car washing question - drying problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius_Gnome, Jul 12, 2008.
  1. Prius_Gnome
    Prius_Gnome Member
    95
    36
    Long Island, NY
    After drying the washed Prius, I go ahead and wring out the water and I can feel that it's soapy. Is that supposed to happen?
    I thought I did everything right: wash the car with a microfiber wash mitt and then rinse it. Am I supposed to "agitate" while rinsing (i.e. like I would do if I was washing myself)?
    And another thing: do your drying towels completely dry the car? Mine seemed to leave some "streaks" which evaporated away.
    Any suggestions would be appreciated.
  2. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    I'm curious what you are using as soap?
    If you have sufficiently rinsed off the car after washing you should not experience any left over residue from the soap unless you are using some type of heavy dish detergent (which is really bad for the finish, unless you are doing a full detail and claying).
    I suggest you get a simple car wash soap at your local store and go easy when mixing it......use 3/4's of whatever amount they recommend.
    Also, if possible, try to avoid washing in direct sunlight!
    keep it simple....you'll b fine!
  3. Prius_Gnome
    Prius_Gnome Member
    95
    36
    Long Island, NY
    thanks for replying, bshef,
    I was using Turtle Wax ICE Car Wash. It says to use 1 oz for every gallon and since it didn't come with a measuring cap, I just poured in what looked like 2/64 of the bottle (64oz) and filled up my 10 quart bucket with 2 gallons of water. Maybe I overdid it. Next time, I'll try not to be lazy and pour from the big 64oz bottle to a smaller container so I can more easily pour into my wash bucket.
    I also just remembered that I used those drying towels last at a Texas Car Wash (a place where you put tokens into a machine and you get a certain time limit to shoot 1. soap, 2. water, or 3. wax with their spray gun) and didn't have a chance to properly "clean" them. The Texas Car Wash had a system to recycle the water but it must have been faulty because the rinse water was soapy. Needless to say, my drying towels were soaking up soapy water from my Prius after the wash which did not make for a happy ride home. :mad:
    So anyone with that "streaking" thing while drying?
  4. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    i dont think any drying towel on the market is going to remove 100% of the water, there is always a little left that just evaporates away it seems. i suppose you get 99% dry using multiple towels.
    i have had good luck with multiple microfiber towels for drying. i tried chamois but
    its requires a lot of wringing out
    the mr clean autodry seems to work crappy for black cars
    there are some new self drying car wash soaps on the market, i havent tried one yet
    (simoniz and rain-x)
    i wanna use a leaf blower, im betting the 200 ++ mph wind coming out of it
    would just totally blow all the water off the car in 10 seconds
    some reviews on the simoniz brand say the quality of the self dry has to do a lot with whether or not your
    water supply is hard water or soft water..
    i wonder if a water softner would eliminate all water spotting but that would be overkill?
    some people have reported that it is a lot cheaper in the long run to use one of those de-ionizing inline water filters used for
    mobile homes then the mr clean autodry filters
  5. GatorJZ
    GatorJZ Member
    285
    17
    Your drying towels (hopefully you're using waffle weave) absorbed that spray wax crap. Wash them alone in warm water with either MicroRestore or Charlies Soap and dry them on low heat. NO fabric softener or dryer sheets. You may have to wash them more than once to remove that junk and some vinegar in the final rinse might be a good idea.
  6. Patrick Wong
    18,210
    6,511
    Why not use a clean chamois skin to dry your car?
  7. patsparks
    10,664
    567
    Adelaide South Australia
    I use a very large artificial chamois which give a good dry finish. Nothing will get all water off.
    If you use a "wash and wax" type car wash the soapy feel may be the wax.
    When drying a car do the glass and bright parts first then everything else. A big chamois should dry the whole car without needing to be wrung out. You may want to wring it out half way through. If you car has enough wax on the water will bead and most will run off on its own.
    Dry wheels and tyres with a separate smaller chamois.
    Always rinse out your chamois with clean water when you are finished and if it touches the ground.
  8. rigormortis
    1,340
    26
    san jose, ca
    chamois just seemed to be a pain to work with, for me using like 4 or more
    microfiber towels works a lot faster, and you dont have to pre dampen
    and wring out microfiber towels like you do with chamois
    we should also open up the discussion to those silly infomercial towels
    too.
    1) bill mays's zorbeez is reviewed to be total crap, its supposed to be no better then felt that you buy at an art store
    2) shamwow!, if you watch the commercial in slow motion thier is still some soda spilled under thier carpet that the product did not pick up
  9. Scruge
    Scruge New Member
    97
    TX
    This may sound odd, but I wash car in rain.. very easy and takes 15 minutes.
    1. I let car get wet from rain.
    2. I have a very dense soft brush on long handle like car wash places uses to pretreat areas. I then brush (no soap) down the car and rinse with hose. 10-15 minutes tops
    3. I let sit in rain for awhile longer to allow rain to rinse tap water away.
    4. I next put car back into garage. The car will dry spotless in garage. You can speed up drying by blowing with leaf blower before returning to garage.
  10. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Getting a soft water loop will help. When i lived in Queen Creek, Arizona we added it onto the house from the builder. I would wash my truck outside, move it into the garage wet and the heat inside hte garage dried it. Then went out and waxed. It was nice, and even sometimes when i had to leave it outside, with the sun beating down on it the water did not leave marks jsut evaporated off.
  11. blamy
    blamy Member
    380
    Central Florida
    Excellent idea as the rainwater does not have all the minerals that tap water has so it dries without spots. I wash in the rain also but I still wipe the car dry after I put it back under the carport. P.S.I really like your definition of political correctness! You hit the nail on the head with that one.
  12. richard schumacher
    7,664
    1,046
    United States
    Mr. Clean Autodry needs no toweling.
  13. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I use a capfull of car shampoo in the wash bucket, and a large bucket of cold water to rinse the dirt off the washcloth before it goes back in the soapy warm water. Frequent rinsing is necessary, more so if it's really hot, though I try to work in the shade or at least the cool of the day. Maybe the local soft water helps, but a chamois does a fine job of drying, with no spots or streaks.
  14. rigormortis
    1,340
    26
    san jose, ca
    i have burned through 2 mr clean auto dry filters and the results were poor. it did
    reduce spotting but it did not eliminate it. i got better results on my moms white
    buick tho.
    if u are really detailed about using the filtered water trying to get the non filtered
    water off the car, you can burn through the mr clean filter really quick
    its just not worth it, an inline rv filter would cost about 50-60 and it would last
    a lot longer then "about 10 washes"
    keep in mind i am just reporting my expierence with black paint
  15. GatorJZ
    GatorJZ Member
    285
    17
    Do yourself a favor and try one (actually, buy two) of the models of waffle weave drying towels I mentioned above. If you spend any time at all at Autopia, you will quickly come to two conclusions. First, these people are absolutely anally retentive about car care. Second, you would be very hard pressed to find anyone there who still uses a chamois. There is a reason for that, it is old "technology" that presents a far greater chance of damaging your finish. If it was better, they would use it, if it was as good or nearly as good, there would be a "chamois camp" and a "waffle weave" camp. There is not a chamois camp" because the WW is the superior way to dry your vehicle.
  16. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I use old, laundered white cotton towels to dry Rudy.
    I also use Zaino "Show Car Wash", only at half-strength, to wash him.
    We use microfiber cloths to clean, a hose to rinse.
    When the Zaino is all gone, I'll switch to Dr. Bronner's soap to wash him, as it is biodegradable.
