5000 mile strange increase in MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by pauleknight, Jun 30, 2008.
  1. pauleknight
    pauleknight Junior Member
    17
    Orlando Florida
    We are a two Prius family. My wife has an 07 and I recently purchased and 08.
    Well the 07 was used and had 9000 miles on it when we took it home.
    The 08 was brand new.
    I noticed that her 07 got better MPG over my 08, but I assumed it was because I am on the highway 50% of the time and she is back and forth from the kids school. I also noticed that her battery seemed to have more UMPH, (I am sure that it is watts ot amps or something techincal, but UMPH is the best that I can come up with) when we pull of from a red light in her car.
    Well last week after passsing 5000 miles (yes I put 5000 miles in 2 months), the cars MPG shot up from 44MPG to 48MPG and it is still climbing.
    My habits have not changed, the gas has not changed the car has not been in the shop, so nothing changed.
    Also the UMPH at red lights is more like her car.
    I am guessing that the first 5000 miles might be a break in period that is regulated by the car's comptuer on the battery?
    Is that possible?
    Anyone expreience the same?
  2. Neicy
    Neicy Member
    834
    Wakefield, MA.
    I also experienced that, but at the time chalked it up to experience driving and a wheel alignment in the vicinity of 3700 miles.
  3. dud2001
    dud2001 New Member
    Toledo, Ohio
    I have read in several forums that the Prius has a break in period of several thousand miles where the mpg goes through stages of improvement. As was also stated, the longer you drive the Prius the more techniques you learn to improve the overall mpg.
  4. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    PAULEKNIGHT - yeppers. what you have experienced is a prius, hybrid phenomenon! actually, it's just a break in process. i heard that at 10,000 miles, a secondary wind kicks in and our motors get even better!
    i can't wait!
  5. richard schumacher
    7,664
    1,044
    United States
    Did it get better right after the 5000 miles service?
  6. pauleknight
    17
    Orlando Florida
    I have read lots of people talking abuot the breakin period of the car and of the driver, BUT since we had another Prius before this one, it does not make sense that it would be me.
    Also I have not had the 5K mile service done yet. I am at 5,600 miles and am going to bring the car in next week.
    Also the increase in MPG was drastic at exactly 5K miles, it only made since that the MPG increase was due to a comptuer thing and NOT a "break-in" thing.
    Amyone have anything similar happen?
  7. triumph1
    triumph1 Member
    275
    I had been hovering around 51.8 mpg.... these last two tanks, since I hit 4500 miles, I've been averaging 54, and I haven't changed a thing, other than using the AC even more, higher blast.
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i had gains around 5k.. 10k and 15k.. but was using my car as a delivery car and no longer have to drive that mild... otherwise i was getting 50+ delivering cookies... after 15k. around 48 for 10k.. and a tad less for 5k.
  9. Stefx
    Stefx Member
    336
    An alignment at 3700 miles?
  10. Mole_8
    Mole_8 Junior Member
    Alabama
    I have about 25k miles and the car is running much smoother and with more power. Also, I use high octane gas. The Prius engine has a high compression ratio, which requires higher octane of fuel. By doing so, I actually get an extra 100 miles or so per tank.
  11. richard schumacher
    7,664
    1,044
    United States
    In a Prius anything above 87 octane is wasted money, for this reason: the variable valve timing makes the *expansion* ratio about 13:1, but the *compression* ratio is about 10:1. Stop making Exxon and pals richer.
  12. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    So why do you suppose the owner's manual recommends regular?
  13. Rest
    Rest Active Member
    1,210
    CA
    An increase in MPG is normal for any vehicle at this mileage.
  14. Ichiro
    Ichiro Member
    335
    SF
    Are you serious?
  15. qbee42
    3,077
    High octane gas will not increase mileage and in some cases may cause a reduction in mileage. This is a common misconception, but still a misconception.
    High octane gas would offer an advantage only if the Prius engine was designed to take advantage of it, which it is not.
