How do I open the hatch door when powered up?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ZC1, Jul 1, 2008.
  1. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I keep running into this and need a couple answers.
    I enter the Prius and power it up to READY or have been driving and now am parked with power ON.
    At this point, I need something in the cargo area, so I reach for door handle, get out, walk to hatch and the hatch refuses to open even if I have the key in my pocket which I always do.
    Only solution I've found is to walk back around to the front, open my driver's door and hit the unlock button, walk back around and open hatch.
    I reset the open doors on... feature, so my wife can approach the driver's door which unlocks while all the other doors stay locked. Much safer that way.
    Should not the doors open while the key is in the pocket even if the car is ON.
    This problem does not occur if the car is OFF.
    Suggestions?
    ZC1
  2. qbee42
    3,081
    Suggestions? Unlock the doors before you get out. It sounds trite, but it works.
  3. ZC1
    711
    Metro Detroit
    I knew it would be soon when that answer came.
    It came a bit sooner than I expected.
    I'm sure the first 50 times I'm going to forget to hit the unlock switch, but after that........ golden.
    ZC1
  4. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    I don't think this behavior is limited to the hatch. If the passenger door is locked and the car is on, I don't think the SKS will unlock the passenger door when you grab the handle. Same with the drivers door. I'll try it when I leave work and report back later.
  5. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Never had that problem, I'll have to try it out tonight.
  6. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    I have my remote programed so it unlocks all locks when I enter the car that way when I get out and need to open the hatch it is unlocked.
  7. chrono807
    chrono807 New Member
    Scotia, NY
    Sounds to me like a safety feature - if they hadn't done this, then someone could walk up and open your hatch if you're stuck in traffic.
  8. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Can you press the unlock button on the keyfob to open the hatch in this situation?
  9. tachan
    tachan New Member
    I think it'll depend on your setting. If you have the setting set to what you have said then it's a safety feature that keeps the doors locked because the car is on. It doesn't want intruders coming up and just unlocking the doors. I would have my key in my pocket with the car started and all doors locked, then my dad would come up with the 2nd key in his pocket and it still won't open the door for him. Unless the car is not started, I would unlock the driver's side then he'll go to passenger side and unlock all doors.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Mine is the same. You cannot open back hatch with car on. They don't want you to get run over cause you left the car on I guess.
  11. Danny Hamilton
    926
    94
    I don't know of a way to change it. I tried it last night, and this appears to be the way SKS is designed to work. It is not just the hatch. I tried all three doors (driver, passenger, hatch) with the car in "Ready" and the fob in my pocket. None of the doors unlock.
    I haven't tried the buttons on the fob yet, if I get a chance I'll try that today, unless someone else posts about it here first.
  12. ZC1
    711
    Metro Detroit
    For those folks who are posting "It keeps people from opening your hatch while in traffic"...well, in the original post I said "..My key is in my pocket."
    I don't expect the hatch or any other door to open IF you don't have a key on you, but I would like to expect the SKS to allow ANYONE to open the hatch/doors if they are sporting the FOB for my exact car.
    Possibly Toyota's programmers didn't allow this feature because they don't want you outside of a running car with the key FOB, trying to unlock doors.
    I did try the buttons on the FOB, while in this situation. Pushing the buttons only results in dead silence. So that idea is out, too.
    (I knew all doors didn't open but mentioned the hatch only)
    ZC1
  13. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Ok, it's this simple. When the car is on (READY) the SKS system is disabled.
    So now it's like any other car. If you approach a fully locked car and only unlock the drivers door, then start the car, and get out to get something, ONLY the drivers is unlocked, so the rest won't open.
    If you approached the car in the beginning, and unlocked all the doors, all the doors would open, even after you start it.
    SO, It all depends on how you have your SKS locks set. If it's set for just the drivers door (which you said your is for safety), and you start the car, then you need to unlock the other doors manually to access any other door before getting out of the car.
    The expectation that a smartkey would allow unlocking of doors after you start the car, that you didn't wish to be unlocked before the car was started,
    makes no sense.
    And the expectation that the car should recognize the driver's SK or multiple smart keys, after the car is started, is just plain dangerous. The last thing I want (and Toyota too, i'm sure) is someone (or the driver) to be behind a running car, that the least little mental glitch by the operator could result in them getting run over. Especially with the Prius, where interpretation of what running mode it's in is such a big problem with people.
  14. Fraser
    Fraser New Member
    667
    Navarre, Florida
    I just tested parameters on our car. The door locks are set to open when either driver or passenger door is opened. Tried to open the hatch at READY without driving it with driver door both open and closed. Also drove it up and down the driveway, set the parking button and tried to open the hatch with driver door open and closed. In each case, without exception, the hatch opened. The only anomaly I noticed was the READY light remained on with each test. I may not have noticed previously if it stays on in normal operation, so I can't say that was a variation from the norm.
  15. 9G-man
    1,273
    194
    Atlanta, GA
    What was the point of this experiment, your SKS is set to unlock all the doors, and they were. No surprise.
    OP's SKS is set to unlock only the drivers door, so the rest are locked.
    He wants to get out of the car, after it's running, and access things, yet he can't with the SKS set like that. He doesn't like it. All he has to do is manually unlock the doors, or change his SKS setting.
    And how is your READY light remaining on an anomoly? You never powered down the car.
  16. 9G-man
    1,273
    194
    Atlanta, GA
    See what I mean;)
  17. tmanson
    tmanson Geetar-playin' Traveler
    71
    Frederick, MD
    How do you program the remote to do that?
  18. patsparks
    10,664
    569
    Adelaide South Australia
    I have the same problem with the front door of my house, bloody thing wont open when it's locked. I tell you it is really starting to get to me.
  19. Jack66
    766
    Stafford, Virginia
    Reprogram your house and pray that the bladder never gets screwy! :D
  20. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    It's in the Owner's Manual, near the beginning, in the section/chapter about Keys and Doors.
    In my 2007 Owner's Manual, it's on page 32 under a heading "CHANGING THE DOORS TO BE UNLOCKED".
    If I understand the instructions correctly, I think you have to press the Lock Button and the Panic Button (the red button) at the same time until you get to the unlocking mode that you want.
    BTW, what's with that Panic Button? What's it supposed to do?
