Pruis Maintenance
Discussion in 'Gen 2 Prius Main Forum' started by SunRayz, Jun 21, 2008.
  1. SunRayz
    SunRayz New Member
    Canda
    I am 95% sold on getting a pruis. The one thing I am wondering is the maintenance for the puris. Are repairs more costly then a non hybrid vehicle?
    Thanx for all the help
    Carla :)
  2. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Damn cheapest car to maintain I've ever owned; here are my costs for 50,000 miles.
    1. Oil change, filter and tire rotation every 5,000 Miles costs around $50.
    2. Trashed the OEM tires at 10,000 miles for Goodyear ComforTreds from TireRack for $300 delivered, plus $50 dealer mount and balance
    3. Self installed new Toyota air and cabin filters every 10,000 miles cost $25
    4. Last week, at 50,000 miles, bought Goodyear ComforTreds from TireRack for $312 delivered and paid the dealer $213 for tire installation, balance, NitroAir, 4-wheel allignment, oil change, filter and wipers (70 MPH commute and Florida heat/roads are murder on tires)
    That's $1,500, or $.03 a mile for 50,000 miles, and my new tires should last me to 90,000 miles. I did buy the 7-year/100,000 mile Toyota extended warranty from Troy for under $1,000 and I'll be happy to never use it.
  3. resoh02
    resoh02 Member
    140
    Northern OHIO
    I would definitely not recommend HID headlights with all the problems with them listed on this site. If one burns out your looking at 300. to replace. They also have not been lasting like they should.
  4. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Costs less to maintain because there's less to go wrong. No belts or an alternator to break. Friction brakes only used when <7 mph or in an emergency stop, so they take forever to wear out. So far I've only needed oil changes and tire rotations out of pocket. Front end alignment under warranty so no charge to me. (It did cost me $10.00 to have the "oops" fixed.:embarassed:)
  5. Carbot
    Carbot New Member
    Chesapeake, VA
    My '04 has over 201,000 miles on it. It is by far the least expensive car I have ever owned to maintain. That's not even factoring in the high MPG. Brakes seem to last forever. Mine are still original. My wife has a '03 Murano. Great car, but maintenance is ridiculously expensive.
  6. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    I agree with what the others said about maintenance. And repairs are very infrequent. Consumer Reports (and others) rates it as very reliable, so odds are you'll have nothing break.
    IMHO, the only downside insofar as repairs are concerned is that there aren't many independent shops that have learned the hybrid system well enough to be competent and confident in its repair. So in the unlikely event of an out-of-warranty repair to anything related to the hybrid system, you're stuck with the dealer -- and its prices.
  7. F8L
    19,011
    4,081
    Grass Valley, CA.
    I can't answer the question directly from experience because in 67,000 miles I've only had 1 repair and it cost me under $1 (burned out tail light bulb). :)
  8. richard schumacher
    7,663
    1,038
    United States
    In four years and 30,000 miles I've spent $250 on scheduled maintenance (every 5,000 miles/6 months) and bought four tires.
  9. hschuck
    hschuck Member
    385
    17
    bay city, ca
    49,000 miles here. Oil changes and tire rotation/replacement are the only maintenance performed.
  10. tochatihu
    tochatihu Senior Member
    9,057
    3,529
    Kunming Yunnan China
    2001 Prius
    As Prius routine maint. is so light, some of us suggest that you add a periodic transaxle fluid change to the list.
  11. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    92
    Virginia
    Costs the same, if not less.
    Brake pads last a LOT longer, 5000 mile oil changes (10,000 in europe and their synthetic-like oil), just a few fluids and other stuff to top off/replace as needed. Past problems have been largely addressed with design flaws, and the prius is very reliable.
    As for repairs... Depends on what breaks out of warranty. Keep in mind: If you jump the car incorrectly, your looking at a very expensive repair bill, as you fry a lot of electronics. But hey, with a normal car, its expensive to repair a transmission or some other part :p
  12. Icculus
    Icculus New Member
    27
    One thing to note, which I did not realize until I picked mine up -- my dealer told me that if you take the Prius to a non-Toyota dealer for oil change or whatnot it will void the warranty (eg no Jiffy Lube). My nearest dealer is a 30-min drive so it will be more of a hassle for me, but I'd rather not void the warranty or take a chance of someone unfamiliar with the synergy drive screwing something up.
    Interested if anyone else has had an issue with this, anyone taking chances and hitting their local Jiffy Lube anyway?
  13. snowdog650
    snowdog650 Member
    171
    27
    Sacramento, CA
    Sounds like you need a new dealer, as the one you currently have lies to your face.
  14. JimboK
    2,817
    187
    49
    Chesterfield, VA
    What Snowdog said. What your dealer says is hogwash. For there to be a warranty issue there must be an engine failure caused by or contributed to by not changing the oil as Toyota specifies, not as a dealer specifies. Just keep good records.
    The oil change is straightforward and has nothing to do with the hybrid system. Having said that, I'm not sure I'd trust Jiffy Lube. Too many reports on the web of them not doing it right or even ripping folks off. I'd suggest either a reputable independent shop or doing it yourself. The latter is easy; the drain plug and the filter can both be reached without lifting the car.
  15. Icculus
    Icculus New Member
    27
    Ugh, I was hoping that wasn't the case as I really liked the guy. I'll probably call over there tomorrow and speak to the service manager about it ... Thanks for the heads up!
  16. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    DO NOT GO TO JIFFY LUBE
    just take it to the dealer, or find a reputable garage that will do it if you bring your own oil and filters in. keep your oil receipts and work orders
    or you could do it yourself inbetween major services i.e 30,000/60,000
    they really dont do a whole lot more in the 30,000 mile except replace airfilter and cabin, which is very easy to do yourself. Though they supposedly give the car a more through check over.
  17. Bob64
    1,540
    92
    Virginia
    Jiffy lube has earned itself a bad reputation in my books. I'd rather do the changes myself.
  18. Prius313
    Prius313 Member
    219
    What do some of you think about the scheduled maintenance that recommends changing/flushing the transmission fluid and anti-freeze? It's recommended at around 60,000 miles. Have you all been doing it?
  19. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Your dealer is a lying sack of sh!t. Anyone can do an oil change, basically drain the oil, remove and replace filter, fill with oil. Has nothing to do with the HSD. The Firestone guy told me they aren't qualified. Why not go to the mechanic who serviced your last car?
  20. tochatihu
    9,057
    3,529
    2001 Prius
    Speaking as one of the fans of transaxle fluid changes. The cautious would perhaps do the first change earlier than 60k and subsequent one on longer intervals, assuming that the fluid analysis supports the decision. But gravity drain only, no flushing.
    Both coolant loops should go 100k on the first fill (50k subsequently) and I see no reason to alter that.
    Above numbers for NHW20 Prius. For NHW11, or if blurred vision develops, see your doctor.
