Augment Bonnet Damper
Discussion in 'Gen 2 Prius Accessories & Modifications' started by redlinedrift, Jul 9, 2008.
  1. redlinedrift
    redlinedrift New Member
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    can't find the article, the directly link, even from the jdmtuningnews site is broken...
  3. redlinedrift
    It looks like it is working again. On an aside, I wonder if there is a product like this for the Prius on the market in the usa already?
  4. chinalfr2
    chinalfr2 Member
    234
    New England
    Pics of the Bonnet Damper.
  5. efusco
    19,891
    1,196
    Nixa, MO
    Ok, I still can't really get to anything of much use. The picture is great...except I don't know what I'm looking at. Is it that black thing on the underside of the hood/bonnet?
    What's the damper supposed to do that the OEM one doesn't? Why would I spend money on it?
  6. chinalfr2
    chinalfr2 Member
    234
    New England
    With a damper, you can pop the hood on your car and the damper will raise the hood. You effort to hold the hood up until you can get a support will not be required. I think your hihy should have a damper supported hood.
  7. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    You still have to release the secondary latch, but yes, it is a pneumatic spring/support, similar to the rear hatch. So you don't have to use the manual hood support. It's more secure in windy situations as both ends are permanently attached.
    Then there is the "cool factor".
  8. redlinedrift
    There are many advantages to using a damper over the traditional metallic rod hood prop. Dampers are designed to eliminate the OEM hood stand. It's really a wrenchhead and convience item. For the people who are always tweaking stuff under the hood this allows for more workspace as it removes obstructions. Those looking for something simple, it also allows opening and closing the hood to be quick and hassle-free. It's especially useful on vehicles equipped with large OEM hoods, and for situations with high wind, as more stability is provided. As the fuel economy gurus on here should already know if your hood has better rigidity and stability against movement, g's and wind that translates into better aerodynamics and ultimately better mpg.
  9. efusco
    19,891
    1,196
    Nixa, MO
    AHHH!!! I see...OK, thanks for the clarification.
  10. efusco
    19,891
    1,196
    Nixa, MO
    we need to get Sigma to carry this...or the Priuschat shop.
  11. a_gray_prius
    2,927
    783
    IL
    I want hood pins. :D
  12. patsparks
    10,664
    567
    Adelaide South Australia
    I lift the bonnet once every 3 months or so because it's a Toyota. For $163AU plus shipping I think I'll pass.
  13. Areometer
    Areometer Silver Business Sponsor
    578
    Tyngsboro, MA
    Hey Doc, I hear ya. Wish me luck in sourcing this. :)
  14. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Just how does this damper add stability and better aerodynamics?
    Looks like it just assists in opening the very light aluminum hood.
    An open hood does not provide better areodynamics if it did we would see the MPG obsessed driving around with their hoods open.
  15. bac
    bac Active Member
    863
    52
    Pennsylvania
    Yes, that is just stupid. Redline ... I believe you to be a shill also.
    ... Brad
