Air-Powered Car Coming to U.S. in 2009 to 2010 at Sub-$18,000, Could Hit 1000-Mile Range
Discussion in 'Other Cars' started by Areometer, Feb 23, 2008.
  1. Areometer
    Areometer Silver Business Sponsor
    578
    Tyngsboro, MA
    Don't know if this was mentioned before, but here goes:
    By Matt Sullivan
    Published on: February 22, 2008
    The Air Car caused a huge stir when we reported last year that Tata Motors would begin producing it in India. Now the little gas-free ride that could is headed Stateside in a big-time way.
    Zero Pollution Motors (ZPM) confirmed to PopularMechanics.com on Thursday that it expects to produce the world’s first air-powered car for the United States by late 2009 or early 2010. As the U.S. licensee for Luxembourg-based MDI, which developed the Air Car as a compression-based alternative to the internal combustion engine, ZPM has attained rights to build the first of several modular plants, which are likely to begin manufacturing in the Northeast and grow for regional production around the country, at a clip of up to 10,000 Air Cars per year.
    And while ZPM is also licensed to build MDI’s two-seater OneCAT economy model (the one headed for India) and three-seat MiniCAT (like a SmartForTwo without the gas), the New Paltz, N.Y., startup is aiming bigger: Company officials want to make the first air-powered car to hit U.S. roads a $17,800, 75-hp equivalent, six-seat modified version of MDI’s CityCAT (pictured above) that, thanks to an even more radical engine, is said to travel as far as 1000 miles at up to 96 mph with each tiny fill-up.
    Full Article:
    Air-Powered Car Coming to U.S. in 2009 to 2010 - Zero Pollution Motors - 1000-Mile Range - Popular Mechanics
  2. darelldd
    6,059
    389
    Northern CA
    Hadn't seen that article yet, though these have been promised "next year" for many years now. This thing doesn't even exist yet, of course! And they'll sell it here in just a year or two? That's a pretty tall order - almost as likely as selling 100's of 1000's of Volts in 2010.
    I'm also a bit confused - they speak of the "air car" and "zero pollution" and then go on to talk about maybe getting 1000 miles if they have a tank of liquid fuel and some compressed air. Huh?
    Unless the laws of thermdynamics are broken, this will be among the least efficient vehicles on the road. :-(
  3. qbee42
    3,079
    Yes, the losses of going through those compression/expansion cycles will be killers, and carrying enough compressed gas will be harder than batteries, and we know how difficult that is.
  4. Doc Willie
    1,717
    144
    Out there, somewhere
    Whoa. This company is in my home town? And I do not know about this?
    I do now. I will check them out.
  5. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I find concept drawings to be so very stylized... and usually ugly.
    My Prius is prettier.
  6. daniel
    14,487
    1,519
    Spokane, WA
    More bullshit. We've beaten this horse to death several times over. :deadhorse: Yes, it is possible, even trivial, to run a car on compressed air. However, the heat generated during the compression phase makes it very inefficient unless you can utilize that waste heat for space heating. (E.g. re-charge the car while it is sitting in your living room in winter.) Further, compressors are noisy. The thing is going to make a dreadful racket while it's charging. And finally, the range on a charge of air will be short, due to the limitations on how much air can be shoved into a given tank. And tanks capable of sustaining high pressures are very heavy. And of course if you carry fuel to run an engine to run a compressor to re-charge the air while you drive then you've defeated the whole point of an air car.
  7. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Hmmmm.. There's a tire shop down the street that has an air hose that's left out 24 hours a day with free air for topping up the tires. I wonder..........:rolleyes:
  8. daniel
    14,487
    1,519
    Spokane, WA
    Hey, if it'll deliver a few thousand psi you're in business! :car:
  9. leegsk
    leegsk New Member
    According to the website of ZPM, the car is a hybrid compressed air/gasoline engine, getting a total of just over 100 mpg in normal use. The compressed air is stored in carbon fibre tanks and is the source of energy until about 35 mph. There is even a video of an Australian journalist driving a (very noisy) prototype.
    It seems to work but the economics of its mechanism remains to be seen. They claim that the three tanks use about $2 per refill which seems very low even at last year's energy pricing. Also, they air is converted to rolling force using pistons and a crankshaft; that seems to be an inefficient way.
    The key calculation would be if storing energy as compressed air and converting it into kinetic energy would be as economical as storing energy in a battery.
    From a user viewpoint, the noise factor using the proposed drivetain is a consideration. The idea may make economic sense.
  10. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    D'OH! someone beat me to it.:eek:
  11. stevecaz
    stevecaz New Member
    77
    Massachusetts
    There was a great series on one of the Discovery networks last year called Future Cars where they looked at this technology.
    It was pretty cool.
  12. Devil's Advocate
    922
    Las Vegas, Nevada
    I saw this a year ago, the prototype seems real, but will they be able to produce something other than a death box that will get approval for the U.S.???
    I think that there is a New Zeland company that has an air engine that uses a rotary piston, which is much more efficient for air.
  13. daniel
    14,487
    1,519
    Spokane, WA
    While the technology can work, the claim of 100 mpg is not credible. With the energy ultimately coming from gasoline, and with the loss due to the heating of the air as it is compressed, I'd believe something in the 40 to 45 mpg range.
