Unidentified Prius Warning Light.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by leornere, Jul 31, 2008.
  1. leornere
    leornere New Member
    Camarillo Ca
    Greetings friends,
    I have read several of the threads that refer to different dashboard lights but have been unable to locate one that sounds like the light I have on currently. Feel free to refer me to the appropriate thread. I don't know what its called so my searches have been handicapped.
    This light came on last night. I looked it up in the manual, its there, but it doesn’t say what it means. I've tried to describe it to the dealer but he had no idea what I was talking about and told me to stop driving it and bring it in Saturday.
    My prius has 14300 miles on it; I got it last oct or nov. It’s a 2008.
    Anyone know what this is? I’m worried about going into the dealership with no knowledge and trusting everything they say considering the phone call I had today.
    Thanks for your time.
  2. Patrick Wong
    18,210
    6,513
    I have a 2004 which does not have this light. Is this light warning you that your tire inflation pressure is low?
  3. leornere
    leornere New Member
    Camarillo Ca
    My first call to the dealer said thats what it is, I checked the tire pressure, all is good, and upon further inspection the (!) light is a different light.
    Thanks for your reply!!!
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    This light indicates that at least 1 of your tires has lost 25% of its pressure. Check & inflate all tires to desired pressure then reset the sensor by pressing the button on the borrom left of the dash. Keep an eye on the tires. If there is a slow leak you'll find it soon enough.
  5. leornere
    leornere New Member
    Camarillo Ca
    Thank you for your anwser. I checked my tires and they are all between 32 and 36 PSI. The (!) light is actually a sepparate light on my dashboard.
    Here is a picture of all of the lights as they come on when I turn the car on. I hope you are right! I just want to make sure.
    Thank you so much for your time.
    EDITED TO ADD: You are both very correct. I appologize, what I was interpreting as the low pressure light is actually the break light. Thank you so much for your help, I appologize if I cause any frusteration.
  6. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    It is definitely your tire pressure warning light. It is one of the first things our salesman pointed out when we picked up our 07. :)
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    These lights are, in order:
    Bon Jovi's "Slippery When Wet"
    "Shock Wave Ahead"
    Time to work on your "abs"
    "Very Slippery Condition"
    Engine? Check!
    "Low Tire Pressure"
    "Blowing bubbles while driving is dangerous!"
    "Someone keyed your car"
    "You locked your keys inside"
    As usual, I'm always glad to help. :)
  8. qbee42
    3,079
    It is in the manual.
  9. [H]ackerK
    [H]ackerK Geek
    99
    Great White North
    haha.. LOL! I like this one -> "Blowing bubbles while driving is dangerous!"
  10. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Tony, you forgot the exclamation point in the triangle:
    Woo-boy!
  11. TonyPSchaefer
    14,816
    2,501
    66
    Oh yeah, well that one's "WARNING! Indian Reservation Ahead!"
  12. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    I'd nominate this post for post of the month if I could...
  13. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    And the arrow at the top is the warning "Republican ahead!"
  14. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    It's definitely the tire pressure warning. As someone else posted, check all your tires and once you're happy with their pressure, use the reset procedure that's in the manual (don't remember the procedure off the top of my head). This indicator doesn't necessarily mean that your pressure is set wrong, it just means that there's a 20 or 25% (again, don't remember the exact number) difference between at least one tire and the others.
    If all the tires are set right and you go through the reset procedure then one of your tire sensors could be baroque.
  15. tvmstad
    tvmstad New Member
    KY
    I'm trying to locate info on the "someone keyed your car" light as it is currently blinking in my car after being turned off. I've never noticed it before. Do you know what it means?
  16. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    The blinking key light means that the keyfob is NOT in the slot.
    Yep, that's all it means. You might look it up in the manual...
