headlight delay off
Discussion in 'Newbie Forum' started by browercreed, Jul 9, 2008.
  1. browercreed
    browercreed New Member
    56
    Arkansas
    Couldn't find the answer to this on here nor in the manual, but is there a way to
    have the headlights delay in going off when you get out of the car? I'm so used
    to being able to get out and have the lights stay on until I can get to a light switch
    or into a building. Is this not possible on the prius?
  2. Joekc
    Joekc Member
    265
    It's not possible. Sorry.
  3. browercreed
    56
    Arkansas
    Didn't think so - guess you can't have everything.
  4. qcaudill
    qcaudill New Member
    Nebraska
    Our Prius does not have automatic lights, but if you leave them turned on (manual on setting) they will go off in about a minute. The only thing is that you get the audible notice that you've left the lights on and they will be on during the day as well.
    Q
  5. qbee42
    3,077
    I haven't seen this feature - are you sure yours work this way? Typically the headlights remain on until the driver's door is opened. There are some exceptions, such as turning on the headlights after the driver's door has been opened. so you always want to check and make sure they are out.
  6. Joekc
    Joekc Member
    265
    If you don't turn them off, the lights go off when you open the door. Turning off after one minute? Your car is smarter than mine. :confused:
  7. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    If you want the headlights to stay on, roll down the window and exit Dukes of Hazard-style!
    :p:p:p
