Don't Loose your Breaks!
Discussion in 'Fred's House of Pancakes' started by naterprius, Mar 7, 2005.
  1. naterprius
    naterprius Senior Member
    1,843
    Okay, it's pet peeve time. For those of you who failed third grade:
    loose: not rigidly fastened or securely attached
    lose: to miss from one's possession or from a customary or supposed place
    "Loose" is pronounced with a HARD "S" and is NOT a homonym to "lose" which is pronounced with a "Z" sound. The thing that I can't figure out, is do folks pronounce the word "lose" with an "S" sound instead of a "Z" sound? I heard someone call someone a "looser" on a forum once and wondered if he pronounced it like "loo sir" instead of "loo zer"?
    brake: something used to slow down or stop movement
    break: to separate into parts with suddenness or violence
    Here are some examples:
    "You might lose your hubcap if it comes loose from your wheel."
    "I really like the brakes on my Prius, but not the breaks in my windshield!"
    Those of you who are thoroughly confused need to repeat second grade.
    All of you who have failed to properly use these four words on this forum are hereby fined 1 point per incident. Donate points to naterprius as restitution.
    Nate
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    lol... in the middle of the night, when i post.. if i post ( i should never post past 10pm for this reason) i find myself making dumb mistakes like these... hey.. i'll take responsibility for writing as if i'm in the 2nd grade still... my bad. if you can find my post.. i'll give you points :)
  3. chanterelle
    chanterelle Member
    115
    San Dimas, CA
    2020 Prius Prime
    Sure you learn these distinctions in the 2nd or 3rd grade? I don't think I learned these until 4th or 5th grade!! Then again, I passed....
  4. naterprius
    1,843
    Next week:
    Fewer vs. Less
    This one's harder; I hear CNN and commercials screwing this up.
    Here it is:
    The Prius uses less gasoline and produces fewer emissions.
    (If it's plural, it's fewer, otherwise, it's less).
    Try it the other way:
    The Prius uses fewer gasoline and produces less emissions.
    This ought to sound doubly wrong. If "less emissions" sounds fine to you, repeat 6th grade and pay your points penance.
    Here's an easy way to know when to use "fewer": Always try it, and if it souds wrong, replace it with "less."
    Nate
    Man, it's getting late.
    Week 3: How to use a turn signal...
  5. Tideland Prius
    16,596
    lol
    Is there a count thing involved?
    If it's a countable noun, it's "few" otherwise it's "less" or "little"
  6. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Here it is:
    The Prius uses less gasoline and produces fewer emmisions.
    Well it's a two part statement broken with "and" and the fewer <pron, plural in constraint> works, sloppy English, but from CNN, about all you can expect. I wonder how Fox Network would say it?
  7. Tideland Prius
    16,596
    It uses less, pollutes less, goes more? lol ok I'm joking
  8. Frank Hudon
    4,147
    got a laugh from that!
  9. dreichla
    dreichla New Member
    2,230
    Connecticut
    How about "Bring" and "Take" My mother, the English teacher, still yells at me for my incorrect use. I still don't know the rules.
  10. heliotropehead
    heliotropehead New Member
    701
    New Orleans, Louisiana
    Peeve this!
    Than vs. Then
    & the spelling of definitely!
  11. jimofdg
    jimofdg New Member
    533
    DG, IL, US
    "Than vs. then" I can live with. I try to be tolerant.
    "Than vs. that" is creeping into written language like kudzu! Wow, these are two very different words. I also realize speech patterns drop some final letters and it gets hard to keep track. (My advice: pay attention!)
    It's important to realize each word has its own spelling. The previous sentence contains my two big peeves.
    I'm also seeing a lot of "penultimate" used as "more than ultimate" instead of the correct "just one less than the final..."
    That's "more than" and "less than," not... oh, I can't say it...
  12. naterprius
    1,843
    This one is almost accepted into common language for political reasons:
    "Anyone who swims at this beach without a lifeguard does so at their own risk."
    What's wrong? It should be:
    "Anyone who swims at this beach without a lifeguard does so at his own risk."
    That's grammatically correct, but politically incorrect, so it becomes:
    "Anyone who swims at this beach without a lifeguard does so at his or her own risk."
    Which is stylistically incorrect, and still places the his before the her, so is still somewhat politically incorrect, all of which is solved with a slight grammar violation:
    "Anyone who cares this much about my grammar can go ---- themselves."
    :mrgreen:
    Nate
  13. victor
    victor New Member
    414
    Gilching Bavaria Germany, &amp; Drapanos, Crete, G
    <div class='quotetop'>QUOTE(dreichla\";p=\"70558)</div>
    My wife always gets this wrong, but English is not her first language (but damm nearly after 15 years together!!!)
    Easy to remember is "Bring to me" and "Chineese Take away"
  14. KMO
    KMO Senior Member
    2,003
    728
    Finland
    2023 Prius Prime
    Something that always jars for me every time I see it is the bizarre way that Americans always write "I could care less", when they mean the complete opposite. Surreal.
  15. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    :-D
    The first thyme I red that post, eye was confused. Butt than I understanded.
  16. ssmithri
    ssmithri New Member
    Ahh... I hate to bring this up... but...
    Isn't "emmisions" spelled "emissions"?
    How ironic... :D
  17. naterprius
    1,843
    Hmmm, it seems to be spelled right to me...
    Nate
  18. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(ssmithri\";p=\"70682)</div>
    ya I looked at that and then remembered that it was a cut and paste then looked at the bottom of the orgional and it was edited after I cut and plastered it into my message.
  19. Frank Hudon
    4,147
    I guess I should have spell checked the whole message! Nice try Nate.
    I'll grant you this one time reprieve. It was late.
  20. Tideland Prius
    16,596
    ok, definitely is one that I cannot stand. The reason why people don't correct it is because MS Word auto-corrects it for them hence they never see the error.
