2002 Toyota Prius Flood
Discussion in 'Gen 2 Prius Technical Discussion' started by cygnusx1, Jul 18, 2008.
  1. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    I have a 2002 Toyota Prius that flew off the road and ended in a creek resulting in about 6" of water on the floor. The car powers on with the Heater/A/C, stereo and odometer stuff all working fine. I removed the HV Control Unit (engine computer) from the underneath right side of the dash and opened it up and it looks trashed so I've ordered another one. My question is what other computers am I looking at and what precautions do I need to take before I try to start this car. No water got inside the engine but not sure about the inverter or tranny. The inverter cooler is damaged but the radiator is okay. I am not sure where to begin??[​IMG]
  2. Patrick Wong
    18,210
    6,526
    The hybrid vehicle (HV) ECU is located under the carpet on the passenger side of the car, and this would be the most likely to be damaged in a flood. The engine ECU is located behind the glovebox, hence it is higher up and may not have been affected.
    Regarding precautions, my suggestion is that you repair all visible powertrain damage, especially the inverter radiator. Then try to start the vehicle. If warning lights come on, then it is likely that DTC will have been logged. If you can retrieve the DTC then you will be able to determine what other faults remain.
    Considering that the car has 120K miles, it is possible that the cost of repairs will approach or exceed the car's market value - unless you have access to a good supply of salvage parts.
  3. tochatihu
    tochatihu Senior Member
    9,991
    3,858
    Kunming Yunnan China
    2001 Prius
    That was a pretty hard smack - hope you and passengers are all OK!
    A new inverter coolant heat exchanger means changing that fluid, which means bleeding air from the coolant system afterwards. You chould learn this procedure and the way to confirm that coolant is being pumped effectively.
    The electronics are certainly going to require close examination, but I also guess that the frame rails are bent. This may not be a good candidate for repair.
  4. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    Actually the frame rails are fine as is the radiator and fans... the inverter radiator has a crack... which is $94 from toyota so I'm not too worried about that... My problem now is I replaced the HV control that is under the right side of the dash (mounted on the floor)... The car now shows a triangle on the dash and the master alarm and the hybrid alarm... when I turn the ignition switch to on. Do not have a single burned fuse in all three fuse box, and the battery fusible link is fine. I have no idea what to do now???? I have completed cleaned the carpet/seats etc. and let them airdry in the 100 degree kansas sun for 4 days and painted all the parts but afraid of where to go next... feel like I might get electrocuted...!
  5. Patrick Wong
    18,210
    6,526
    When you installed the hybrid vehicle ECU, did you first disconnect the 12V battery? If not, try disconnecting the negative battery terminal for 10 minutes, then reconnect. The point of that is to hopefully reset the various ECUs and erase the stored DTCs.
    Then, if you still get warning lights, you need to retrieve the stored DTC to find out what faults the various ECUs have noted. If you have access to a generic OBD-II code reader, try it and see if it picks up any DTC (it may, or may not work).
    If the code reader does not work, then you will have to have the car towed to your local Toyota dealer for the Prius tech to retrieve the DTC for you.
  6. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    Ok, I opened up the battery today and see evidence of damage everywhere... My big question is what is the possibility that I screwed up the inverter/converter? I have found another battery for $400 and am going to go with that if there is a good possibility that the inverter is fine... otherwise I think I'll go with a parts car... any experience with what or how the inverter gets trashed?
    thanks
  7. Patrick Wong
    18,210
    6,526
    Which battery are you referring to - the 12V battery or the large traction battery?
    What evidence did you see - is this water damage?
    Regarding the inverter, the main way to determine its electrical condition is to make the car READY (or IG-ON, if it refuses to become READY) and see what fault codes exist. If you are concerned about water damage, you could remove the top of the inverter to see if water entered it.
  8. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    Okay... I have replaced the HV control and got a new Big battery with the battery ecu and all the other stuff... Now all the warning lights are gone and running it in generic obdII on my snap-on scanner I get absolutely no codes--reades -0000 no failure, okay to drive... However, I don't hear the converter running when I turn the ignition on and it doesn't say READY on the instrument cluster... Anyone have any ideas.... I will pay if the solution fixes it!!!!:)
    Thanks,
    Nick
  9. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    Forgot... I opened up the inverter box under the hood.... and looks absolutely magnificent inside... untouched and not a spec of dust anywhere... The inverter radiator is bent but also holds coolant... so don't think overheating is a possibility...
  10. thepolarcrew
    thepolarcrew Senior Member
    4,426
    271
    North Dakota
    Have wondered just how much (hight) water a person could drive slow in without damage. Like when a storm sewer doesn't work etc.
    I know from past experiences (regular cars) that as long as it doesn't get up to the spark plugs they run fine. Have to check rear end for water, but thats about it other than a greas job.
  11. Patrick Wong
    18,210
    6,526
    Hi Nick,
    The inverter will not be running unless the car is READY. Since you can't retrieve codes, it might be time to tow the car to the dealer to see if they can help.
    Good luck.
  12. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    I am being stubborn about towing the car to the dealer.... but I may. I was told that I need to leave the car in the on position for 25 minutes for the HV control to adapt to the car? I was going to try this, I'm having the 12v battery charged right now--anxious to get this thing on the road.... wondering if I've crested the hill or if I'm still at the bottom. I will try to take some pics of everything and post here. As an aside, I fixed a civic hybrid last year and this was an absolute piece of cake compared to this prius. I still have the civic and want to compare the two...
  13. Patrick Wong
    18,210
    6,526
    Well, there may be some interaction between the immobilization ECU and the hybrid vehicle ECU that could be the problem. I suggest that you consult the repair manual and see what is required when a new HV ECU is installed. The Toyota proprietary hand held tester or laptop might be necessary to program one or both ECUs. (I sold my 2001 repair manuals when I sold my 2001.)
    If that doesn't provide any insight and you don't want to visit the dealer, then you'll probably have to look at the wiring diagrams and the diagnostics portion of the repair manual, figure out how the ECUs communicate with each other, use an oscilloscope on the signal lines to see what you can see, etc.
  14. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    SUCCESS!!! Had the little battery charged at the local battery shop overnight... installed the battery and let it sit for 25 minutes with the key in the on position. Shut it off and tried to start it and boom it started!! Yay! However at this point the triangle flashed and it abruptly shut off. Now I was able to pull the code P03191--gas engine not functional or something like that... cleared that code it started again... this time the gas engine started let it run for 10 minutes drove it around the block and seems to be no issues--no check engine lights or anything. Now, just have to finish the bodywork... Thank you for the help--I'll update later...
  15. Patrick Wong
    18,210
    6,526
    Congratulations on your success!
    I suggest that you look at the traction battery state-of-charge gauge on the MFD and see where it is. It normally will be showing half or 3/4 full. If lower than that, it would be a good idea for you to make the car READY for at least 30 minutes or an hour, and allow the traction battery to charge up. This will also charge up the 12V battery.
    DTC P3191 is a general "engine does not start" code. If it reappears, I suggest that you do a tune-up: replace the iridium spark plugs, clean the throttle body interior and throttle plate, replace the engine air filter if dirty, and make sure that the engine oil is 5W-30 viscosity and is not overfilled.
  16. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    i had that issue with the 01 prius i bought that was in a severe crash, i believe the engine does not start code comes on in relation to throttle body not being used in a while or something, once i erased it the car started perfectly fine.
    Does you SRS airbag computer give a fault on the dash?
    i recently purchased a 06 tacoma brand new from a dealer 12,000 less than MSRP that was flooded, it ran fine just the airbag computer is bad
  17. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    yes, I will need a new airbag computer but that is not a biggie as far as I'm concerned... the motherboard has some "gradu" on it....
  18. statultra
    798
    31
    Edison,NJ
    2001 Prius
