Neat accessories on Toyota Japan Prius Site
Discussion in 'Gen 2 Prius Main Forum' started by dbarry, Feb 25, 2005.
  1. dbarry
    dbarry Member
    114
    Houston Texas
    I found some interesting stuff on their site, and got some idea of each item using Google translation
    Three favorites areL
    Built-in 1200watt A/C outlet in the car
    Side mirror that automatically tilts down when you go in reverse (just like my old Acura)
    Toyota's G-Book Nav system which has neat 3-D views, real-time traffic avoidence, etc
    Some pics attached...
  2. dbarry
    dbarry Member
    114
    Houston Texas
    And the antennas that come out of the front bumper to check your clearence.
  3. myride
    myride Junior Member
    61
    Houston Tx.
    i really like the idea of 120 volt outlets in the veh but we need more outlets and maybe higher watts. 2500rms with 5k peak would work. then i could run my mini office out of my car :mrgreen:
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(dbarry\";p=\"67270)</div>
    It is only 100W of 100V AC converted from DC 12V.
    The Alphard/Estima Hybrid Minivan has 1,500W of 100V AC converted from the HV battery as standard equipment.
    Regards,
    Ken@Japan
  5. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(myride\";p=\"67274)</div>
    There is a special Prius and test home made by Toyota Home.
    https://toyotahome-net.com/papi/atr/index.html
    The test home has the emergency power connector from the special Prius.
    The Prius can supply 3000W for 36 hours, they said.
    Of course, the test home has the smart key system using the same fob as Prius.
    Regards,
    Ken@Japan
  6. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    3 KW for 36hours, That might be a real revolution! And Toyota could become #1 in home power generation and Hybid Vehicles. Goodbye Arabs and Goodbye Electric Utility companies
  7. Anonymous
    Anonymous Guest
    Assuming a 30% conversion efficiency of petrol energy to electrical energy, and 1 litre of petrol containing about 9kWh of chemical energy, you're looking at using 0.37 litres of fuel (about a tenth of a US gallon) to make each kWh of electricity.
    That means (at $2 per gallon), the electricity from your Prius would be costing you about 20 cents per kWh, which isn't too bad compared to grid costs of maybe 12 cents per kWh. However you could just stick a windmill on the roof of your house and get it for 1 cent per kWh!
