Spare tire
Discussion in 'Gen 2 Prius Fuel Economy' started by djphill, Jul 7, 2008.
  1. djphill
    djphill Master of The World
    100
    los angeles
    I no it might be a little risky, but do you think it would be worth it to drive without a spare tire. The reduction in weight could help mpg, probably not by much but any increase that is at least over a couple mpg's is good.
  2. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    This thought has crossed my mind a few times. I think i may do it for local driving, and put it back in for longer trips seein as i didnt renew my AAA
  3. djphill
    100
    los angeles
    does anybody know how much of an impact this will have on mpg
  4. ceric
    ceric New Member
    1,114
    Fremont, CA
    Well some people did that for performance reason.
    Assuming that the spare is 20lb, you are looking at 2/3 of 1% reduction in weight,
    which is 0.4mpg assuming 60mpg as a base line and mpg proportional to weight with small delta. Carry a plug kit instead if you really want to get rid of it.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    In real terms that is a theoretical saving of 0.03 litres per 100km, that is every 100 miles you travel you will save a massive 0.048 litres or 1.62 fluid ounces or 10 teaspoons. or every 7,800 miles you will save a gallon of gas. All this just for being stuck, helpless on the side of the road for an hour or more.
    Or you can have a spare tyre in the back of the car in case you get a flat tyre.
  6. Tchou
    Tchou Member
    161
    that way, putting everyone on a diet will also have an impact on MPG...
  7. patsparks
    10,664
    567
    ... or you could avoid one hard brake application per day.
  8. bwilson4web
    16,253
    It would make getting in and out of the car much easier and ease working on the car.
  9. bac
    bac Active Member
    863
    52
    Pennsylvania
    It's not worth the risk for a return of almost nothing.
    ... Brad
  10. djphill
    100
    los angeles
    k thx i guess i'll keep it but does anybody know any other positive affects it could have except for getting a little extra space (that i don't need).
  11. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    You could probably get a couple of bucks for it on ebay.:D
  12. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Keep in mind:
    a plug kit will NOT work on sidewall punctures.
    Also, do not use a can of fix-a-flat, it'll destroy the TPMS sensor.
  13. Tchou
    Tchou Member
    161
    maybe you could remove all 5 wheels and the seats too, it will be much lighter...
  14. djphill
    100
    los angeles
    thanks that really helps
  15. sta bene
    sta bene Junior Member
    NE Pennsylvania
  16. patsparks
    10,664
    567
    One good thing, if you don't have a mobile phone it could lead to more exercise (while you walk to find a phone) therefore better personal fitness!
    Does that do it for you?
  17. Stefx
    Stefx Member
    336
    Use a bicycle once a week, you'll save more gas than by removing the spare.
  18. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    You guys are tough! anyway, Have you tried P&G, warp, or highway warp yet? Cruise Control doesnt help me very much on the rolling hills of the interstate.
  19. GatorJZ
    GatorJZ Member
    285
    17
  20. rfruth
    rfruth Member
    394
    Houston, Tx
    Is the spare (& jacking equipment) near the rear - if so its good to have a little more weight in the back (helps handling characteristics) + like others have said you paid for it and may come in handy.
