acc mode?
Discussion in 'Gen 2 Prius Main Forum' started by senectus, Mar 2, 2005.
  1. senectus
    senectus New Member
    111
    Perth, Western Australia
    First the back story..:p
    Many many moons ago when i owned a Valiant charger (large heavy inline 6 ) I was told that you should not leave a car in ACC mode for too long, because you run the risk of the coils overheating and even melting..
    Now sometimes I can wait for up to an hour in the car park while i wait for my partner to finish work.
    While I'm waiting I like to listen to the radio.. and to do that I need to put the Prius in ACC mode.
    Is this old wives tale still relevant?
    Or can I sit in the car for many an hour or more in ACC mode while i wait?
    Thanks.
  2. rick57
    rick57 Member
    572
    Circleville, Ohio
    I did a test in another post,about leaving the Prius in the ACC postion(green light on). I had a new one last night I put in this state with the drivers door open and the radio on. All dome lights were off. After approximately 1 hour the system shut down. I believe it says that in your owners manual also.So if your lunch is for 1 hour you should be ok. If longer,maybe hum to the music in your head when it shuts down :lol:
  3. senectus
    senectus New Member
    111
    Thanks Rick57 :)
    So it will shut it off on it's own..? hmmm.. I wonder if thats to stop it from draining the battery or another reason..
  4. KTPhil
    KTPhil Active Member
    1,379
    Most conventional ignition (coil/points) cars added a ballast resistor for this reason. Not sure if the Valiant/Dart slant six had it. No modern electronic ignition car has the problem.
  5. xevious
    xevious New Member
    187
    Oregon
    The only thing that you should worry about is draining the diminuative 12v battery.
  6. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(senectus\";p=\"68800)</div>
    <div class='quotetop'>QUOTE(xevious\";p=\"68859)</div>
    Yes I would agree it probably is to save the 12 volt battery. But I would think it could last longer then 1 hour. Maybe Toyota picked 1 hour just in case you had left it on in the garage :roll:
  7. Tideland Prius
    16,552
    Well the radio won't suck up much juice unless you've blasted it to Vol 62 (or is 63?) and added a thumping wooder :p. My scenerio was the rear dome light on, all doors except hatch locked and the radio on in ACC mode. So I guess regardless of what's on, it'll shut off after an hour
  8. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(Tideland Prius\";p=\"68918)</div>
    With your test also, I would believe that maybe it is on some kind of timer,which starts when you put it in ACC mode. This seems to make sense :roll:
  9. Tideland Prius
    16,552
    mmhmm... so judging from mine and yours, can we conclude that it's approximately one hour (until someone can prove otherwise)?
  10. rick57
    rick57 Member
    572
    Circleville, Ohio
    <div class='quotetop'>QUOTE(Tideland Prius\";p=\"68969)</div>
    Yes I would say so. Unless someone proves us wrong :)
  11. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    ACC mode in most cars does not power the engine electronics, so no harm can come to it.
    I have heard that about being in Ig mode without the engine starting. For the Prius, being a hybrid, the HV won't power anything it shouldn't.
    Now, I wonder if the same shutdown occurs in Ig-On mode. There's a whole lot more there that can drain the battery than ACC.
  12. jeepien
    jeepien Member
    165
    New Jersey
    The warning wasn't even correct for the original Valiant.
    It once was the case that a car could suffer if left in the ON position without the motor running, but it was never the case that leaving it in the ACC position could harm the ignition coil. It's not energized in the ACC position, not even on a vintage Valiant.
  13. dgstan
    dgstan Member
    159
    OC
    Here some related info that might be of interest.
    Late last night, I decided to change all the CDs in the 6 disc changer. While I was doing it, I turned on the passenger's overhead light.
    Needless to say, I forgot to turn it off. Imagine my horror upon seeing it on this morning when I went into the garage. It does not turn off automatically. Once you turn it on, it stays on (in this case, probably 10 hours).
    With thoughts of having to ask my neighbor to jumpstart my two week old car, I cautiously powered her up. No problem, the 12V battery can light the cabin all night without any ill effects.
    DGStan
  14. victor
    victor New Member
    414
    Gilching Bavaria Germany, &amp; Drapanos, Crete, G
    Are you sure it was on????
    I ask as the light comes on automatically as you approach the car, if you have SKS.
  15. Tideland Prius
    16,552
    I've had a discussion with DanMan32 about dome and maplights before. We've concluded that they don't automatically turn off.
  16. DanMan32
    3,799
    27
    Tampa Bay, FL
    I've done that a few times too, fortunately without any ill effects.
    And yes, only the dome lights if left in DOOR position will turn off automatically. In ON position, the body ECU's control is bypassed.
