Stage 3a commute with no stop signs/lights?
Discussion in 'Gen 2 Prius Technical Discussion' started by hammy, Jul 5, 2008.
  1. hammy
    hammy Prius Addict
    53
    Massachusetts
    Would I benefit from pulling over and stopping my prius if I am in S3a with no stop signs or red lights then continuing with my commute to get the car into Stage 4?:confused:
  2. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Before I installed my EV switch, I frequently would do that when I could do so safely -- mainly parking lots or other pulloffs out of the travel lane.
  3. hammy
    hammy Prius Addict
    53
    Massachusetts
    Will my EV switch put me from S3a to S4 without the full stop?
  4. JimboK
    2,817
    190
    49
    Chesterfield, VA
    It doesn't put you into S4; it just allows you to shut the ICE off in S3a. Until the full stop idle check to allow the transition to S4, it will still exhibit S3a behavior without EV switch activation.
  5. hammy
    hammy Prius Addict
    53
    Massachusetts
    Thanks!
