Brake Actuator Problem
Discussion in 'Gen 2 Prius Technical Discussion' started by redbluff, Mar 13, 2008.
  1. redbluff
    redbluff Junior Member
    26
    I have a 2007 with 12K miles on it. Noticed that when moving from Park to Drive I get a big chirp somewhere in the engine compartment. Had it looked at by Toyota dealer and they first did the TSB procedure to see if it would solve the problem. It didn't. Said it was the actuator but that it was not necessary to replace it. I did find out the part is $1,662 and takes 4.4 hours to install. For some reason they dont want to do it. I took it to another local dealer and told them what it was doing and what the other dealer said (had documentation as well) but the new dealer said they would need to spend 3 hours diagnosing themselves and would not take the word of the other dealer who is 10 miles away. Had enough of the crap and called Toyota customer service and ask them to get one of them to just replace the part. Have not heard back from the case worker. This is the 3rd problem I have had with the car since new. Had a steering issue and a driver seat problem both of which they fixed. I also have the extended warranty on the car. I like the car but am getting really frustrated with the dealers which I dont understand because it is warranty work and they get fully compensated by Toyota.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,848
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Red,
    A chirp when pressing the brake is a known problem and is covered in a TSB. It is caused by air bubbles in the hydraulic fluid and often can be fixed by bleeding the brakes (can only be done with special Toyota equipment). If the air is getting in at the actuator due to leaking seals, the actuator must be replaced (and yes that is an expensive job). Let the second dealer re-diagnose the problem and do the bleeding since that should be a short (1 hour or less) job. If that doesn't fix the chirp, they should then replace the actuator for you under the warranty.
    I would not trust the result from the first dealer either (and would not use them again), but the second dealer seems to be taking a reasonable position. You may be escalating too soon.
    JeffD
  3. redbluff
    26
    Thanks. The first dealer did the TSB work and did bleed the brakes etc. They determined it was the actuator at that point but wont replace it since it is not what they call necessary or urgent and will not affect the braking of the car. So I think when a dealer refuses to do warranty work it is time to escalate.
  4. dannykelly76
    dannykelly76 hybridanny!
    Kentucky
    Hey all, I have the same problem with my 2007 Prius. It's a year old, and I took it to the dealer service and they had to look the problem up b/c it hadn't happened before here in Lexington, Kentucky.
    When they determined it was the brake actuator, they said they would order the part and replace it, covered under warranty. I think that's fair. So yes, I would complain too.
    Not sure if it makes a difference, but my dealer service is the same dealer where I purchased the car.
  5. FJD
    FJD New Member
    Southern California
    Had problems with noise in 2005 Prius after 2+ years and 18000 miles. Brake actuator was replaced under warranty. Had similar problem again after 1+ more years and 32000 total miles. Car out of warranty and replacement part was also beyond its one year warranty. Was quoted $2550 for the repair (over $1900 for the part). Complained to Toyota customer service. The best they would offer is I should pay $600. I think is an outrageous failure rate for a part that is so expensive. It should be under at least a 3 year warranty, parts and labor, any time it is replaced. This repair is discussed in Toyota's Technical Service Bulletin BR001-07 which limits correction under warranty to a customer's specific complaint.
  6. RavenFan
    RavenFan New Member
    Washington State
    We have a 2007 Prius and just recently developed the issue. Had the brakes bled only to make the issue worse. The dealer said Toyota would cover half of the replacement costs...obviously there is an issue here...Toyota obviously knows about it...frustrating to have this with a Toyota. I have had four Toyota so far in my life...did they just mess up with the Prius?
  7. acacia987
    acacia987 Junior Member
    44
    MD
    i guess your out of the warranty coverage? if not it should be completely covered.
  8. Patrick Wong
    18,200
    6,474
    If we are still talking about the brake chirp problem, this has no effect on the safe functioning of the brakes - see attached TSB. If your car is out of the 3 year / 36 month warranty, there's no reason for you to incur the cost to replace the brake actuator unless you are bugged by the sound.
    I've recently noticed that my 2004 produces this chirp intermittently, especially at high elevations. I don't plan to take any action since there's no safety issue.
  9. jdenenberg
    3,852
    1,848
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Pat
    At high elevations any air in the system will expand (due to low air pressure) and the chirp will get more prominent. Just bleed the right (passenger side) brake.
    JeffD
  10. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    I just did our first one last week and it really wasn't bad. The attempt at bleeding before resorting in replacement of the actuator didn't have any effect. The instructions for the replacement are a bit overkill for even a remotely capable Prius certified tech. The worst part of the job is the bleeding procedure afterward just because of the time involved. I took about an hour and a half longer than the time on the TSB just to make sure everything was correct, my next one will easily be faster without sacrificing quality. If you're close to southern WV come on in we'll replace it for you!
  11. acacia987
    44
    MD
    If you were only closer to the MD line i would take you up on your offer. I am still trying to convince my dealer that the noise is not my brake pads slipping and is fact due to the brake actuator. I dont know where they come up with this stuff.
  12. txtabby
    txtabby 2011 Prius 4
    123
    Austin, TX
    Shoot!! I had a tech. rep listen for the sound and we did hear it. He said it was something that kept the brake fluid pressure up and was not a problem. I did complain about this while under warranty, just. It's now out of the basic warranty and the noise is back, now louder. Can/should they fix it for free, or do I have to pay for replacing the part??
  13. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I think if a customer has written proof of complaint not resolved during warranty period then it would be difficult for the dealer to refuse warranty repair soon after expiration. Good luck! :)
  14. km1159
    km1159 New Member
    milwaukee
    PW
    2000 miles into my '07 i have dtc C1365 and warning buzz along with ABS VSC lights. Will air in the system throw this (accumultor pressure sensor)dct?
  15. Patrick Wong
    18,200
    6,474
    This is an interesting one. DTC C1365 "Malfunction in ACC Pressure Sensor".
    The accompanying text in the Toyota repair manual says that the DTC may be output if the accumulator pressure drops due to frequent braking (this is not a malfunction). Otherwise, the brake actuator assembly or the skid control ECU are the suspect areas.
    I suggest that you reset the DTC, then see if the problem reappears. If it does then you'll need to identify the failed part. I wouldn't suspect air in the braking system unless you have reason to believe that air was introduced from recent brake work.
    You can reset the DTC by jumping terminals 4 to 13 in the OBD-II connector, then make the Prius READY and depress the brake pedal 8x in five seconds.
    The OBD-II terminals are numbered starting from the right. So terminal 1 is in the lower right, terminal 8 is in the lower left. Terminal 9 is in the upper right, terminal 16 is in the upper left.
    If you decide you have a problem and want to DIY I recommend you obtain repair manual info at techinfo.toyota.com
    If the brake actuator assembly must be replaced then you'll need access to the Toyota diagnostic laptop to be able to bleed air out of the hydraulic brake plumbing. Probably better to entrust that to the dealer.
    SFO and Kauai mansur like this.
  16. km1159
    km1159 New Member
    milwaukee
    You are very good
    I had air suspitions because i had a front end collision that I did replace the bracket onder the asb pump....the lines were all off
    will clead dct and see what arises T Y
    MJB
    Kauai mansur likes this.
  17. txtabby
    123
    Austin, TX
    Now its back really loud. I looked for 'written' proof of my complaint, i have none. I'll check with the dealership but i'm sure they don't have one either. I could get really lucky if they remember and agree to cut some kind of deal. The 'jumper' fix is interesting.
  18. txtabby
    123
    Austin, TX
    Actually, according to the Bentley repair book, it says to "Turn the hybrid system ON (IG-ON, READY indicator not illuminated)".
    Just wanted to clear things up...
    And you said 'if the problem disappears...' did you mean the DTC, or the noise??
  19. Patrick Wong
    18,200
    6,474
    The Toyota repair manual says "Turn the power switch ON (READY)". Try it one way and if it doesn't reset, try the other way.
    I was responding to km1159 who had the brake warning buzzer as well as DTC C1365 and brake warning lights. If his problem persists, then he would have to identify the failed part or else decide whether his car has air in the brake lines resulting from the collision repairs.
  20. clem choy
    clem choy New Member
    burlington, vt
    This is the first time I post so not knowing how the thread works. I have a 2007 Prius and I lost the remote key. I called a locksmith in NYC and he unlocked the car, cut a duplicate from a new remote (I think he got it from the dealer) He then tried to program the remote but was not able to. He then plugged a computer into some wires underneath the steering wheel. The moment he did that, the VSR, ABS, (!) and brake light all came on. I took it to a Heritage toyota in Burlington and they told me they need to replace the brake actuator. The part is $1700+ and plus 5 hours labor. Could the lock's smith computer really do that kind of damage? What are my options. Thanks for the help.
