power wheelchair woes
Discussion in 'Gen 2 Prius Main Forum' started by metal_chair, Jun 17, 2008.
  1. metal_chair
    metal_chair Nashville Prii Unite!
    65
    Nashville
    My wife and I have just bought a 08 Barcelona red pkg.5 and are loving it
    except for one thing I'm disabled and in a wheelchair and often need to use my new $17,000 power wheelchair. So we end up taking the 9 mpg beast
    w no A/C everywhere and leaving the the new baby at home...:( .
    I figured
    that taking the chair would lower my mpg's some but had no idea that I would not ever be able to take it with us. The salesman told us that Toyota has a mobility program that reimburses new car buyers for lifts and carriers so this would not be a problem.
    But now i am finding out that Toyota does not recommend hauling a chair and will not reimburse for this and will probably void my warranty.
    So what do I do sell my Prius?.......hah Nooooo
    Sell my new 300lb power chair I fought the
    Insurance co. tooth and nail for?...............I dont think so
    continue to drive the Opec approved gas beast wheelchair hauler....?
    Please help
  2. tochatihu
    tochatihu Senior Member
    9,828
    3,796
    Kunming Yunnan China
    2001 Prius
    Hi metal, are you considering a rear tow bar that can lift the chair? Offhand that seem like a lot of tongue load, but maybe it has been done successfully with Prius.
    Suggest you study this warranty cancellation issue more before concluding what the Prius can't do.
    If you post more info aboiut the device you use to carry the chair now, maybe we can be of some help. I hope so, anyway.
  3. metal_chair
    65
    Nashville
    here is a pic of the lift I use on my other car (gas beast) Harmar_Extra_Large_Fusion_Lift_(Outside_lg.jpg it wieghs around 100lbs and chair wieghs around 280lbs so I think
    im out of luck but I wonder if a platform LT100_new_lg.jpg that has supported by a swivel type
    wheel underneath would work?
  4. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    I'd be reluctant to load that much weight on a Prius-mounted trailer hitch. I got a class I hitch and was not even comfortable with the amount of metal flex that we got with a 4-bike rack.
    If it were up to me, I'd disobey the manual where it says no towing and do with the motorcycle/ATV people do -- get the tiniest tilt trailer available. I've been shopping small utility trailers and there are a lot of options out there. But I have no idea how that would or would not work for your situation, in terms of getting the chair onto and off of the trailer, because the tilt trailers are essentially ramps. Some of the hitch-mount wheelchair carriers I see on line have ramps, most have a lift.
    I know nothing about this industry (though I have studied the wheelchair manufacture industry). I'll just note in passing that there appear to be several options for trailers specifically made for, well, scooters at least, but presumably power chairs as well. Looks to me like it would be a challenge to get the chair onto the trailer, but ... it's an option. As with all things medical, a regular tilt trailer this size is a few hundred dollars, but a "medical" tilt trailer will set you back $1600.
    Wheelchair & Scooter Trailers at Discount-Trailers.Com
    Wheelchair and Scooter Trailers
    Ah, nuts, this guy says it can beat up your chair. Sounds right, given the crude suspensions on most trailers. Hadn't thought of that -- on most trailers you'll be talking about a pretty rough ride. So you'd have to avoid cheap trailers, at least.
    Aha, here's one with all the options -- has a gas shock lift build into the trailer, so no ramps. Presumably, at that price, you'd hope they put a decent suspension on it as well.
    Scoota Trailer – Scooter Trailer, Wheelchair Trailer
    So, I know jack about this. All I know is that with hitch install, even a modest loading got us a lot of metal flex, and I'd be really reluctant to load much weight on it. But with a loaded trailer you'd be talking about a tongue weight of maybe 50 lbs (200 lb trailer plus 300 lb chair / 10), which isn't going to do anything to the Prius suspension. Beyond that, the only issue is the additional drag from two more wheels plus aerodynamics. I can't really see where, if you drove within reason, that would overload the vehicle. In fact, I'm sure several posters here actually use trailers with their Prii, including at least darelldd.
  5. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    And I bet that would still come under the rules for Toyota Mobility assistance also, bringing down the cost considerably.
  6. husky74
    husky74 New Member
    st. louis
    I am in a similar situation. My wife uses a power chair too, and I've been working on a system to haul her chair in the trunk (sounds impossible...I know). But what I'm doing is designing a quick release system for the seat so i can drive the base into the trunk using a small ramp. There is 26" of height available if the back seat is folded down, so with her chair (invacare tdx series) there is plenty of room, and no modifications to the car, and it's within the payload limits.
    We are definitely trading conveinence for economy in this setup vs. a van, but she travels a lot for work (attorney) so it's worth it for us.
    if you're interested I can send you pictures when I have it finished (just ordered the prius 2 weeks ago, so it's going to be a while)
  7. metal_chair
    65
    Nashville
    I have a permobil and it does not come apart very easily but I would like to share pics when you get them and ill post any thing I get to work as well.
    thanks.
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I would be interested to see if anyone can find a solution to this. my uncle is a quadriplegic so he can't really ever be separated from his chair. He currently gets toted around in a Ford Van with air ride suspension that gets roughly 16mpg
    I know that the sienna gets better gas mileage and Toyota uses them to haul around people and parts.. so i assume it's safe for a heavy wheelchair. It's not an MPG champ like the prius.. but it is better than what you're currently riding in... then again.. a dropped floor, lifts and a wheelchair drop MPG's like a lead balloon.
  9. husky74
    husky74 New Member
    st. louis
    The perfect solution would be a hybrid mini-van, but until then, it looks like sacrifice is the order of the day. We use a Chrysler town and country now and it gets about 25 mpg, but sadly that's not really good enough anymore.
  10. tochatihu
    9,828
    3,796
    2001 Prius
    Indeed there are Prius towing small trailers, with descriptions posted here at PriusChat. There is also a small Yahoo! group called priustrailers. I hadn't thought to suggest that someone there might have experience with powered chairs.
  11. johnphillips
    johnphillips New Member
    Jacksonville, FL
    i'm thinkg about ordering an auto lift from these guys. says alot of them are self installable...anybody out there ever done a self install? if so howd it go?
  12. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I read somewhere that tongue weight is about 10% of total trailer load. So Prius should be able to handle 500-1000lb load without any problem. As long as there is a helper to load and unload the wheelchair. Of course, you could ride in the trailer..
  13. chaslee
    chaslee Junior Member
    Glen Burnie, MD
    Here is something I did when my mom visited us.
    (I can't insert links yet so go to YouTube and search on "Scooter Ramp & Insert".)
    You might be able to do something like this for your Prius although the Prius might sit higher than the Odyssey so you might have to add a couple of boards at the bottom of the ramps so the chair won't "high center" on the dip. You may also have to take the chair off the scooter if it is too high for the Prius.
  14. qbee42
    3,079
    [ame=http://www.youtube.com/watch?v=L4kE-aYTO-c]YouTube - Scooter Ramp & Insert[/ame]
  15. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Wheelchair accesible vehicles are usually vans because they have the headspace. I imagine the person might hurt their neck trying to roll into the Prius. There are only a few cars with enough headspace that I've seen the wheelchair ramp, such as a PT Cruiser.
  16. donalmilligan089
    239
    22
    virginia usa
    cured that problem. My wife had a wheel chair (278 lbs), though I had to remove the seat in order to close the hatch. I attached an electric lift (used $250.00)that works on 12 volt battery. It is an inside/outside lift and though the Prius floor board would not accommadate the bolt down I installed a Curt hitch (U Haul) $161.00 and adapted the lift out side on hitch. Works great though wheelchair has since quit working. If need pics I'll get granddaughter to take them and email, [email protected] Weight is under factory suggestion
  17. donalmilligan089
    239
    22
    virginia usa
    See reply to Metal chair above. Email me and I can walk you through the process. Must have some welding knowledge. [email protected]
