reflection of a ruptured surface causing it to look like primer. Give the scratch remover a try and if that doesn't work then use the touch up paint.
  20. GatorJZ
    GatorJZ Member
    285
    17
    Don't forget to put clear over the color coat.
