Engine no stop but no battary recharge
Discussion in 'Gen 2 Prius Technical Discussion' started by sszhangliu, Jul 8, 2008.
  1. sszhangliu
    sszhangliu New Member
    China
    There is something wrong with my II Pruis. When I wait for the traffic light, the engine does not stop (99.9 L/100km) but the screen shows that no battary recharging happens (no any arrows on the screen). It happens sometimes but not always. The engine will not stop automatically unless I power my car off, then power on again. Then everything is OK. The result is higher consumption from 4.5 L/100km to 4.7. I am sure it has nothing to do with the A/C. It happens when A/C off.
    My Pruis was bought in October 2006 and now it has already run just over 50,000 km. I am worrying I will have to pay to repair it because it is just out of the "50K km or 2-year" guarantee.
    If it happens in winter, I can understand, but now it is the warmest season in a year, is it still normal? Please see these pictures. The first one is when it happens, and the second one is after I restart my car right away.
    Who can tell me what happens to my car. Thanks in advance.
  2. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Does this happen after 15 minutes of driving?
    Do you have a scangauge or other utility to monitor your coolant temp?
    How long does the engine stay idling? Do you have the A/C set to defrost or heat?
  3. Patrick Wong
    18,200
    6,500
    Maybe the hybrid vehicle ECU thinks that the traction battery is fully charged (note that seven green bars appear in your photo), so it is spinning the engine to use up the battery charge.
    • How frequently does this happen?
    • Next time this happens, let the engine continue to spin, and see how long it takes for the engine to turn off.
    • When the engine does turn off, what is the traction battery SOC as displayed on the MFD?
    If you don't have any warning lights appear, there will be no error codes logged and it is unlikely that your dealer will be able to take any action.
    It is unfortunate that your warranty coverage is only for two years or 50K km.
    Good luck.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    I think if you have been on a long gentle down hill run with the engine off or, looking at the state of charge you are at the bottom of a hill and the engine is cold. It needs to fire up to heat itself and the cat converter.
  5. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Mine does the same thing intermittently and infrequently. I didn't think anything was wrong, but I'll pay more attention to it and report back.
  6. sszhangliu
    China
    Thanks for concern. Thanks! Thanks! Thanks!
    It happens right after every time I drive.
    No any utilities to monitor the coolant temp.
    The engine stay idling without stop (I did wait for its stop but no any hope for very long long time), unless I power my car off then repower it on.
    I am 100% sure I do not set the A/C to defrost or heat. It is summer now here, the warmest season in the year.
  7. sszhangliu
    China
  8. sszhangliu
    China
    Thanks for concern!
    No any hill in my city. Only very flat road. Now it is the warmest season and I do not think the engine need so long time to warm up.
  9. Patrick Wong
    18,200
    6,500
    Hmm, I have no idea why your engine doesn't turn off. However, if your fuel consumption was 4.5L/100 km and is now 4.7L/100 km, this is still quite outstanding. This is the equivalent of 52 miles/US gallon moving down to 50 miles/US gallon, which most US owners would find quite acceptable...
    Unless you have any warning lights appear, I doubt that your dealer will be able to take action to help.
  10. Bob64
    1,540
    93
    Virginia
    Is there anything red flashing on the energy monitor screen? (perhaps your in inspection mode?)
    Also, try using the A/C controls and set to auto and make sure that defrost and heat is not on.
  11. sszhangliu
    China
    Thanks Patrick and Bob64.
    The thing turns worse these days. Now it happens everyday and every time I drive. The engine do not turn off. No any warning light appears.
    I would like to describe the condition more. I drive for 30 minutes from home to work in the morning for about 30km without any traffic light and almost no traff jam. And after work I drive back home for about 1 hour with some traff jam and 2-3 traffic lights. The fuel consumption is still acceptable because when the car is running the engine and the battary run well. And the engine does not turn off only when I brake the car for the traffic light. Normally it takes me 1-2 minutes waiting for the light turns.
    I have already go to see the after-sale people and the guy used a computer to test my car for half a day. Then the second day he called and said he did see some irregular data but he could not tell what happens. He sent the data to Japan and wait for their reply.
  12. Patrick Wong
    18,200
    6,500
    Thanks for the update. If any DTC (diagnostic trouble codes) were logged by the various ECUs (electronic control units), please identify them. We can help interpret what the codes mean.
    I would be very interested to know what the "irregular" data is.
  13. RM007FC
    RM007FC New Member
    Georgia, Tbilisi
    Today the same issue happened to my Gen 2 2006 Prius. Engine works continuously and not shuts down even when car is stopped and parked. Today i changed oxygen sensor and then car was reset by computer, could these cause the problem? These topic is old but if someone knows how to solve the problem please help.
