air intake pocket
Discussion in 'Gen 2 Prius Technical Discussion' started by Flying White Dutchman, Jul 11, 2008.
  1. Flying White Dutchman
    4,376
    314
    When i removed my front bumper i noticed a little plastic box on the front passenger side behind the front bumper
    its not the coolant storage thing you have in the US but its connected to the air intake?
    anyone now what this is? and what i's for?
  2. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    Now, that's what I call hidden storage!
  3. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    If it's what I think it is, it's an intake resonator. Many cars have them. Not 100% sure on the theory but here's what I remember:
    Air intake is not smooth, it tends to be rapid pulses because of the action of the intake valves. The intake can be tuned to maximize certain frequencies of the pulses to help with air flow at certain speeds by adding air chambers of specific sizes, thereby improving power at specific RPMs. It's usually done to smooth out power curves at specific RPMs. It's the other side of adding a tuned exhaust.
    Someone correct me if I'm wrong please. (they always do). :rolleyes:
  4. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The engine gulps air in pulses. The box is designed to provide one pulse without causing much of a vacuum. Yes, it's a resonance chamber. It dampens the pulses by the above mechanism so you don't hear them (much).
    In the Prius the box also takes some of the air forced back out of the intake due to the "Atkinson cycle" (intake valves are held open during part of the compression cycle).
    But the short answer is narf is correct, it's an intake resonator, there to smooth air flow to reduce noise and smooth out air flow.
  5. Flying White Dutchman
    4,376
    314
    a ok
    nice toyota!!
  6. a_gray_prius
    2,927
    783
    IL
    Hey - my Prius has a CAI! :D
  7. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Most Toyotas have some form of resonator built into the intake tubing. It also has another nice effect, if you should accidently hit deep water (an unexpectedly deep puddle) the resulting splash into the air intake can allow water to be sucked into the engine. The resonator box allows for the greater volume of water to be pulled down by gravity and help reduce the chances of hydrolocking the engine. Small amounts of water can be handled, but a large gulp can enter the combustion chamber and cause massive failure.
  8. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    wow, those Jeffries tubes are getting smaller and smaller! :fear:
  9. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    so... what would happen if you were to add a snorkel... hehe... you can get as high as.. what?.. the plugs? the bottom of the fuse box?
  10. David Beale
    5,963
    1,990
    Edmonton Alberta
    A snorkel would change the tuning of the intake system. I doubt that it's critical, so it probably wouldn't hurt. It would certainly help those who drive into "ponds" on the road. ;)
  11. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    its the intake resonator, i removed mine on both priuses, it just increased the noise from the intake not by much.
  12. Flying White Dutchman
    4,376
    314
    and wy did you remove it?
  13. richard schumacher
    7,686
    1,068
    United States
    He expected it would improve power and/or fuel efficiency. But one fiddles with resonant systems at one's peril: if the remaining air intake structure resonates in the wrong way it can reduce power and/or fuel economy. Impedance is not the same thing as resistance.
  14. MR.K
    MR.K Junior Member
    86
    Idaho
    My white resonate bottle/tank was crushed in a wreck ...so do I really need one? Would a gallon milk jug work or something like that ? Statultra did you find any improvements by leaving it off??
  15. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    hearing about all the incidents, maybe toyota decided to give a little access port for all the mice to be nice to them
  16. qbee42
    3,081
    No. It needs to be exactly the same size and shape.
  17. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    As long as you have the connection to it sealed off you probably don't need it.
    When doing intake mods to other Japanese cars I've removed resonator boxes (actually disconnected them, but left them in place.) One car used MAP sensing the other was a mass air flow sensor. Both used air horns with conical K&N air filters. Neither had any problems and both produced a lot more power than before (timed 0-60 runs), but this was because of the air horn/filter, not the lack of resonator. The one negative is that the Accord was noisier, particularly when the VTEC kicked in. The 240 sounded much better (throatier but in a positive way) without the resonator. Gas mileage was unaffected...except for the tendency of a certain driver (me :redface:) to use the new power available frequently for harder launches.
    It would be interesting to do a test on the Prius making a fixed distance highway run (in both directions) on cruise control with/without the resonator measuring both mileage recorded and time elapsed--the latter as a cross check.
  18. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Hmmm. That looks interesting. Could we add a little electric fan to that box and pressurise the intake air?
  19. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    It would take a little more than a "little electric fan" to pressurize the intake air. You have to make the pressure higher than what the engine does, not just over what it is when the engine is not running.
  20. Patrick Wong
    18,210
    6,522
    Well, the gasoline engine certainly will function without that part. If you want to do a first-class restoration like jelloslug, then you will replace it. If you are working to a lower standard, then leave it out.
