Foot pump for tires?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by clongwor, Jul 4, 2008.
  1. clongwor
    clongwor Junior Member
    68
    Acushnet, Mass.
    So I was looking to get an air compressor to help keep the inflation right. I noticed that some of the British forum members mention using a foot pump.
    When I googled these, most of the sites that come up are uk sites.
    Does anyone use a foot pump? How easy is it to use? Any recommendations on where to buy them, etc?
    Thanks!
  2. ski.dive
    ski.dive Active Member
    967
    245
    Hutchinson Island,FL. Mt. Snow,VT
  3. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    u can get an inexpensive 12 volt compressor to maintain tire pressure, why would you want a foot pump
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I have one hanging in my garage, it's been there about 25 years. Was good for pumping up bicycle tires for the kids.
    For the Prius I bought a combination air compressor/battery jumper.
  5. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Plain and simple - Forget it. The best ones don't last long in use, the seals go bad, the shaft bends, but more importantly, unless you're Walter Payton, you don't have the stamina to pump up a car tire. A tire takes a lot of air, even though it's at lower pressure than a bicycle tire.
    Get a 12 volt compressor. They are lightweight, easy to use, and come with emergency lighting. A combined compressor/jump starter/power pack is better as you can use it as a power supply, jump start cars, charge your cell phone or whatever.
  6. clongwor
    68
    Acushnet, Mass.
    Thanks for all the replies. Guess I'll get the compressor instead. I was hoping to avoid noise and also to not use electricity!
  7. Picasso Moon
    Picasso Moon Member
    117
    Phoenix, AZ
    If are going to go with a manual pump I would suggest investing in a good bicycle floor pump. I use my Silca floor pump on the bikes as well as the Prius. On the plus side it is a simple, proven design with a steel barrel that will last a lifetime, is easy to maintain/repair, requires no power (other than you), is virtually silent and requires a bit of manual labor to operate (about 10 strokes per 1 psi gain). On the down side, it is more expensive than the cheapo compressors, takes a bit of time if you tires are really low and requires a bit of manual labor to operate.
  8. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    I second that. I use a bike pump that has both schrader and presta connections (use the schrader). Works great to top off the pressure once every week. It can be a good workout too!
  9. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I wouldn't bother w/a foot pump. Long ago when I was little, that's what we used to inflate car tires. It took forever and yes they bend too.
    These days, I avoid even using the cigarette lighter based pumps I have and just go to a gas station near my work after work (and use their air hose). It takes WAY less time than my pump and is convenient enough.
  10. fcc
    fcc New Member
    245
    Nashua NH
    my two cents on this is to avoid the cheapest compressors out there.. a la walmart
    ones. i bought one because it fit in that little compartment in the back but now regret
    it after using it.
    1. it fails to mention on the box how darn how it gets and you should only use it for
    10 minutes at a time and then let it rest 30 minutes (cool off).
    2. it did not fill the tires quickly... in other words it took a multiple minutes just to raise
    the tire pressure a few notches.
    3. i could barely hold the thing it got so hot and was afraid to put it back in the compartment
    in the box because i thought it would start a fire :-|
    4. it sucks.
    Spend a few more dollars then i did and be happy!
  11. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I totally, totally disagree. I have a better "bicycle" floor pump (not the $8 cheapo model), and it's been great for 8 years so far. Takes 10 pumps per psi, generally I'm never more than 2 or 3 psi from where I want to be - that takes 30 seconds. Even with the Subaru when I had a leaky tire (bigger tires took 12 pumps/psi) and needed to put in 5 pounds every week, it was still no big deal (I went over a month before fixing the tire, and by then I needed to put air in every other day).
    It's better to get a minimal amount of exercise and at the same time avoid using fossil-fuel derived power. Much more convenient than going to a gas station, and much, much quieter than one of those little whiny cigarette-lighter-powered units, and definitely faster too.
    But I would recommend an upright floor pump instead of a foot pump.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    Michelin make an excelent 2 tube footpump.
    I over inflate my tyres on my way home, just 3 or 4 PSI over the 42/40 I like at a petrol station then adjust the pressure to 42/40 the next morning with a dial type gauge
  13. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    Husky has the air scout, they cost about 80 bucks though..not bad and pretty cheap for a oiless pump. Has 2 gal air, i used it for more then just pumping up my car tires, works double duty on dusty computers in a pinch every few weeks.
    is quite portable also and not very heavy, google Husky air Scout.
  14. SiTam
    SiTam New Member
    Los Angeles
    100% Agree with Nerfer, I use a floor pump, JoeBlow $30 at REI, work great with my 3 cars and 2 bicycles
  15. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    Hand pumps are better than foot pumps, which take longer to inflate. A hand pump is adequate for keeping tires at the desired inflation pressure. I've used one for years.
  16. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
  17. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Floor Bike Pump
    I've recently decided to go with a moderately decent floor bike pump as well for my car tires.
    My daughter, a biker, is giving me one of hers.
    She says that I can choose between her Avenir Air Source Pro or her Blackburn Air Tower 2.
