Hypothetical Battery Upgrade
Discussion in 'Gen 2 Prius Technical Discussion' started by dwreed3rd, Jun 17, 2008.
  1. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    Look! I realize that there are probably a dozen reasons that this would be impractical and/or unsafe. I did a search to avoid being redundant, but did not find anything on the subject.
    So just for the fun of brainstorming, if anyone would like to join in;
    I know that in battery powered electronic systems, if you need longevity, you add more batteries in parallel. I was just musing on the idea of adding a second high voltage battery, in parallel with the original. Please, I am not thnking of actually doing it, just a what-if exercise. The voltage would be the same and since amperage is a function of resistance, the increase in potential amperage should not create a current problem. If you attach it at the original battery's terminals, the hybrid system ECU may not even recognize that it's there if the Pos. & Neg terminals are he only connecions to the battery. Assuming that were the case. It may be able to store a little more of your breaking energy in stop and go traffic in hot climates that use the A/C alot, or braking downhill in hilly terrain. Or Also it would give you that extra couple of miles on the battery around home, short local trips @ <35mph. It's just a crazy idea, and even if it would work, I doubt the it would be economically justifiable. Just wanted to have some fun speculating.
    I've been enjoying reading the posts while waiting to move down on "The List". Touring, Seaside Pearl, (Leather w/Pkg#3 prefered, Don't need $800 GPS) or Pkg#6 to get POL/POE Leather., willing to wait for what we want. Good questions, good answers, good news, good suggestions. good information, good monitor and most important good members. I've been in alot of chats/forums etc over the years and PriusChat is one of the best I've ever joined. I look forward to sharing our(my wife and my) Prius experiences, hopefully mostly good.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Hi Dave, you should be realizing by now that the Prius is pretty complex and highly instrumented. If it were just a big battery, slugging in another would be a piece of cake and easy. But the battery has its own ECU that monitors it and communicates with the hybrid system ECU about its state of charge. The hybrid ECU knows the Prius has one battery. If you put in another and nothing else, it might get very confused if one battery said I'm hungry and the other battery said I'm stuffed. Part of the value of a PHEV kit is that the manufacturer has figured out how to fool the hybrid ECU.
    While every thing can be improved, Toyota spent a lot of research time coming up with the balance of efficiency, power, safety, and cost that they sell as the Prius.
    I agree with you about PriusChat and most of its members.
  3. dwreed3rd
    742
    Marietta, Ga
    Bill; Thanks for the reply! I was afraid of something like that. And like I said, I have absolutely no intention of doing anything like that myself. It's just a mental exercise. I was thinking that the High Voltage Battery Pack itself might be a series of cells that was connected together forming a battery or batteries, several sets of cells in series providing the 201 volts, connected in parallel to provide the amperage and connected to the rest of the sysyem with a positive and a negitive connection/cable to the Power Control System (Inverter). But if they're monitoring individual cells or batteries within the battery pack itself that would make it more challenging. I did not realize there was an ECU withing the battery pack itself. I thought the Power Contol ECU was in with the inverter in the front engine compartment. Toyota could have chosen to use a larger battery pack or make it an option, like the optional larger battery packs for camcorders, etc. I'm sure that they made an intelligent decision balancing power, storage capacity, weight, space, cost and cooling requirments. I just thought that if Dr. O'Brien could drill holes in it, what would happen if you could attach a second battery pack to it.
  4. icarus
    icarus Senior Member
    4,884
    976
    earth
    From Bill Merchant: " If you put in another and nothing else, it might get very confused if one battery said I'm hungry and the other battery said I'm stuffed."
    That really wouldn't be the problem. 2 large battery banks of equal capacity age etc, wired in parallel would act as one large battery. I agree that the problem would be with the ecu however. For example if the ecu directs the battery to discharge only until it has put out X number of amp/hours, and to stop charging only when it has put x number back in, the additional bank might not do anything except add dead weight. If you could reprogram the ecu to realize that the bank was twice as large, it could therefore double the amp/hours allowed for discharge etc.
    Icarus
  5. bwilson4web
    16,123
    I've had occasion to deal with a dozen, NHW11 battery modules as part of my battery refurbishment experiments. IMHO, if the electrolyte is not part of one pool, it takes only a few cycles before one battery is weaker than the other and the problem appears to get worse. Over time the individual NiMH properties appear to diverge and this may put a natural limit on how big NiMH cells can be.
    I have not done much work with lead-acid batteries and since they have a larger dV/dQ (where Q is their charge capacity,) they may work better in parallel. But the nearly flat charge/discharge curves of these NiMH batteries is maddening and makes simple circuit connections a thing of horror and wonder.
    I don't want to put anyone off from their own experiments but I'm trying to suggest go cautiously with a lot of 'backup'. Experimentation is good but these NiMH batteries are something else. My admiration for the Toyota engineers grows higher every day I deal with these modules.
    You might consider reading up some of the RC hobbyist work. I've found they have a lot of insights about operating NiMH and other battery chemistries ... just before their models crash.
    ps. If you have an interest in NiMH module experimentation, send me a PM and we can work out a deal. I have plenty from a replaced traction battery and if someone has a proposal for some experiment lacking only modules, let me know. It is better to have more than one expert in this area.
  6. icarus
    4,884
    976
    earth
    I know less than nothing about NiMh battery chemesty, life etc.
    From the solar world, I know enough about flooded lead acid batteries to be dangerous. The cardinal rule about lead acid is that all the batteries in the bank need to be the same size as well as the same age. If you put a bigger battery in the bank, you will effectively give the bank the capacity of the smallest in the bank for example. If you put a new battery into an older bank, the new one will rapidly become the effective age of the older ones.
    It seems that the Prius battery is nothing but a series/parallel array of individual cells. As such, in my uninformed mind, if all the cells are the same age and size, then the only difference would be that the total amp/hour capacity of the total would be bigger.
    Icarus
    PS. I too am not advocating hacking the car for novices. People who want to play, push the envelope, go for it!
  7. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Its actually been done. The short answer is its pretty complicated and it doesn't improve mileage by any appreciable amount.
    The common perception is that more battery = better efficiency. After all, thats what makes a hybrid better than a regular car. The reality is that the people who get the best efficiency out of their Prius do it by driving their car using as little battery power as possible. It seems that if you can accelerate the car with the ICE at its peak thermodynamic efficiency while transferring no power into or out of the battery, and then glide with minimal drag and no power going into or out of the battery you achieve the best possible mileage under normal circumstances. The short explanation for this is that while the hybrid system does greatly improve the efficiency of the ICE when its driven in what would normally be very inefficient modes, the inherent conversion losses of mechanical to electrical to chemical energy and back can never do better than the peak efficiency of the ICE since all of the energy must eventually come from the ICE. So for the everyday driver, the hybrid system makes the Prius more efficient than a regular car. For the hypermiler, using the hybrid system as little as possible is key to optimal results under most conditions. Even for the everyday driver the size of the current battery is more than enough to capture and release all the energy encountered under normal driving circumstances. As an example, the DOE ran a Gen1 Prius to 160k miles and then ran tests on it. They found that the battery capacity was down 50%, but they had seen no corresponding drop in mileage.
    Extra batttery capacity doesn't really come in to play until you add a means to charge the battery from some other source than the ICE. This is the idea behind the PHEV conversions. Now you are offsetting gasoline burned by the ICE, with electricity from the grid and the bigger your battery the more you can offset.
    If you haven't seen it already, you can find out more about plugin hybrids here:
    Prius PHEV - EAA-PHEV
    Rob
  8. icarus
    4,884
    976
    earth
    As Rob says,,,,BINGO.
    You might be able to make the argument that hypermilers would benefit from removing the battery and the associated weight?
    Icarus
  9. miscrms
    2,079
    526
    Phoenix, AZ
    NimH are a very different beast unfortunately. The biggest problem is that their voltage is not a good indicator of SOC. As they get full, they will start to heat up, their internal pressure rises, and their voltage will flatten out or even drop. You have to either monitor dv/dt and look for the flattening or peak, or monitor temperature and look for dT/dt (preferably both). You pretty much have to do this on a single cell or small string of cells basis, as cell to cell variation tends to be significant and trying to look at too many at once will mask the effect you're looking for. Another problem here is that due to these issues NimH cells do not like to be paralleled.
    The Toyota pack is I believe made up of a single string of 6.5Ah, 7.2V prismatic packs similar to these:
    Plastic Case Prismatic Module | Panasonic EV Energy Co., Ltd.
    Even in a single string the charging and discharging is complicated enough that you need a BMS (battery management system) to babysit the batteries and keep them in their safe operating ranges. Since the battery voltage is not a good indicator of SOC, the ECU employs a coulomb counting scheme. Basically, what ever charge you take out of the battery it puts back. This is one of the big challenges to the PHEVer, is that the controller doesn't care how big the battery actually is. It knows how big the battery is supposed to be and only uses that amount of energy. Cal-cars, and others that use parallel packs get around this by taking the pack voltage higher than normal to trigger a recalibration event referred to as SOC-Drift. In this way you can get the car to use the extra battery, but you introduce a lot of additional challenges by using a higher voltage secondary battery. This is why most of the commercial conversions pitch the prius battery all together and install their own primary battery and a new BMS/controller. Thats way beyond the capabilities of any DIY conversion yet though.
    This is a big part of the reason that most PHEV work being done has either focused on sealed PbA or Li-ion. Li-ion has its own issues, but large capacity cells and appropriate BMSes are fairly available. One exception is the Nilar NimH, which have a built in pressure sensor to indicate the onset of charge saturation. They're decent capacity, and the charge sensor is pretty easy to monitor. I think you still have to charge them in parallel strings and monitor every pack but its at least feasible for the DIYer.
    Plug-In Conversions and Nilar Team Up
    Rob
  10. Patrick Wong
    18,200
    6,499
    Hi Icarus,
    This is not correct. The Prius traction battery is a series array of individual cells:
    • Six 1.2V cells per module
    • 28 modules per traction battery
    • 201.6V nominal voltage rating (6 x 1.2 x 28)
    If you try to connect battery modules in parallel, you'll end up with one module hogging most of the charging current due to small internal resistance differences.
  11. icarus
    4,884
    976
    earth
    Patrick
    Got it!
    T
  12. dwreed3rd
    742
    Marietta, Ga
    I want to thank everyone for the EXCELLANT posts. And please, I appreciate your concern but let me put your minds at ease. I have no intention of electrocuting myself, blowing myself up or experimenting with our, to-date, virtual Prius, although there probably was a day. Older and wiser now. Thank you, Bob, for the offer. I assure you it is purely a hypothetical question for the mental exercise. I was sure there were valid reasons for the design specs/parameters. that Toyota established. I am trying to understand what those are. Sometimes, a limitation is established by the manufacturer for reasons that the user many feel is worth the consequences. I think the EV Mods are a good example. Sometimes you accidentally stumble onto something of value while brainstorming on a different goal. Vulcanized rubber, Teflon, penicillan, and my favorite brandy, to mention a few. Never be reluctant to think outside of the box or afraid to look in it. The above posts are extremely informative, interesting and enlightening and I am really enjoying the thread.
    We live north of Atlanta which put us in north Georgia at the foot of the Appalachian Mnts. The seed for thought was spawned by the hilly topography and the posts that seem to indicate improved mileage, over non-hybrid, in the stop/go urban traffic scenerio. It started me wondering if the battery pack had enough charge capacity to capture all the kinetic energy from all the downhill braking; or if it was maxing out on the long downhills and being lost as heat. That just brought up a new question! When that Battery Pack reaches full charge state (80%), what happens to MG1 & MG2. Do they cut out and have the brakes take over or do they continue to use the MG's across a load resistance for dynamtic braking like I added to my R/C race cars back before it was a common feature?
    Thanks again. This is most enjoyable.
  13. dwreed3rd
    742
    Marietta, Ga
    Patrick; Makes sense. Thanks
  14. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    MG2 is used to generate power, that power is then sent to MG1. MG1 becomes the load resistance as it attempts to spin the ICE (with fuel and spark cut) against it's internal resistance. IF this isn't enough stopping power, then braking is supplemented with the brake pads as needed.
  15. dwreed3rd
    742
    Marietta, Ga
    Thanks! It all comes together. I always like to understand, to the best that I can, what's inside the box and what makes it tick. I really appreciate all the posts. I am really salavating waiting for our Prius. I think we pretty much exausted this topic, but It really goes to show the vast depth of knowledge of the forum's members. Awesome!
  16. miscrms
    2,079
    526
    Phoenix, AZ
    Long climbs and downhills could be a special case where more battery could be useful. You burn a lot of extra gas getting to the top, and ideally you'd want to capture as much of that energy back as possible when you come back down. In my experience anything more than 4-5 minutes of significant downhill grade will usually fill the battery, at which point you are no longer able to recapture energy. If thats a situation you face regularly, you could get some benefit. IMHO there are two ways you could consider doing this.
    1. Add a second Prius pack, as Steve did on the page below. The results were not impressive in general, but again if you regularly go up and down very long grades you could be in a unique situation. Steve has now moved on to a full Li-ion plugin conversion in the second link.
    DISCOUNTED INSURANCE SALVAGE
    Prius Aux Battery preliminary
    2. Do a cal-cars open source "PriusPlus" lead acid conversion as described below. This is about the cheapest plugin conversion you can do, at least from an upfront cost perspective. The Nilar NimH version may be cheaper in the long run due to much better battery life. One nice thing about the simplicity of the cal-cars conversion is it allows regen energy to be stored back in the secondary pack. When the secondary pack is depleted it stays attached to the primary battery which has the benefits of increasing battery efficiency by lowering effective internal resistance, and increasing capacity to store regen energy. This is not true of most of the more sophisticated conversions that use big dc:dc converters. Its probably questionable whether dragging the added weight of the lead acid up the mountain would burn more energy than you could recover coming back down. You would also need to plan your battery usage such that the secondary pack is empty before you get to the top so that you will be in this paralleled "charge sustain" mode coming down. Theoretically I can imagine that if you were using the secondary pack for hybrid assist on the way up, giving you lots of battery capacity ready to be filled up on the way down that could certainly be a good thing. Just not sure if the extra battery capacity would be a help, or mostly just the extra energy stored from the grid as with a traditional phev.
    PriusPlus - EAA-PHEV
    Rob
  17. dwreed3rd
    742
    Marietta, Ga
    Of course! Using the ICE with fuel and spark cut. The Hybrid's version of the down shifting on down grades..
  18. dwreed3rd
    742
    Marietta, Ga
    So let me see! If I understand correctly, I probably should not go ahead and mount the switching control unit, shown below, on the dash, as planned.
  19. 425i
    425i New Member
    Australia
    I to was thinking about the possibility of adding a second battery in parralell as the route to work is quite hilly in sections and the battery drops right down and I have to slug up the hills using the ice. The fact that the ecu knows the battery size seems to kill the idea completly.
    Nick
    "Since the battery voltage is not a good indicator of SOC, the ECU employs a coulomb counting scheme. Basically, what ever charge you take out of the battery it puts back. This is one of the big challenges to the PHEVer, is that the controller doesn't care how big the battery actually is. It knows how big the battery is supposed to be and only uses that amount of energy."
  20. dwreed3rd
    742
    Marietta, Ga
    See Patrick's post #10.
