Heated side mirrors: when?...
Discussion in 'Gen 2 Prius Main Forum' started by mikepaul, Feb 23, 2005.
  1. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    What do I turn on that also heats the side mirrors? Up until then, I thought they were heated.
    Foggy and lots of dew yesterday, so I was running front and rear defrosters all of the ~20 minute drive to work but the side mirrors never defogged.
    Any test to see if they are shorted out or something?...
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Hmmm, I thought it was the front defroster that turned them on.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Mine work with the front defroster just like the manual says. I am sure the dealer can check to see if yours are working.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    They're standard on Canadian market Prius, as far as I can tell. They turn on with the REAR defrost button. It's possible they are not offered in the U.S., or only as part of an option package like the rear wiper is.
    At -40, driving into the heated underground parking will cause the side mirrors to instantly fog up. I hit the rear defrost button when I approach the garage door, drive in and back into my stall. The mirrors never fog if I remember to hit the rear defrost before driving in.
  5. Dave
    Dave New Member
    340
    Santa Cruz, CA
    They become active when you turn on the REAR defroster. They work quite well.
  6. mikepaul
    1,763
    Columbia, SC
    I'll keep an eye on it for a while before I decide it's really broken or something. Thanks...
  7. efusco
    19,891
    1,196
    Nixa, MO
    I guess that make sense...you're trying to see behind you'd want the mirror and rear window defrosted....I've never used my rear defrost or needed my rear view mirrors defrosted and just, for whatever reason, assumed it would be the front defrost I'd need to use.
  8. KMO
    KMO Senior Member
    2,006
    730
    Finland
    2023 Prius Prime
    We don't get mirror heaters in the UK, although they're mentioned in the manual (with a "if fitted" clause). Not sure about the rest of Europe.
  9. DaveG
    DaveG Member
    806
    Vancouver, BC
    Yup, definately the rear defroster. It clears mine in about 10 seconds when I tap the rear def. switch.
    Dave
