seeing GREEN BARS more often, as the car ages
Discussion in 'Gen 2 Prius Main Forum' started by john1701a, Jun 30, 2008.
  1. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    Seeing 7 bars (GREEN) has become more and more frequent as my Prius ages. Years ago, warm-weather driving could go for days between each occurence. But now that the odometer has exceeded 100,000 miles, it happens at least once per drive.
    My guess is that nothing has changed with the Multi-Display or the measurement criteria itself, that the cause is simply due to vehicle components loosening up with age... allowing for more regeneration now.
    Anywho, my question for y'all is who else has seen this aging behavior?
  2. qbee42
    3,079
    It's more likely that it is a function of battery aging. As your battery gets older, the capacity is reduced.
  3. john1701a
    12,820
    5,305
    58
    Then the question would be about how capacity being displayed. But knowing why is not the intent of this thread.
    I just want to know if others have witnessed the same change.
  4. qbee42
    3,079
    The MFD doesn't display battery capacity, only SOC. The SOC rises and falls more quickly with reduced capacity.
    I will leave it to others to say whether they have experienced the same thing, but tests run by a national laboratory showed a significant drop in battery capacity with age and use. They got their test batteries down to about half capacity over the life of the test, but with significantly more miles than yours.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i noticed mine falls and fills a little quicker than it used to....
    On a decent commute.. i can get my car into the green several times.
    It drains a lot faster with the A/C blasting than it used to....
  6. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    I will say that as batteries are exercised, their capacity can grow... is true for EV's.. until you get to the point that they start to wear out, but at 100k, you shouldn't be anywhere near that with a Prius battery pack.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I have had my Prius since March, and have put just under 3,000 miles on her. I see this condition everyday. I live in the Foothills of Los Angeles and even though my commute is only 11 miles each way, the TO WORK commutes is approx 70% downhill. I get GREAT 99.9 mileage for that 70% and about 46 mph or so on the remaining 30%.. When I arrive at work the battery is always FULL GREEN.
    HOWEVER .. That being said ...
    The trip home is 70% uphill, and my uphill milage is around 36 or so ...but when I park at home I am usually down to 2 or 3 blue bars.
    If I decide to run uphill to the food zone in my neighborhood I will drop into the 2 purple zone! Of course after I get my dinner I roll downhill, apply some brake and back to 2/3 blue bars!
    Time will tell if this charge and discharge cycle is good or bad.
    I find when using rechargeable batteries, that a full charge/discharge cycle usually gives a good life to the battery.
    HOPE SO!!!
    73 de Pat KK6PD
  8. kimgh
    kimgh Member
    297
    San Jose, CA
    My Prius is 2 years old and has 25K +; I've recently noticed green bars more often. I'm nowhere close to the OP's miles, so I don't know whether it's the same phenomenon or not.
  9. Godiva
    Godiva AmeriKan Citizen
    10,339
    Could it be you're just driving better?
  10. john1701a
    12,820
    5,305
    58
    Now with 160,000 miles and almost 8 years experience racked up, it's hard to remember the priustoric times.
  11. Patrick Wong
    18,210
    6,511
    Hi Pat,
    I live at 1,100 ft elevation in south OC and commute to sealevel in Irvine, 25 miles one-way. I have owned three Toyota hybrids and two traction batteries have failed (under warranty) so far. The 2001 battery failed at ~61K miles while the 2006 HiHy battery failed at ~25K miles.
    Hence my personal experience is that the charge/discharge cycle associated with climbing and descending daily is not healthy for the traction battery.
  12. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    I think you should take some of your own advice and "just drive it". The battery will take care of itself.
  13. kimgh
    kimgh Member
    297
    San Jose, CA
    I like to think so!
  14. john1701a
    12,820
    5,305
    58
    Discussions where none have gone before is something I have much experience with. After all, I played a major role in associating the term "stealth" with Prius. So, introducing this topic was too good to resist.
    As for my driving, little has changed over the years. Brisk acceleration is my style. I pull away from stoplights much faster than average... enjoying that initial surge of electricity.
  15. sleonardelli
    sleonardelli Junior Member
    141
    Ruskin Fl
    I have almost 9000 miles on my 08. Today I noticed nearly full green for over 20 minutes (driving 65 mph). Is this normal?
  16. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Priustoric times! I love it!
    Forget about coming up with "stealth" -- you've got it all with "Priustoric," John!:horn:
  17. samiam
    samiam Antipodean Prius Poster
    2,442
    29
    Enn Zed
    In a word, yes.
    Almost daily. I notice it does not visit the purple end of the spectrum as often, but this could be because I (semi-intentionally) adjust my driving to send more voltage to the batt (at the expense of km/l) as it descends towards purple.
  18. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I'm only at 77k John and haven't noticed any more frequent green or pink...still seems to hover at 60-61% SOC during highway driving and closer to 50-55% SOC during my P&G commute.
    In short though I'd tend to agree with Tom's assessment...reduced capacity could lead to a greater relative delta of the SOC....that said I'd expect an equal amount of time with a somewhat lower SOC as well as the green higher SOC.
  19. Ichiro
    Ichiro Member
    335
    SF
    So, does reduced battery capacity affect gas mileage very negatively?
  20. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i have to say, i suspect something is amiss if your SOC has really changed that much. sounds like your batteries are on the way out. that is how batteries die... they become unreliable, stop acting predictably, etc.... its kinda like an incandescent...when it get real bright just before it dies...
    hope that is not the case for you but...
