Confessions of a pseudo hypermiler
Discussion in 'Gen 2 Prius Fuel Economy' started by Codyroo, Jul 16, 2008.
  1. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I don't know if I was born this way, but I've always been fascinated with fuel efficiency (I suppose the power of TV back in the 70's when cars started touting their mpg's had a profound influence on me). I calculated mpg on my parents cars and my high school car. My first car purchase was a 1988 CRX-HF, best fuel efficient 4 cyl car on the road at the time. No one asked about the HF payback, as it was cheaper than a stock CRX by about $500 - $1000.
    Over the years, I've developed "habits" that would later become typical of hypermilers. My issue is that stories I read basically trash on hypermilers and only address the most outrageous of their behaviors, yet don't address all of them.
    1) I drive 55 mph (and have done so for 3 years) in 65 mph speed zones and I drive in the right lane. This, by the way, is the speed limit for trucks and cars towing trailers. It cannot be illegal, as it is supposed to be the Maximum speed limit for a certain percentage of the cars on the freeways.
    2) I coast in neutral or press the clutch pedal (I drive a stick shift) when I'm coming up to a stop sign/light (red). I notice that I have to keep gassing the car to reach the stop sign due to engine braking if I leave it in gear. If I put it in neutral, I can coast a much longer distance (At or Below the speed limit) as I approach the stop sign.
    3) I time the lights as best I can, so as to catch them turning green while I'm still rolling.
    4) I will turn off my engine, if I know I will be sitting at a red light for more than 30 seconds.
    5) I will (occasionally) put my car in neutral on the highway when going down a long grade. I will put my car back in gear or brake (or both) if I'm following too close (e.g. 2 seconds or closer). Typically, though, I have a good idea when I can do it and it is safe (looking for brake lights ahead).
    6) Recently, I've started inflating my tires to their maximum pressure.
    It seems that law enforcement and journalists will trash most of these things, but I don't understand precisely why. What are the downsides, risks, real consequences (not perceived, opinions, etc....give me facts) of these behaviors.
    1) No one has run me over for driving 55 mph. I get "looks", the "bird", "cut off" and tailgated, but *knocks on wood* no accidents involving me or happening just behind or in front of me.
    2) I've not been in a situation where coasting in neutral has compromised my ability to handle my car. Typically (99% of the time) in an emergency situation, I'm braking, steering, and, pressing on the clutch (to not kill the engine), thus effectively putting my car in neutral. I'm not a high performance driver, typically my best effort is to reduce speed and trying not to lock up the tires so what ever direction I'm turning the wheel, I might have a chance in driving that way. I'm not an expert driver, nor have I taken advanced course in accident avoidance. Most arguements that I hear about keeping a car in gear is to avoid accidents, but if you don't have the proper training (and most of us don't) it won't help. Most of us don't think to accelerate to avoid, we think to brake.
    3) I do not roll through stop signs or lights. Ever. Not even on my bicycle.
    4) My car is well maintained, it will start if I turn it off.
    5) See #2. I don't tailgate. Heck, when I'm coasting down a steep hill, I finally am keeping up with traffic. At the bottom of the hill, I'm slowly bleeding off speed and it allows those behind me to merge left and pass. I suppose it does confuse them as to why I drive 55 mph up, coast to 75 mph down the hill and slowly return to 55 mph.
    6) My tires haven't blown up by increasing the air pressure. The ride isn't noticeably different. On freeways, I'm typically driving slower than the traffic flow and I follow no closer than 2 seconds (typically 3 seconds) from the car in front of me, thus I usually have plenty of time to react to address any additional "braking distance" my inflated tires cause me.
    7) "Drafting" 100 feet (or less) behing big rigs (or tailgating in general), turning off your engine while coasting, rolling or running through stop signs/lights are very risky and dumb things to do. I don't do them, and it seems obvious to me why they are poor behaviors.
    If you can come up with real consequences for my habits, please do explain, but try to back it up with facts when possible. Mostly, I'd like to hear from someone who could explain the whole "coasting in neutral" is bad.
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Real consequences? How about substantially better fuel economy? But then you know that. ;)
    Coasting in neutral on downgrades is illegal in many states, but most states seem to allow it on level terrain or uphill. As one who has driven professionally for many years, I (like you) fail to see what makes it unsafe, assuming the vehicle is otherwise kept under control and at safe speeds.
    You're doing what CleanMPG has advocated for several years now. Take a look over there for further discussion on -- and a response to -- the bad press recently given to hypermiling.
    I will challenge anyone (and I have actually done so with one of the local media outouts) to take a ride with me to see how to do it safely and courteously.
  3. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    You know, I did a lot of that stuff as well, for years in my 'regular' cars. Now I do it with hybrids I own as second nature.
    It really helps with the Hybrid Highlander. I get about 30MPG in that, and with the A/C on as well.
    I'm all for saving some gas, when I can.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Cody,
    I am like you... fascinated by efficiency. Efficiency impresses me -- not burning gas as fast as possible (add cylinders or increase displacement) to make power. To me, getting more power out by improving efficiency and delivering power to the wheel smoothly is very exciting -- not manual labor gear shift-shock.
    I think where you and I differ is how to achieve higher efficiency. It sounds like from the explanation of your behavior, achieving higher efficiency is mostly up to the driver. I believe in technology to achieve higher efficiency and make the driver's life easier.
    There are some extreme hyper-milers that focus on changing driver's behavior to the extreme (even to the point of pushing the car) to achieve extreme MPG out of non-hybrid cars. This requires compromise and you end up giving up something to get something. It is good to know what is achievable but general public will not be able to do that. A compromise or trade off is nothing new. We need technology to shift us into a new and larger paradigm.
    I believe in the technologically advanced car that is more efficient and make additional gain by slight driver's behavior change. Yup, I am talking about HSD. I don't consider myself hyper-miler and I don't hype about it.
    I am an Environmental Friendly Efficient Driver (EFED) -- I like to pronounce eeee fed. I don't go to the super duper hyper extreme. I have a life and a job. I drive with the traffic flow. I don't drive active aggressively (speed/tailgate/etc) or passive aggressively (slow/stubborn/etc). I let the technology take care of saving majority of the fuel.
  5. Codyroo
    1,826
    515
    Pleasanton, Ca
    The only thing argument I've heard is that you "have less control" over your car, as an explanation for the illegality of coasting in neutral. Does less control just entail that you can't accelerate? Or are there real time handling consequences? I'd argue that the point is irrelevant because, if I assume that I react as most people in an emergency situation, I'm braking, not accelerating. I think only the most highly trained drivers would be able to correctly assess when to accelerate out of a problem and my guess is that a vast majority of the time, braking is the best way to avoid the problem (or minimize the damage if the problem is unavoidable).
  6. douglas001001
    douglas001001 smug doug
    222
    Chicago
    I think a lot of the negativity is based from what they chose to name it, HYPERmiling (how does that sound compared to say, maximiling), as well as how the information is presented on their web site.
    They post editorials blasting media outlets and car manufacturers. These are the same manufacturers with the same strong lobby that has been against and helped reduce tougher fuel economy legislation. Why are they surprised when media outlets report misinformation and attack their methods? The auto industry represents a significant portion of revenue for media outlets.
    The point is, you are driving safe and efficiently and driving as every person on the road should. No need to worry if you are doing something incorrect.
  7. Codyroo
    1,826
    515
    Pleasanton, Ca
    Background: I drove my CRX from 1988 - 1999 and put over 190,000 miles on it. I've been driving this Integra from 1999 - present and have put about 120,000 miles on it (or so). A couple of years ago (after seeing my first Prius on our work campus during an Earth Day like event) I became enamored with the car, because it could seat 4 adults comfortably AND it got better EPA estimated gas mileage than my CRX.
    What was depressing was the subsequent searches that found that cars were getting worse fuel mileage than they were 20 years ago. After looking around a bit and reading, I was enlightened on how cars had become bigger, engines were more powerful, and all the wonderful safety features. But, it seems, that automakers listened to their buyers and buyers weren't overly interested in fuel efficiency. A bit of a pity, because I wonder what they could do with a conventional car if they focused on that (even with all the modern day safety features).
    I agree, technology can help out a great deal (heck, my brother once owned a Corvette and could get nearly 30 mpg highway if he kept the speeds down). But, there are 2 things one can do to improve MPG's. 1) Throw money at it. 2) Modify one's driving behavior.
    Throwing money at the problem is the psychologically easier solution. Getting a more fuel efficient car is an "easy" solution....assuming you have the cash to do so (and it could just be trading in a larger car for a smaller one). But to me, it only solves part of the problem.
    Modifying one's driving habits is the harder, psychological solution. It is withering to one's testosterone drive psyche to continually watch people blow by you on the freeway. But it requires no additional cash, no change in vehicles and can be initiated immediately.
    The best is to do both, get a more fuel efficient vehicle and drive it safely and for fuel efficiency. I will say, it does bother me at a core level to see Prius drivers blowing past me, doing 70-75 mph on the freeway. On the one hand, at least they are getting about 40 mpg while doing it, but I can't help but feel that if they slowed down to 60 mph, they'd be getting mpg's in the mid to high 50's.
    I guess to me it seems like by buying the car they feel that they've done their part. And to me, it is only half the job, and they've taken the "easy" way out. I'm definitely envious, I want my Prius, but I have to wait (and especially so with the current supply/demand issues). But once I have it, my driving behaviors won't change, because I've trained and disciplined myself.
    BTW for the record, my last 12 months driving my Integra, I averaged 38 mpg. Summertime was 40 mpg, winter was 36 mpg (Darn that cold weather and winterblend gas). Worst tanks (average of 3 consecutive fill ups) was 35.7 mpg (January 2nd - 15th), best tanks (average of 5 fillups) is 42.5 mpg (June 17th - July 11th). EPA estimates for the car was 25 mpg city, 29 mpg highway.
  8. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Here's a thought: I've seen it said that on some conventional cars, if you're going downhill with your foot off the gas, the car will shut off the injectors and not actually use any fuel. However, if you're in neutral, it will have to burn fuel to keep it idling.
  9. PoulStaugaard
    PoulStaugaard Now a PriusOwner
    95
    Copenhagen, Denmark
    Yes, you can coast for a longer distance in neutral than you can in gear, but that doesn't neccessarily mean that you save gas. I haven't done any testing myself, but the experts say that you should leave it in gear while coasting to a stop because that way, the engine receives no gas, as opposed to if you put it in neutral.
  10. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    141
    HTTP 404 Not Found
    HTTP 404 Not Found
  11. Codyroo
    1,826
    515
    Pleasanton, Ca
    Which cars would have that feature, how would one know if ones car did this or not?
    Would a 1989 Integra have such feature? I've never heard of this before.
  12. PoulStaugaard
    95
    Copenhagen, Denmark
    I believe all engines with electronic fuel injection have this feature.
  13. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    There are many times when you should "dip the clutch" into neutral to control the car.. eg: when aquaplaning, sliding on "black ice" etc.. this removes the "engine braking" component from locking the front wheels and you then lose the steering. The Prius gets around this with the vehicle stability system.
    Going down steep winding mountain roads is not the best time to "dip the clutch" either! The engine braking may save the brakes from overheating and also the car's center of gravity is altered when cornering round a sharp bend in neutral without braking or engine braking.
    Safety regulations always err on the side of extreme caution IMHO.
  14. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    The Prii seems to no longer be the car you see moving slowly or slower than the pack. I see Prii on the road now and they are almost all doing as fast as the others. I guess people think it's the car that does the work of saving fuel? The Prii does a lot at what 46 to 49 mpg even if you drive it like a sports car?
    I guess those folks are happy enough with that.
  15. davidhol
    davidhol New Member
    27
    Roseville, CA
    Well, the results are in. Our vacation trip of 5,901 miles from CA to NV, UT, CO, KS, MO, IL, IN, MN, SD, WY, NV and CA resulted in 52.8 MPG. We took the car up to 85 MPH briefly over the salt flats and it handled very nicely and felt as though I could have gone much faster if I wanted to. The CO mountains were no problem at all.
    I drove at 55 MPH for about 95% of the trip. My back was a bit sore but overall it was a fun trip.
