Judging by speed of PC we're goin' down
Discussion in 'PriusChat Website Questions' started by MarinJohn, Feb 27, 2005.
  1. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    Danny is it possible for you to shut PC down before it crashes, then bring it back up?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    it's probably not PC but the server it's on being attacked.
  3. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Running about normal with me right now at 12:48 CT.
  4. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Looking at the logs it looks like it was just Google and MSN spidering the hell out of the site at the same time. I'll try to look into a way to only allow them to have one session at a time, instead of sending 150 spiders at the same time to the site.
  5. dbarry
    dbarry Member
    114
    Houston Texas
    Danny,
    You need to put a files called robots.txt in the web root (ie. www.priuschat.com/robots.txt). Robots.txt is a simple text file that you upload to the root directory of your website. Spiders read this file first, and process it, before they crawl your site.
    # robots.txt for http://www.priuschat.com
    # the idea is to block off all access except what you want spiders to see
    User-agent: *
    Disallow: /_notes/
    Disallow: /bin/
    Disallow: /classifieds/
    Disallow: /faqs/
    Disallow: /forum/
    Disallow: /gallery/
    Disallow: /logs/
    Disallow: /memorabilia/
    Disallow: /resources/
    Disallow: /stats/
    Disallow: /Templates/
    Basically, I deny ALL the directories on my sites. I leave one or two html files that contain the keywords I want spiders to use to identify my site.
    Don
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    spiders may be inconvenient, but they help drive new blood to this site.
  7. jchu
    jchu New Member
    1,063
    Nampa, ID
    A curious thing that I've have found that one of you computer gurus might be able to answer is that at work running FF, PC is horribly slow ("1200 baud" like slow) IE runs at an acceptable load rate for the 100Mbps connection that I have.
    At home no problem with FF.
  8. dbarry
    dbarry Member
    114
    Houston Texas
    Clear the cache... FF is great (I use it), but I've noticed the cache access times aren't the best...
  9. dbarry
    dbarry Member
    114
    Houston Texas
    That's why you leave some html files with the keywords for the spiders to access. And you cen be very specific on the keywords by using META tags for the content... spiders will index their results on them. Example from one of my WWW sites:
    <META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=windows-8859-1">
    <META NAME="Description" CONTENT="Elec-Trak, Wheelhorse, and New Idea Electric Tractor resource site.">
    <META NAME="Keywords" CONTENT="elec-trak, wheelhorse, new idea, electric tractor, club, resources, manuals, parts, info, GE Elec-Trak, electrak, green tractors, enviromentally frendly, GE, E-15, E-20, E-12, E-12M, E-8, General Electric, B-145">
  10. jchu
    jchu New Member
    1,063
    Nampa, ID
    dbarry,
    Wish it was as simple as clearing the cache. Doesn't speed up PC on FF at the office. By the way it PC on FF loads slower with the 100Mbps at the office than it does with a "regular" 52k modem hookup at home. (same machine, a laptop)
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    gott be crappy office connection
