SCC1 + TOY-SC1 display issue
Discussion in 'Gen 2 Prius Audio and Electronics' started by sincitymedic, Jun 11, 2008.
  1. Rest
    Rest Active Member
    1,210
    53
    CA
    Didn't you read the post above yours?
  2. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    No, you don't need all three. You need either SCC1 (which is a Sirius tuner with its own serial number) or SCVDOC1 plus your own compatible receiver. You need the TOY-SC1 adapter to connect either to the Toyota's stereo system.
  3. Hryb
    Hryb electic
    81
    NW
    I have had these units connected in my car for about 10-days. No problems at all with the display. I am set to scrolling though. I'll call a friend of mine who works at Sirius and ask him if he's heard of this issue.
  4. srickard
    srickard New Member
    Sachse, TX
    I believe this is a problem in the radio, not the Sirius stuff. I have seen a similar problem on the audio display for FM. Recently I took a trip several hundred miles away from home. One of my presets matched the frequency of a different station. The station info was updated on the display. When I returned home the station info did not change back until I reset the preset. :rolleyes:
