Would this horn fit?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Godiva, Aug 5, 2008.
  1. Godiva
    Godiva AmeriKan Citizen
    10,339
    Can anyone tell from the picture whether this horn would fit in the Prius in place of the current (whimpy) horn?
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Godiva,
    Can't tell from the pix how big it is. In the Q&A section the same question is
    unanswered.
    That said, unless the horn/compressor is bigger than a 6-pack it will fit
    between the radiator and bumper. One of the OEM horns mounts near the top
    of the radiator. Room is hard to find here. But there is lots of room at the
    bottom of the radiator. I suspect that you'd have to remove the center section
    of the lower grill to get the horn in and have room to manipulate your
    hands/tools.
    There are a number of "new horn" threads that have pictures of the area at
    top and bottom of the radiator.
    BTW, the second OEM horn is crammed into a really tight spot at the top of the
    radiator on the pax side. The aforesaid pix show the layout.
  3. Joekc
    Joekc Member
    265
    I just replaced my OEM horns with the PIAA horns (available from Amazon.) They fit fine, but they're pretty small. Even so, it was a chore in the heat and humidity, and I came away with bruises on my arms. They sound great, though.
    One thought: How are you going to wire the horn/compressor? The wire going to the OEM horn is very small, probably 22 gauge or smaller (and it has no ground wire), and I doubt it would handle the load. So you might have to do some additional wiring -- maybe not -- I just don't know.
    The dimensions of your proposed horns are: 2-1/2" W x 4-1/2" L x 4-1/2" H. I'm pretty sure these would not fit without relocating at least one. I am almost positive you could not put these in without removing the grill, etc.
    As I said, the horn replacement is a bit more of a chore than it seems due to the tight space. You might want to take the above dimensions and make sort of a mockup to check the fit before you order. And the chromes cost $15 more -- is this really important for hidden horns? Good luck.
  4. Godiva
    10,339
    Okay. It was a thought. The present horn is just so whimpy. But I am not going to go to the trouble of rewiring, etc. If it was a simple swap in/out yes. But looks like not. So I'm abandoning the idea.
  5. Patrick Wong
    18,200
    6,497
    I understand that some Prius owners have installed Camry horns to beef up the sound.
  6. Joekc
    Joekc Member
    265
    Nah, don't give up. The OEM horns DO sound wimpy, so wimpy I think they might be a safety factor because of the high noise levels in other modern cars. You really need to be heard.
    Go to Amazon and search on PIAA horns. These sound like "normal" horns from American cars (2 tones). These will fit without doing any rewiring or re-locating, but like others here I extended the "hot" wire a few inches so as to relieve the strain on the original wire. The ground wire simply goes under the original bolt when you attach it since the OEM horn is grounded through the car frame. It's a slightly annoying task, but certainly nothing beyond the range of someone who's had middle school shop class. Try it! :)
  7. Godiva
    10,339
    Okay. I was looking for something I could use to replace the current horn using existing wiring, etc. I didn't want to have to rewire or do a lot of modifications. This sounds doable.
    I'm looking at getting a 2009 and planning on what I want to do to upgrade it beyond what I did with my current car. Better horn is on the list.
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Small they may be, but the 118 dB of sound this horn puts out is quite a bit louder than the stock Prius horns. I installed them about a month ago. Very Simple install!! they bolt to the same mounting holes and if you carefully massage the wiring, the existing plug will fit. You can also make a simple jumper from parts from AutoZone etc!!! A 6 inch jumper would be more than long enough!!
    They are about $50 for the pair from Amazon.com
    Good Luck
    73 de Pat KK6PD
  9. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I don't think I've ever used my horn in the 10 months I've owned my Prius. Am I doing something wrong? ;)
  10. lwnboy
    lwnboy New Member
    37
    Shell Beach, CA
    Exactly, I've used the horn on my twice in 8 years on my Tacoma and it was to wave at a friend.
  11. Joekc
    Joekc Member
    265
    By "small" I meant physically small. I noted they sound great, which didn't make your edit.
  12. Joekc
    Joekc Member
    265
    Where I live morons wander all over the interstate lanes while talking on their cell phones or fiddling with their cds. I recently saw a woman talking on two cell phones and steering with her elbows. Not kidding.:eek:
    If you don't need a horn, you are truly blessed.
  13. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I think the wimpiness of the Prius horn is a real safety issue. Although the times one may need to use the horn may be infrequent, they're oftentimes emergency or semi-emergency situations where it's important that your horn be heard. I think I've had a couple of instances already when I've honked someone on the highway, and it appeared as if the target didn't hear me.
    Anyways, if the Camry horn is sufficiently loud, it sounds like it might be a good bet because of its low cost (for a used one) and apparent ease of installation:
  14. rayxoxo
    rayxoxo New Member
    39
    Sacramento
    Hi to all;
    I am new to this forum and my Prius is less than 2 weeks old, pkg 6.
    Regarding the horn being poor, I just wanted to say that I just went out and adjusted mine. They now sound good and I was thinking of replacing them but the adjustment made a world of difference. I don't know the level of dBs but it sounds to be around 100 would be my guess and before the adjustment maybe 50dB.
    So please try adjusting it with the screw on each one, to save a buck.
    Cheers
    Ray
    99 Mercedes C230 Kompressor
  15. Godiva
    10,339
    How do you "adjust" them with a screwdriver? What do you unscrew?
  16. rayxoxo
    rayxoxo New Member
    39
    Sacramento
    Hi Godiva;
    Yes, you can adjust them with a screw driver. Not sure if it is a phillips or straight. I used a small straight one about 1/8th wide. On the side you will see a screw that is usually painted (black on mine), I screwed mine in CW and could only get to one of them (the easiest one to reach). But it is just a matter of playing with it. Most horns are adjustable from what I recall. I am older than dirt and when we didn't have the money for new ones we tried to make do.
    I am still a tight wad and was actually considering ordering one from all the post in here and I thought that it was strange that no one mentioned adjustments. So I went out to my car and removed all the needed plastic and saw right away that they had an adjustment screw.
    Like I said I only adjust the one on the drivers side, the other one was a little tight to get to without more work. Being as you probably have the old ones in the garage, try hooking them up to a battery and playing with them. The screw is located on the outer ring, not near the center, if that helps.
    I was a little shy to bring it up, thinking that some one must have mentioned it on one of these threads.
    Good luck,
    Ray
    PS: How do you put your pix up by your name on the top left? TIA
    A retired 2003 R1200CL BMW bike
  17. KK6PD
    4,003
    946
    118
    Thats exactly what I thought you meant. I just wanted to agree and add a loudness reference, 118dB, which is quite loud. Had to toot at somebody yesterday, yeah, they work fine!!
    I usually paraphrase down to just the point. The habit comes from a "Talking Heads" lyric in one of their songs ..."Say something once, Why say it again"!!
    Hope were ok!!
    73 de Pat KK6PD
  18. Godiva
    10,339
    On the top there is a blue line going across with different links listed. The fourth from the left says User CP. This is your control panel. If you click on it you'll get a page with recent posts. On the left is a column that says User Control Panel. The two top links are for your profile and your profile picture. This allows you to upload a picture, create a signature and all that good stuff. Be sure to follow the rules for size.
    I didn't take the horns out of the car. They're still in there. And I'm not sure where they are. Or how to get to the screw you're talking about. I do much better with pictures than with descriptions.
  19. Boo
    5,051
    488
    97
    Flushing, NY
    Maybe this will help (photos and instructions for installing new horns):
    2004 Horn Install
  20. Godiva
    10,339
    Thanks. That shows me where the two horns are and how I can get at them. But where is that adjusting screw? I'm not sure what I'm looking for on the horn.
