2004 MFD Acting UP
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dion, Jul 22, 2008.
  1. Dion
    Dion New Member
    128
    Jersey City, NJ
    My 2004 Prius MFD is exhibiting the TSB problems. Audio off shown while audio is playing. Check connection to air conditioner displayed.
    My question is this. The screen has not completely died. I want to get a replacement under the extended warranty. Should I wait until the MFD completely dies or bring it to the dealer now. The dealer says that they may need the car the entire day to inspect it. I don't want to be without the car for an entire day and then have the dealer say there is nothing wrong. What have you others done to have the MFD replaced. Can the dealer just connect something to the MFD to diagnose it?
  2. Patrick Wong
    18,200
    6,497
    I suggest that you take photos of the MFD display to document the symptoms that you noted. Then the service dept can use that evidence to become comfortable that the part indeed needs to be replaced.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    They should replace it based upon you report of an issue. The TSB is pretty clear that the owner will report intermittent problems. I would use the word intermittent and describe exactly what you see word for word. If you can grab a photo that cant' hurt, but should not be necessary.
  4. Dion
    Dion New Member
    128
    Jersey City, NJ
    I totally agree that they should replace it based upon my report. They don't need to run disgnostics on the entire car to replace the MFD. The service guy said that it's an expensive part and we need to check everything before we can order a new part and that he does not know anything about the MFD TSB. They are just trying to give me a hard time. I will try to snap a photo.
    Thanks for the replies
  5. johnp
    johnp New Member
    35
    Moses Lake, WA
    I had the same problem and the dealership insisted on spending time with the car prior to ordering parts. It did not act up while they had it but they ordered the refurbished screen and installed it a week later anyway.
    I got the impression that this inspection is a formality that the service department is required to perform before they can proceed on the warranty claim.
    Let us know if they accept a photo as proof but I suspect that there is a process to go through to get it fixed.
    John
  6. Patrick Wong
    18,200
    6,497
    OK, then maybe you should bring a copy of the TSB as well as your MFD photos so that the "service guy" can become educated about this issue. :p
  7. efusco
    19,891
    1,196
    Nixa, MO
    They are, technically, supposed to check a few connections that could be loose and cause a similar problem...a good department will order the part based upon history.
    But yes, bring in the TSB with you and hand it right to the Service guy who didn't know anything about it. If you're feeling snarky you could ask if he'd like to see copies of the other Prius TSBs that are out...
  8. Dion
    Dion New Member
    128
    Jersey City, NJ
    Thanks again.
    I had already printed a copy of TSB for the service guy.
    I will take it when I make my appointment.
  9. richard schumacher
    7,664
    1,044
    United States
    Uhh, didn't this TSB apply only during the initial warranty period? That has expired for the OP's car. Or did Toyota extend this in some way?
  10. Patrick Wong
    18,200
    6,497
    Hi Richard,
    A TSB provides technical advice to the Toyota techs about how to fix a problem; hence there is no expiration date to that advice unless superceded by a more recent TSB.
    A separate question is whether or not the customer must pay for the service recommended by a TSB. The bottom of the front page of each TSB describes any applicable warranty associated with the service.
    If the OP, owning a 2004, did not purchase extended warranty coverage, s/he would have to pay for MFD replacement now. Since s/he holds an extended warranty contract, the MFD replacement should not result in an out-of-pocket charge.
  11. richard schumacher
    7,664
    1,044
    United States
    Thanks for your usual correctness and clarity. I was careless in reading the bit about "warranty claim".
    Maybe I'm fooling myself, but haven't most of the failed MFDs been in climes with large temperature swings? Thermally induced stress is a common contributor to solder joint failure. Maybe I can hope that mine will never break...
  12. Patrick Wong
    18,200
    6,497
    Hi Richard,
    My dad was the first owner of my 2004, which spent the first 2+ years of its life in Honolulu, where the ambient temps usually range from the low 70's to the high 80's. After I bought the car from my dad (only 15K miles on the odometer at that time) I had it shipped to southern CA in the fall of 2006. A couple of months later, as winter approached, the MFD started to become flaky as ambient temps dropped down to the low 50's and high 40's at night. I then had the MFD replaced under the 3 year/36K mile warranty.
    Hence I would agree that thermal stress likely contributed to the early failure of my original MFD. The good news is that Hobbit identified the exact point where the failure occurred, so with some persistence anyone with a small-tip soldering iron can replicate his success in repairing a failed unit whose warranty has now expired.
  13. randyb359
    randyb359 Member
    430
    Pittsburgh
    I have a 2008 that did this once so far. I turned off the car and back on and it started working. Is this the same problem? I will have to ask the dealer tomorrow when I have it in for other work
  14. Patrick Wong
    18,200
    6,497
    The MFD design changed in 2006; however I've noticed that a small number of owners continue to report MFD issues. Hence if your MFD is intermittent it would be quite reasonable to report that to your dealer.
    However I suggest that you document its failure via photo, to make it easier for the tech to justify its replacement. Often an intermittent failure will refuse to manifest itself while the car is being tested at the dealer.
  15. Dion
    Dion New Member
    128
    Jersey City, NJ
    Just to update everyone.
    The dealer installed a new MFD today on my 2004 Prius.
    Now it toggles the energy screen from the steering wheel.
    Maybe it was worth the touble for that little option.
    I am now glad I purchased and got to use the extended warranty.
