Question about best practice
Discussion in 'Newbie Forum' started by lmp, Jun 23, 2008.
  1. lmp
    lmp Lauris
    Latvia
    Hi there,
    I'm still in hope to have my Prii after some time. But as many people I can't wait till I get it :) Dealer guy says somewhere in middle of August.
    The question I have is quite simply but anyway maybe someone knows how it is better. I'm in Europe so I'll have European version of Prii, it has EV button.
    For example in morning when I get into car and start my car I have to go in very low speed trough neighborhood about 500m till I get to street where cruising speed is fast enough so it is required to run ICE. So how is better to proceed, to allow automatic start of engine, or to press EV button and drive till street in EV mode? And afterward how is better to switch off manually EV mode shortly before going on street or just allow automatic to switch it off during acceleration?
    How this all deals with coolant stored in thermos and following heating of ICE?
    Cheers!
  2. richard schumacher
    7,664
    1,044
    United States
    Your situation is exactly what the EV button is designed for. Use it while you are in the neighborhood, both when leaving and returning, and turn it off otherwise.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    :welcome: Welcome to PriusChat, lmp!
    I don't think your European Prius has the hot coolant storage thermos bottle, I think that it, and the notorious fuel bladder, are North American affectations. But you do get 4-wheel disk brakes, which we don't.
  4. lmp
    lmp Lauris
    Latvia
    Hmmm, interesting... if there is no coolant storage thermos in European version, then why this about 7 sec delay from "power on" till ICE start.
    Of course there might be a lot of reasons :D
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I suggest NOT using the EV button for the initial 500m. That's a perfect time to allow the ICE to warm up while going very slowly...that's the most fuel efficient and cleanest way to do that. If you EV that first 500m the ICE will run esp. hard (ie. inefficiently) and there will be more draw from the battery (also inefficient).
    I used to do the stealth out of the subdivision thing, but I'm convinced now that I'm doing much better by allowing that warm up. I now use the EV button only to force the ICE off before S4 when approaching stops or for just moving the car around in the driveway and such.
  6. richard schumacher
    7,664
    1,044
    United States
    So, Evan, you're saying that for the average driver it's better not to use the EV button at all? I here define "average driver" as "someone who is not going to bother to find out what S4 is". I'm not trying to be confrontational.
  7. lmp
    lmp Lauris
    Latvia
    Thanks, Richard for pointing me to topic. :) After this post I have read much more info about Prii and "what's inside", not only about stages. :ranger: Anyway, there are still some questions about practical side of using all that stuff (theory is good to know, but on the road all that is quite different), but I suppose I just have to wait when I'll get one and then try to figure out my own best practice. :) It just takes so long :eek:
    Cheers!
  8. jacksonny
    jacksonny New Member
    Sydney, Australia
    Re: aussie version
    bill, so does the aussie version come with any of the stuff mentioned above?
    and also, is the water source of the rear wiper coming from the same tank as the front wiper spray?
  9. efusco
    19,891
    1,194
    Nixa, MO
    Better off in terms of using it as a tool for MPG? yes, that's what I'm saying. I'm not necessarily discouraging anyone from installing one...I think they're still fun, it's cool to be able to move the car around without the ICE starting, whatever. But yea, in general there are much better ways to improve FE. I use my EV button very rarely these days preferring to get into S4 as early as possible and then letting the car 'do it's thing'.
  10. Bill Merchant
    4,096
    85
    Re: aussie version
    I should think you'd be in a better position to answer than I. I do know that there is only one washer reservoir.
    One thing I noticed about the Prius I saw in Melbourne a couple of years ago is that the plastic lens covering the headlamps is a bit more angular than the NA version, though still smoothly rounded.
    And you have the marker lights below the Hybrid badge on the front fenders.
  11. jacksonny
    Sydney, Australia
    hmm, i'll go have a look, thanks!
  12. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Evan is quite correct about the use of the EV switch.
    I would not use it leaving the neighborhood in the morning when the car is cold.
    I would use it coming back in.
    Anything that depletes battery state-of-charge (SOC) significantly is very bad from an efficientcy stand point.
    Use of the ev switch will do that.
    Plus, It's best to let the ICE warm up before you really get it on the road, because the Prius will try to reduce engine load if you don't, by favoring electric assist and deplete your battery. (Or, possible worse, if you push it too hard, you'll induce rapid ICE opporation when its cold.)
    That will result in huge opportunity cost in glide and stealth operation down the road until it can recharge. Very inefficient. Those who really understand how this car works and how to get the most out of it realize this.
    When the ICE is cold, the ev switch should only be used if there is no intention of actually driving the car, like driveway or parking lot reposition.
    If you intend on driving, don't use it until the ICE is warmed up and then only for very short duration. Again you don't want to intentionally deplete SOC too low, because it will cost you later. Example, 1/4 mile or so of forced EV will cost you MILES of opportunity cost in lost glide, stealth and warp stealth possibilities. Not a good trade-off.
    There is a tremendous temptation to use the Ev switch when you first get in the car, cold. Don't fall for it. Most of the time it's a bad idea.
    Use ev on the road to link glide opportunites, where the incline/pedal load demand is too high to allow basic stealth opporation for that brief moment. Use it to move forward in traffic for that obvious shot distance to the next stop, especially if the needed rate of acceleration would prevent basic stealth movement. (EV swich allows more demand/pedal lattitude without starting the ICE.) That's where it's really useful.
    Use it during a glide at lower speeds to crest that hill that would induce opporation, unit you can get to the other side and glide again.
  13. richard schumacher
    7,664
    1,044
    United States
    Thanks for the clarifications. Using EV on the way out will harm fuel efficiency. The original poster may still want to use it while operating in the neighborhood to minimize noise or emissions while driving there.
  14. lmp
    lmp Lauris
    Latvia
    Thanks from me too ;) Probably I will not use, at least at beginning of trip (with cold ICE). :)
    Of course exception is some times to play with car and all that features - have fun from it :D
