Inspect very carfully before purchasing!
Discussion in 'Gen 2 Prius Main Forum' started by Toy08, Aug 7, 2008.
  1. Toy08
    Toy08 New Member
    Southern Calif
    Re: 2008 Prius leans to the left
    Sorry, but that theory doesn’t appear to be correct. People have only suggested that adding weight on the passenger side might correct the 1/2" lean to the left. Putting 200 pounds in the passenger’s seat with no one in the driver’s seat only lowered the difference to 3/8". I even tried added 200 pounds directly over the right rear wheel, which also only decreased the difference to 3/8". And when I added the weight of the driver, it went back to the original 1/2" difference.
    Some have suggested that the lean is being caused by the weight of components in the front of the car (Transaxle, Electric Motors, steering, etc..). If this was true, why is the lean twice as much on the rear of the car? These components are ether in front of, or directly over the front suspension. Even allot of weight at those points, wouldn’t transfer every much weight to the rear of the car. The drivers and front passengers weight are slightly forward of the center of the car. This puts more weight on the front suspension.
    Your theory would also assume that there are no passengers in Japan. I have never been to Japan, but that would be hard to believe.
    Also, why have several people noticed that the lean does not occur in the touring model? I believe it is because the touring model has better, or even maybe even the correct rear struts.
    My point for this post was to:
    1. See how many other Prius owners have the same issue, and maybe didn’t even know about it.
    2. Try to get Toyota to correct the issue.
    The fact is why should we except this without even trying to get Toyota to correct it? And why should anyone at their own expense, have to make modifications to a new car to make it ride level?
    I encourage everyone to do the following if they have the same issue and believe that Toyota should be made to correct it:
    1. Call Toyota customer service and file a complaint.
    2. If they refuse to fix the problem, file a online complaint with consumer affairs and the Better Business Bureau.
    For those of you that try to get the issue corrected, please post your progress. Thank you and good luck.
  2. Toy08
    Toy08 New Member
    Southern Calif
    "Dude", sorry I annodied you. Is this any better?
      File size:
      59.1 KB
      978
  3. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    If it's true that the rear left is worse than the front left, then it *must* mean that the front right is higher than the rear right or the frame is bent. If the frame isn't bent and the front right is higher than the rear right, then handling will be compromised and ABS and VSC might not even work optimally. I'd sure like to know if the reports of the "pedal to the floor" brake failures are on left leaning Prius's. BTW, this will show up in an alignment check as it will effect both camber and castor. One thing you might do is go to an alignment specialist and get your alignment checked. If it's out, a specialist will be able to tell you if it's due to adjustment or a defective suspension component. But it was already like this during the factory alignment, then the alignment might be in spec because it was done with a defective part in place.
  4. Toy08
    Toy08 New Member
    Southern Calif
    Thanks for the info, but could you please clarify you last sentence for me. Will a check of the alignment by a specialist tell me anything, if Toyota has already said that the car is aligned?
  5. Toy08
    Toy08 New Member
    Southern Calif
    If I thought I could recover my money, I would sell the car. The car is only 60 days old and I would have to tell interested buyers that the car leans to keep a clear conscience. I am sure I would loose several thousand dollars on the transaction, which is simply not acceptable to me. I have already made the mistake of not looking the car over closely before buying, I just wanted to let others know they need to be careful if this type of an issue would bother them.
  6. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Do you have an alignment printout done by a Toyota dealer?
  7. Toy08
    Toy08 New Member
    Southern Calif
    No, So I guess I don't really know if they did one. Thanks
  8. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    What a lame response. Maybe....just maybe he wants a Prius and maybe just maybe he might expect that such an obvious and possibly dangerous defect be repaired without having to go through hell.
    I for one appreciate the OPs post because my Prius is coming up in a few weeks and I certainly won't accept one that leans to the left or right. Since I'm getting a Touring model, it probably won't be an issue.
  9. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Since an alignment specialist is also a suspension specialist they should be able to give you a written diagnosis along with a written opinion about the state of your suspension. If you have a third party document that states this is not normal or that you have a defect, it will go a lot further when trying to convince Toyota to fix the problem.
  10. hill
    8,885
    No kidding! We could of saved 4 pages of posts if the 1st thread would have simply said, "will the dealer have it fixed in less than 2 days?" After all, your avatar show your car is nearly new. Under warranty. So you're good to go. Let us know what they do to fix it.
  11. Huntceet
    Huntceet Junior Member
    85
    Chicago area
    2018 Prius
    I'd say there's no chance the dealer is going to correct a half inch ride height variation and I bet Toyota corporate will say it's within tolerances.
    Rod
  12. Toy08
    Toy08 New Member
    Southern Calif
    As I stated in my first post, the dealer will not repair the problem under warranty and Toyota corporate will not do anything about it ether. They said that 1/2" is acceptable and they said the car is only off 1/4â€. All measurements I have taken shown the car to be off by at least 1/2" or more even with the car empty. The difference increases with the driver in the seat. The 1/2" is very noticeable due to the fact the car is so narrow.
  13. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Toy..,
    Most likely the Touring cars tires result in less lean. The Touring tires have a lower section height. The lower section height for the same load rating, means the tires have to have a higher spring constant to take the same load in a shorter compression distance. Consequently, they deflect less due to the extra weight.
  14. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Glad to hear you can determine that without any sort of testing whatsoever.
  15. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Toy..,
    As you indicated in your other thread that the problem was more pronounced in the rear, it might be the rear axle. The Prius rear axle is a combination axle and torsion bar welded sub-assembly. And that makes it cheap, but requires precision welding. I would imagine all the parts are fixtured, and a robot comes in and lays down the welds. But various pieces of metal may react differently to the heat. It may actually be the proper shape, but the torsion may be more on one side than the other.
    There is a free one-time alignment check for the first year of ownership of the Prius. Have them check that, and see if the rear alignment is ok. They might be able to get a good alignment with an out-of-true rear axle, but most likely not.
    You might take it to a shop with a pressure sensors for each wheel. There is a shop here that sets up 911's for road racing, and when they do alignments they give you a weight / tire result. One can then bias tire pressures to get neutral handling. For the 911's they add balast to the desired weight at each corner.
  16. JamesWyatt
    JamesWyatt Señior Member
    348
    Allen, TX
    Mine is 1/8th inch lower on left and isn't noticeable.
    You say yours is off 1/2 inch or more? Why is the dealer claiming 1/4 inch? Geez, just go out with them and a take measurement and clear up that up first, right?
    1/4 inch would be just barely noticeable, but damn, 1/2 inch or more is nuts. I had Land Rover re-calibrate my ride height sensors on my LR3 because it sagged 1/2 inch on the right rear after going off road. Note that the first thing they tried to tell me was that it was more like 1/4 inch. I dragged their sorry asses out there with a tape measure and shut their piehole fast. Then they cried that it was within spec. I said it wasn't within my spec. Eventually they caved in and fixed it. 1/2 inch in an LR3 with oversize A/T tires was horribly noticeable. You need to nail down just how off it is with the dealer.
    Good luck.
    [edit]I went back and looked at your photo. It does look closer to 1/4 to me than to 1/2. To post a photo and have us objectively look at it you need to park the car in your garage where the slab is level. Driveways are not level. Also you need to use a tripod. Put a level on the tripod head/platform and level it before mounting the camera.[/edit]
  17. Toy08
    Toy08 New Member
    Southern Calif
    Believe me, it is at least 1/2" lower. Did you look at my measurement photos "Doc.2"? The driveway is level, but I will redo the photos tomorrow with a level tripod.
  18. JamesWyatt
    348
    Allen, TX
    No, I didn't see them. I usually don't open word documents from untrusted sources (no offense). I took a look and damn, that's pretty bad. The best measurement, though, will be from the ground to the body at the highest point in the center of the wheel well. The places where trim and body panels meet up are not reliable, as the vehicle may not be perfectly symmetrical left to right. The taillight spot was a good measurement.
    Again, though, why is the dealer saying 1/4 inch? Did you physically drag the service manager's nice person out there and show him? Might be worth a try. Ask him if his car was over 1/2 inch off if it would bother him.
  19. JamesWyatt
    348
    Allen, TX
    You know, just some odd thoughts.
    1. Try measuring the height of your tires from concrete to the top of the tread. See if there is any variance. Measure the wheel itself. Switch your rear tires just for shits and giggles.
    2. Measure from the concrete to various suspension parts and check them left to right.
    3. Has it occurred to you that maybe one side is high instead of one being low? Can you go out and check the "normal" height of other Prius?
    4. Try driving rather aggressively down a country road with potholes. See if anything re-seats itself or settles.
    I can't see any reasonable service manager that would not at least swap your shocks, springs and tires in the rear just to see what happens (if the springs are the same left and right). They're only out the labor. I know in some vehicles the springs for left and right are slightly different. Maybe one side on yours got the wrong part... Just thinking out loud here...
  20. richard schumacher
    7,664
    1,046
    United States
    Swap the wheels side to side and see whether the imbalance changes. Start by checking the air pressure in all the tires.
