noise when braking, even when engine is off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TonyD50, Jul 28, 2008.
  1. TonyD50
    TonyD50 New Member
    Baltimore, MD
    Hello. I have a 2008 Prius, bought in April. I've recently noticed a relatively loud noise coming from under the hood, directly in front of the driver. It occurs when braking at low speeds, and sometimes on acceleration from a complete stop. For the first few minutes after turning off the engine, you can hear the noise when you step on the brake. It sounds like a very rapid, machine-gun fast clicking. Sorry for the poor description, but it's the best I can do. A Toyota mechanic said that it's the ABS pump, and that it always made the noise, and that I just didn't notice it before. I'm concerned that he might have blown it off. Has anyone had this problem? Thank you!
  2. realale
    realale Junior Member
    94
    St. Louis
    We've noticed this too. My searches on the forum indicated it was something to do with the brake system as well.
    Mine seems to be more prevalent when I'm carrying more passengers or cargo, but it definitely happens from time to time on both braking and acceleration when it's just me in the car as well. I'll be interested to see what the more experienced say. It definitely makes me nervous.
    Great description of the noise, by the way! I always think it sounds like a Vibraslap (most like the LP 209 soundclip, but not as metallic, on this site: Latin Percussion: LP Vibra-SlaP II ). Ours lasts about 1.5 seconds each time.
  3. Patrick Wong
    18,210
    6,511
    The noise likely is from the brake pressure accumulator pump. If you repeatedly depress the brake pedal while the car is READY, you should hear the pump running to rebuild pressure in the system. If that is the same sound that you expressed a concern about, then no worries.
  4. qbee42
    3,079
    This is the brake accumulator pump. The power brakes on the Prius are driven by an electric pump, since the engine does not run continuously as it does on a normal car. The accumulator pump kicks on about every third time you use the brakes. It builds pressure in a little tank, which is then used to power the hydraulic system. The accumulator pump makes a buzzing or ratcheting sound.
    The other noise you hear after powering off is the coolant transfer pump. The transfer pump saves hot engine coolant in a thermos bottle, which is then used later to preheat the engine. The coolant transfer pump makes a whirring sound.
  5. TonyD50
    TonyD50 New Member
    Baltimore, MD
    Thank you for the input. I have an appointment with a dealer today. I'll let you know what they say.
  6. TonyD50
    TonyD50 New Member
    Baltimore, MD
    Well, the mechanic who worked on my car doesn't know quite what's wrong with it. He thinks the noise is much too loud. They kept the car and put me in a loaner. I'm glad that this dealer isn't blowing it off, as did the dealer who sold me the car.
  7. TonyD50
    TonyD50 New Member
    Baltimore, MD
    Well, I finally got my car back. It took 3 days. They said that the noise was from the "electronic brake booster." They contacted the "tech line" and were told to reset the linear calibration. They did that. Nothing has changed. The noise is the same as before they made the adjustment. I've been told that it's not a safety or drivability problem, so I'm going to ignore it.
  8. qbee42
    3,079
    It's the brake accumulator pump. I have this comment on a hot key, so I can press it once to answer this question. It's one of the most common.
  9. Large
    Large New Member
    Thanks, Tom! for the clear reply to the question.
    I have found this in various forums, so I will ignore this noise, unless it gets worse or I feel it affects performance. It's just unusual to have this noise when you hit the breaks (as you say, approx every third time or so and sometimes when accelerating out of a stop).
    But I guess it comes with driving around with a lot of technology under the hood and the seats and the trunk and everywhere.
  10. 2006 prius in nashville
    2006 prius in nashville Junior Member
    nashville
    The noise from my brake accumulator pump now occurs every 8 seconds when driving and about 20 seconds when stopped. I just had the clock spring replaced and the also my sway bars. (and my instrument cluster) The pump has always made that noise but now it happens what seems like too often. 1) could it have been something they did 'wrong' at the shop?; 2) should I be worried? I am about to drive for 5 hours away on a two week trip to a mountain town in North Carolina. Closest big city 1 hour away
  11. mr_guy_mann
    mr_guy_mann Senior Member
    4,062
    1,981
    NJ-USA
    If the brake pump runs periodically even when you don't push on the pedal, then something inside the brake actuator assembly is bleeding off (leaking) pressurized fluid.
    Normally it should stay pressurized for a long time - my 06 will barely drop any pressure after 30 minutes until I use the brakes.
    If yours is getting worse then it's time to research replacing the brake actuator assembly. No one can tell how long a failing actuator will last before the pump dies- but it should start throwing ABS codes when it gets worse.
    Loss of the pump will result in the "last stage" fail safe function- the brake pedal will directly operate just the front brakes- no boost (hard pedal), no ABS, no regen, long stopping distances.
  12. 2006 prius in nashville
    nashville
    Thank you! So it is safe to drive until the ABS last stage event occurs? and even then, but then it will brake like an old truck?
