Prius Won't Start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jsheldahl, Jul 20, 2008.
  1. jsheldahl
    jsheldahl New Member
    Iowa
    Just tried to start my new 2008 Prius, 16,000 miles, and got the Problem icon and the car stopped. Now, the car won't start, but when I do attempt, the display shows this icon:
    http://mahanon.net/photos/a38f22815ac3.jpg
    I got the car used, and a manual is on the way, but I have no idea what this icon means. Can someone explain? I'll be calling Toyota on Monday.
    Thanks!
    Julian
    Desmond Amen likes this.
  2. richard schumacher
    7,664
    1,043
    United States
    That's the generic something-is-bad icon. Are there no other warnings or icons? What does the fuel gauge show?
    Did you buy it from a Toyota dealer, or pay a Toyota dealer to thoroughly check it over before buying? [D'ohh!! Nevermind, I see now that you bought it new.]
  3. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi js...,
    Assuming (dangerous) you are new to the car here are the things to check. Are all the doors fully closed? The rear hatch has a tendency when the support struts are new to not close all the way. Really push it down when you close it. And the most common newby "can't get the car to start" issue is pushing down on the brake pedal firmly (again with all the doors closed) when you press the start button.
    Check those two things out, and see what happens.
  4. jsheldahl
    Iowa
    I got the car from a different dealer, actually, and hadn't had it checked over yet, because it was so new and I figured I could get it all looked at with the warranty at my first oil change. Maybe this wasn't the best decision, but it's what I did decide and will have to live with.
    The gas gauge has two pips left on it, and it's ready to go down to 1 pip any time. The current tank has about 450 miles on it, so I'm getting ready for a refill. I've only driven the car about 1500 miles.
    Funny thing, I was just putting the plates on this afternoon and I had opened the hatchback for something, I don't remember what, and I thought that was surely the answer. Just tried it and made sure that the door was closed really well, but that didn't turn out to be it.
    There aren't really any other warning lights on that I can tell. The brake light is on, the warning icon, ABS icon, and check engine light. In other words, the car is dying somewhere in the boot up process, but it almost looks like it hasn't diagnosed the problem yet.
    Any other ideas? I really appreciate these! I'm planning to call my Toyota dealer on Monday and have the car towed there to be looked at, since I can't really move the thing. Still, it would be AWESOME if I could get out of that whole mess with a simple fix. Alas, life doesn't always work that way. :(
    Thanks again!
  5. dbuchanan
    dbuchanan New Member
    Greensboro NC
    You need to have the key inside of the car!!
    This also stumpted me the first time I saw it.
  6. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I have seen that icon when Im in my wifes car and she walks away with the key while I stay in the car. It's almost like it misses her! Maybe it just misses the key?!
  7. jsheldahl
    Iowa
    Actually, I don't have the SKS (which I totally should have mentioned), so I have to insert the key into the ignition to start the car. Thanks for the idea, though!!!
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    The car will start and run fine with the hatch open it just puts up the standard door is ajar red nag and pushing down on the brake pedal firmly when you push the start button is exactly how you should start the car.
  9. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Without turning the the car on just put the headlights on. Are they bright?
    I bet not.
    My guess is you left a vanity light on or a door ajar all night and it killed the boot battery in the trunk.
    NOTE!!!!!!
    If dead boot battery be extremely careful I repeat extremely careful if you jump start it. Use the front jump points under the hood and if you reverse the polarity on the jump leads you will severely damage the car.Look in the owners manual on the jump points. The positive is RED. If your not an ace at jump starting a car do not do it on this one.Good luck. I'm sure its something stupid. Don't make it worse.
  10. jsheldahl
    Iowa
    I'll definitely give that a try! It would make sense that this would be a simple, stupid thing. Since I'm not a pro at jump-starting, I'll call Toyota in the morning and suggest that this is the problem. Without a manual (I got it used, and it's been ordered), I probably shouldn't attempt it myself or get someone inexperienced with the Prius to try it, either. I really appreciate the suggestion, and I can't wait to check as soon as it gets dark out (I'm not at home anyway).
    I'm definitely going to read up on how to jump start this baby, just in case this ever does happen again. I'll let everyone know if that's the case or not. Not because if it goes to the dealership they can't figure it out, but if you're anything like me, you'd want to know the end of the story.
    Thanks again!
    Julian
  11. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I've never drained my 12V so maybe I'm off base here but:
    If the 12V has enough voltage to start up the MFD, I would think it would have enough to open the relays to the traction battery. That is the one that starts the electric motor which, in turn, starts the gas engine.
    Also, I have left my dome light on over night several times, always in the winter when the cold will decrease the battery's power. Never had a problem in the morning. So, IF this did happen and that was all it took to kill the 12V, I think the 12V has some issues.
  12. Patrick Wong
    18,200
    6,492
    Hi Julian,
    I suggest you consider that your car might be out of gas. If it is easy for you to add a gallon or two, then you can quickly rule out that possibility.
    As Ed suggested, it would be interesting to see whether the headlights are at full brilliance, which is an indication that the battery is producing adequate voltage (assuming you don't have access to a digital voltmeter).
    The icon in your photo is the hybrid vehicle warning icon, and when it appears this usually means that there is a problem with the hybrid drivetrain.
  13. jsheldahl
    Iowa
    I suppose that's a possibility, which is kind of scary since there are two pips on the meter. I know that I've read that the gas meter can be off, but that seems kind of far to be off. Obviously, I'm going to try this. I'll need to put gas in the car anyway. :)
    I'm confused about the icon, though. If it indicates a problem with the hybrid drivetrain, how would that be related to the gas?
    I'm still not at home, since Sundays aren't really a day that I can get any help anyway. I'm going to try all of this here in about an hour.
    Thanks again!!!
  14. richard schumacher
    7,664
    1,043
    United States
    If you're lucky it will be merely a half-dead 12V battery. Funny things happen when that gets low enough. But for pity's sake don't let some random tow truck guy try to jump it; if the polarity is reversed you're hosed, and the warranty will be hosed also. Have a Toyota dealer send someone or get it towed.
  15. jsheldahl
    Iowa
    Yeah, that's the plan. I tried gas and checked the lights which are BRIGHT, and the car still didn't start. I'll call Toyota at 7am and tell them that my Prius won't start and that I need a tow, shuttle, and service. Thanks, everyone for coming to my rescue with ideas on this!
    Julian
  16. Patrick Wong
    18,200
    6,492
    Hi Julian,
    Sorry that the simple checks proved to be unproductive. Please let us know the dealer's diagnosis, any DTC logged, and the resolution to your problem.
  17. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Forgot to ask. What was it like when you put it to bed before this? No warning lights?
    Thats too bad. You must have a rare infant mortality failure. Probably the inverter which we have seen a very few fail when new.
    Patrick Wong: Remember that time you had a poster remove the boot battery connections resetting the boot cpu. Something about no start 3 times and it goes into shutdown. I'm kinda remembering it was a no gas situation though.
    Do yourself a favor and buy a Scangauge here at the Prius Shop. Its only $ 150 and could save you alot of money because in addition to all the ICE parameters like engine temp etc it will also read out DTC's (diagnostic test codes) which the experts (not me) can interpret for you. It displays the code number. It'll work on other cars too. Its easy it just plugs right in. No wiring at all. Its like a gun. You'll only need it if you really really need it.Plus its karma related. If you have a meter to read out test codes chances are you'll then never ever see a code again. Or maybe thats just my life.
    Good luck and it'll all be under warranty I'm sure but please report what happened.
  18. jsheldahl
    Iowa
    Well, the diagnosis is in, and it's not a good one: it's the inverter!
    Here's the best part: I got the car used, as I mentioned, and it was in an accident! I ALMOST asked for a Carfax report, but didn't for reasons I do not remember. Lesson learned, I will ALWAYS ask for this on a used car from now on! Sometimes, I do stupid, stupid things, but I always try to learn from them. Toyota believes that this is the only problem from the accident, so hopefully everything else will be warranty covered in the future. Does anyone else have any insight into this?
    When the car was being repaired, the connector cable for the inverter was not placed back where it was supposed to be. I forget where it was supposed to be, but the technician who took car of it used electrical tape to tape it to the bar behind the radiator. Guess what? Water got in there and shorted the thing. I have a little solace knowing that if I had looked closer under the hood when looking at the car, I wouldn't have seen any problem, anyway. I'm definitely not a motor-head.
    Toyota won't fix it under warranty, which is no surprise to me (the part and assembly shows no issue, it was purely the moron that taped it). I got the car at a Ford dealership about 2 hours away, and after going around in circles with them, they decided that they would pay to tow it back (because they refused to take Toyota's word, probably because they don't understand it) and repair whatever is wrong with it. I don't think that they believe the inverter is the problem, but my service writer assured me that until they replace it, it will refuse to start so I don't have to worry about not getting a new one. As long as it starts, it's a new one.
    They said that they have several master certified mechanics that they may have do the job, to which I questioned since it's not a normal ICE car or component that's the problem. He said that if they look at it and don't think that they can do it, they will get Toyota to do it for them. I'm hoping that they realize that it's dangerous to replace if they don't know how and let Toyota do it. Problem is, I'm stuck between a rock and a hard place here; I can let them have the car and give it back fixed or I can pay Toyota $4000. I'm just REALLY hoping that they don't do it themselves.
    Anyway, that's the story this far. Sorry for writing a book. The car is being towed in the morning, and I'm really hopeful to have it back by the end of the week (depending on part time and mechanic schedules).
    Have I mentioned that I absolutely love my Prius, despite all of this?
    Julian
  19. kazots
    kazots LifesaBeach
    262
    CALIFORNIA
    Call or take your car to the dealer. Why mess with the warranty?
  20. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Duh, kazots! Did you skip over the $4000?
