help: switching the door unlock function
Discussion in 'Gen 2 Prius Main Forum' started by Palmetto, Jul 12, 2008.
  1. Palmetto
    Palmetto Junior Member
    88
    West Michigan
    Misson: Open all doors with 1 press of keyfob.
    I've pressed the panic and lock buttons simultaneously until I hear two sets of two beeps. It wants to stay on the default setting of unlocking the drivers door only. I am doing something wrong, but am stuck.
    Can someone help me out here?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Are you saying that the settings are not changing even when you hear the beeps?
  3. Palmetto
    88
    West Michigan
    Yes! That's exactly what is happening.
    I've tried sitting in the car and performing the same function. No diff.
    I know I'm close....anybody, anybody?
  4. Palmetto
    88
    West Michigan
    bump
    :preggers:
  5. efusco
    19,891
    1,196
    Nixa, MO
    It's been 4 3/4 years since I did this...there's surely someone who's done it more recently than that....
    I guess I'd suggest you continue holding the buttons down even after the beep...seems they have to be held until you hear the door locks cycle... I may be off base....it's been a long time.
  6. beckaloulou
    beckaloulou New Member
    51
    Zionsville,IN
    I am going to try and change mine tonight so if no one else gets back to you give me tonight and I will tell you how I did mine (well hopefully cross your fingers :) I need to read my manual a bit I only picked mine up a few hours ago!!!!!!!!!!!!!!!!!!!!)
  7. Palmetto
    88
    West Michigan
    Congratulations Becky!!! :horn:
    I think I have done it, but honestly, I was hoping for a different outcome. When I put my hand in the drivers door handle, or open the trunk, all the doors unlock.
    What I'm hoping to do is use the remote and with one push, unlock all 4 doors. Maybe this is as close as it gets.
    Anyway, let me know how it goes for you. Welcome to the wonderful world of Prius Land!!!
    Jeff
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It requires two button press' on the remote to unlock all the doors (and to keep them unlocked you have to open one within 30 sec). This is not settable.
    The "hold the two remote buttons down" only changes the way the car reacts when you reach for a door (SKS).
    In the default setting if you reach for the drivers door only that door unlocks. If you reach for the front passenger door or the hatch all doors unlock. They will not stay unlocked unless you actually open a door.
    In the alternate setting all the doors unlock if you reach for either of the three sensors (drivers door, front passenger door, or hatch). Again, they will not stay unlocked unless you open one of them.
  9. Palmetto
    88
    West Michigan
    Hi David,
    You have confirmed my conclusion.
    When I leave work I always put my bag on the floor behind the drivers seat, close the rear door, open the front door get in a drive off.
    In the default setting, the remote pressed twice opened all doors. I was looking for a setting to press the unlock button once and open all the doors. You're saying it isn't an option and I suspected this.
    In the modified setting, the best I can do is put my hand in the drivers door handle to open all the doors, toss in my bag in back, then open the front, get in and drive off (all without using the keyfob).
    I can live with that. I'm so happy with this car, I consider my programming wish small potatoes.
