Tire Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by nyprius, Jun 26, 2006.
  1. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    Here are several links that may be informational:
    Tire code - Wikipedia, the free encyclopedia
    Uniform Tire Quality Grading (UTQG)
    Treadwear rating - Wikipedia, the free encyclopedia
    Before places like PC, I would use the Traction and Temperature(Speed) standard ratings to try to make an intelligent compromise of wear vs traction/handling and speed/performance vs cost. Treadwear rating is relative to all tires tested with a 400 rating falling pretty much in the middle of the pack. Since I learned about these ratings sometime in the '70's, I look for tires with ratings of Traction=A, Temperarure(speed)=A and Treadwear~400 for our primary cars. Currently running Michlein MXV4 Plus' on our 2000 Avalon XLS, 34psi front/32psi rear. Third set(original plus 2) still good tread @ 108K. Averaging right around 40K per set. Keep them rotated. Running B/B ratings on the '87 Ford Club Wagon XLT. It hasn't been over double-nickle in over 8 years, <1000mi last year.
    While the rating are informational for new or unfamiliar tires, and good for comparing tires, I would rely heavily on the real life experiences and opinions of PC members.
  2. Highly ImPriused
    Highly ImPriused Impressive Member
    250
    Western NY
    OK, after a week of commuting with the new tires I can confidently say that there is a hit of about 2-3 mpg going from worn out OEM GY Integrity tires to brand new Pirelli P4 Four Season tires in the wider 195/60/15 size. Both sets of tires at 50 PSI all around. This week I've been getting right around 56 mpg on my commute in (was around 58) and 63 mpg on the ride home (was around 66).
    Not too bat at all and the handling is noticeably better. I bet mileage would be very similar in the OEM size. Now that I have a good basis for comparison, I'm going to try bumping the psi up a bit higher to see if I can get back to my previous mpg range. I haven't noticed any ride discomfort to speak of with them at 50 psi. I'll report back over the winter once I've had a chance to try these new shoes out under more challenging conditions.
  3. dwreed3rd
    742
    Marietta, Ga
    Q for those running at a high psi. My experience, non-prius, has been that if I go too high, still within tire max., that the tire will wear the center of the tread faster than the outter edges, if no compensating weight is on the vehicle to keep the tread flat on the road. It's happened to me when I would increase the psi in my rear tires to compensate for towing the trailer. Then forget to adjust it back down after towing. I would notice some degradation in handling and that they were wearing faster in the center of the tread. Checking the tires for treadwear is how I determine my optimum psi(s) for front and rear as to handling, economy and even treadwear. Feathering will indicate an alignment problem, usually in the camber on front wheels.
    Has anyone experience this with the Prius. I cant imagine that at some of the high psi(s) posted on PC that the tire isn't ballooning at least a little without a compensating weight on the wheels.
    Thanking everyone in advance for your replies.
  4. Highly ImPriused
    250
    Western NY
    Try searching on tire psi and you'll find a lot of varying opinion on here. The one thing I haven't seen is any documented proof of uneven center wear at high psi. To the contrary, most people experience edge wear at the manufacturer recommended PSI of 33/35. Also F8L has provided high resolution photos of his OEM Integrity tires, which he runs north of 60 PSI I believe, with completely even wear across the treads. I don't remember which particular thread that was in, but you could probably find it with a search including his username.
    The only difference I've noticed with mine at 50 PSI is perhaps a bit of a stiffer ride (not enough that I've ever had any passengers mention it though) and that traction control is a bit more prone to kick in when going over a big enough bump/pothole. I plan to lower them down a bit during the winter for better handling.
  5. dwreed3rd
    742
    Marietta, Ga
    Thanks! That's interesting info. It may just be that the newer tire disigns, sizes, shapes, and materials distribute the psi in a manor, that the psi range, between min & max psi, does not change or distort the tread cross section, so the car's weight is distributed evenly on the tread and thus, to the road, at the full recommended psi range. Sorry for the horrorably long sentence. That would explain it, because psi used to have a significant affect on treadwear. Now that you mention it, I have not noticed it on the MXV4 Plus tires I've been running on the Avalon. I think I'll run them up to Max on the front/less 3psi in the rear, and work down from there to find a happy median between Toyota's recommendation and max psi. Currently running @34/32. 2000 Avalon XLS w/108K. City went from 17-19 to 19-21 due in part to ScangaugeII and in switching to Mobil1 5w30.
    Haven't done enough highway yet to note change there. Maybe I can get a couple more mph upping the psi. I won't sacrifice handling though.
    Thanks again! I'm an old dog that likes to learn new tricks.
    My Dad always told me: "It doesn't matter who you are or what you know. Evrybody knows something that you don't. Even a bum in the gutter". His choice of words, not mine, and he did not mean it in a derogatory manner. I don't remember the term homeless in the '40's - '50's. Anyway, I'm always open to reprogramming the old grey matter.
  6. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    You might want to reconsider your choice of inflation pressure - Pirelli specs 44 psi as the max inflation pressure. If the tire fails due to over-inflation, you are on your own.
  7. Highly ImPriused
    250
    Western NY
    If I thought there was a chance of tire failure due to over inflation, I wouldn't be doing it period. Regardless of who may be responsible. Do you know of any documented cases of tire failure at reasonable speeds (say under 70 mph) due to overinflation at up to 50% increase over the sidewall listed max pressure (i.e. up to 66 psi for a 44 psi rated tire)? I searched before deciding to go up this high and didn't find anything. I'd love to hear about it if there's something out there.
  8. apriusfan
    6,050
    205
    S.F. Bay Area
    You might try posting on PC to see if anyone has done what you are contemplating doing (66 psi for a 44 psi rated tire). I personally wouldn't go more than 44 psi on a 44 psi rated tire. But you may have a higher risk tolerance level than I do.
  9. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    I have to agree. There's a reason the maximum psi is posted on the tires. A lot of testing goes into tire failure before they're placed on the market. When they "do" fail, they result in humongous lawsuits the the Cooper Tire suits.
  10. Highly ImPriused
    250
    Western NY
    First of all, mine are currently at 54 PSI. I don't plan to go over 60, but many people do. 44 PSI is the industry standard maximum PSI rating for most passenger tires. Tire manufacturers don't reverse engineer back to that number for tire failure. They make tires according to industry standards with slight differences in tread patterns, etc. There is a huge factor of safety involved in the industry-wide maximum rated tire pressure. Typical engineering FoS where loss of life can occur is 3x. That would mean that a 44 PSI rated tire might be expected to fail at over 130 PSI. Am I going to test that? Hell no. There's a reason that big of a safety margin is there, the true number is not exactly predictable. But if there were even a slight chance of failure at 60 PSI, you can bet the tire rating wouldn't be anywhere near 44; it would be more like 20. You can choose to believe me or not. Bottom line is that no one I'm aware of has found any credible evidence of tire failure under normal (i.e. non-racing) conditions due to over inflation.
    The Rubber Manufacturers Association warns that underinflation is a tire's number 1 enemy. It results in unnecessary tire stress, irregular wear, loss of control and accidents. http://www.rma.org/tire_safety/tire_maintenance_and_safety/
    * Highly ImPriused does not recommend that you exceed the maximum rated pressure printed on the sidewall of your tire. Your decision to stay within that limit is the right one. Sleep easy at night my friends.
  11. F8L
    19,011
    4,081
    Grass Valley, CA.
    I'm running 66/64psi. I have been doing so for probably about 5,000 miles or so now. They were at 60/58psi. I drive so much and time goes by so quickly I cannot be accurate with my # of miles guestimates but it's close enough to get an idea. :)
    My wear patterns are excellent after having run 50+psi for the last 40k+ miles. Could I be more likely to have a blowout? Who knows, I've never seen any proof of that opinion. I do know that the car handles better and gets better milage north of 50psi and the wear is not effected in any visible manner. I will likely drop them back down to 60psi as I do not notice any major mpg inceases after going to 66 but I do feel more bumps in the road and that may not be great for the shocks. :)
    I'm going to have to side with Highly ImPriused on this one.
  12. ursle1
    ursle1 Realist
    35
    NH
    I'm in hong kong building a prius, specification sheet says both front and rear brakes are disk
    Toyota - Prius
    seeing is belivin
  13. dwreed3rd
    742
    Marietta, Ga
    Did you notice the fine print at the bottm of the spec sheet?
    "Details of specifications and equipment provided here are subject to local conditions and requirements and may, therefore, vary from models available in your area. Please enquire at your local dealer for details on your local specification and equipment."
    Do they also have EV mode and Plug-in?
  14. birdsquared
    birdsquared New Member
    46
    Burnaby, B.C., Canada
    Highly ImPriused and F8L (kinda ironic nickname given the topic...), have you considered posting a separate thread on "Overinflation" to see if there are more people out there with experiences to share. These posts on page 31 and 32 of a different topic might only be reaching a very small minority of readers. I would also be very interested to see more anecdata on this issue.
  15. F8L
    19,011
    4,081
    Grass Valley, CA.
    I did a threa sort like that titled Integritys at 30k and 50+psi or something to that effect. :)
  16. birdsquared
    46
    I searched for that thread and read it, but it turned into more of a discussion on Integrities rather than on experiences with overinflation generally... Maybe I'll start a thread...
  17. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    I guess I don't understand why anyone would pay a lot of money to upgrade tire performance on a car like the Prius. I'm not talking about replacement tires for your worn out OEs. That makes sense to me. What doesn't make sense is upgrading your new OE tires, and spending several hundred dollars in the process. That's a lot of gas in a Prius--a car built more for efficiency than performance.
  18. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    Most people don't care, but I did. Here were my reasons:
    1. Improved Handling. I bought the Standard Prius without test driving it first. Big mistake. Even on the short drive home from the dealer, I was disappointed by its poor handling. I submit that the Standard Prius is the worst or one of the worst handling cars of its size (175 inches long) sold in America. I wasn't looking to turn the Standard Prius into a BMW. But I did want it to have at least average handling (e.g., like a Corolla or Matrix) or above average handling (e.g., like a Civic or Mazda3) for its size.
    2. Improved Braking. The Standard Prius' braking distances are subpar. In Consumer Reports' tests of approximately 270 current model cars, the Standard Prius had a 60-0 mph dry braking distance of 143 feet, putting it in the 30th percentile of all cars tested by Consumer Reports.
    3. Improved Wet Handling. Ever since I had the experience of hydroplaning in a car, I've always been concerned about the issue. So when I've had to get replacement tires for cars I've always gone with tires known for their wet traction performance. But in the Prius' case, I decided to replace the tires early because I read too many posts here on PriusChat about people hydroplaning on the stock Integrities.
    So because of the above, I opted to replace the Integrities with Goodyear TripleTreds in the wider 195/60/15 size. I'm very pleased with them.
  19. dwreed3rd
    742
    Marietta, Ga
    Boo; Exellent reply!
  20. kazie60
    kazie60 New Member
    56
    Madison, WI
    You really did your homework. What would you recommend for me? I have a 2008 Touring Model and I need good all season tires for Wisconsin winters. Thanks much.
    Kay
