Extended warranty expires soon!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Weinerneck, Aug 10, 2008.
  1. Weinerneck
    Weinerneck New Member
    78
    Western New York
    My extended warranty will be running out this fall and was wondering what I should be checking out before it expires. I have a 2005 which just turned 3 years old and just shy of 90,000 miles. We have replaced both front hub assemblies and had a little trouble with water getting in the coil pack tubes. Other than that it has been a pleasant 90,000 miles of driving.
    I hate going to dealers for service but was thinking it might be worth having them looking it over before the warranty runs out, any thoughts?
    I did just change the transaxle oil myself (dealer said it needed it) and have done most of the oil changes, filter replacements and little things myself.
    Any concerns, thoughts or dealer recommendations I should heed or be wary of?
  2. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    what caused the front hubs to go out? That would be expensive I bet without coverage. At what miles did they go?
  3. Patrick Wong
    18,204
    6,505
    1. MFD - has it ever acted flaky?
    2. Inspect front struts and rear shocks, looking for oil leaks. If leaks are more than minor, you may be able to get them replaced under warranty (a fairly expensive repair post-warranty)
    3. Air conditioning - does it quickly cool down a hot passenger cabin?
    4. Any problems with the stereo system or CD changer?
    5. Exhaust system - check physical integrity (rust, holes, etc.)
    6. Brake system - if covered under extended warranty, inspect front disk rotors/pads and rear drums/shoes
  4. Weinerneck
    78
    Western New York
    Not sure what made them go, right front went at 73,000 and the left a few thousand later.
    __________________
    Sheepdog- Protecting my flock
    2008 Barcelona Red "Lil Rachel" :flock:
    Avg 56mpg for July08! A Greyhound in the back seat can't hurt!
    Mods:
    Rear Bumper Pad, Hood Deflector, No Reverse Beep, Garmin 660 GPS unit,
    Zaino and Aerospace 303, wheel rings gone, Scan Gauge II, tire inflation at 42/40, PriusChat decal!
    [​IMG] [​IMG]
  5. Weinerneck
    78
    Western New York
    Patrick......... I hesitate to say that the MFD, Stereo and the AC have worked fine. I'll look over the exhaust, struts, shocks and brakes before the big 100,000.
    Thanks
