2006 DVD Upgrade Disk
Discussion in 'Gen 2 Prius Main Forum' started by Harper, Dec 9, 2005.
  1. Harper
    Harper New Member
    60
    Fountain Valley, Ca.
    I was wondering if anyone has heard if we can get our hands on one of these little suckers. I went to my local Toyota dealer and checked out an '06 Prius and was impressed with the look of the upgraded DVD v5.2. The dealer said that the new DVD disk was not available yet and to check back in a few months. Anyone have any luck? BTW, I am in the Orange County, Ca. Area.
  2. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Do you mean 5.1? I don't think 5.2 has been invented yet. :)
    I'm 'reasonably' certain that the 2006 disk will not work on a 2005. If it does, it would probably only add a section of Canada to the data, and not display with the enhanced resolution. You would have to replace several components to upgrade to the 2006 capabilities.
  3. mchinta
    mchinta New Member
    63
    Yes you are right. I am the owner of brand new 2006 and the version of my navigation system is just 5.1 but not 5.2
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I don't follow your reasoning on this. The resolution of the screen doesn't have anything to do with the accuracy of the database. I sincerely doubt that the DVD is tied to a specific output resolution.
    Think about pictures you see on the web. What's your screen resolution? How many colors? How many pixels per inch? I guarantee not everyone on the web has your same setup, but we can all see the same pics, more or less.
    Geographic data isn't pictures, it's mostly numbers with some words now and then, like street names. The Nav computer reads the data and renders an image that the MFD displays. The POI data is more words than numbers, but each entry has location data and type data so the Nav computer can put an icon on the right spot on the map it has rendered. And there isn't any reason Denso would change the basic structure of the database when moving from 2005 to 2006.
    What's your basis for your assertion?
  5. DHonzik
    DHonzik Junior Member
    70
    Oak Creek, Wisconsin
    If someone with a 2006 Prius with Ver 5.1 would like to burn me a copy....I'll tell you if it works with a 2005 Prius. :lol:
  6. mgingold
    mgingold Junior Member
    Santa Clara County, CA
    I, too, am interested in learning more about upgrading my current Navigation DVD (4.2) to the latest DVD (5.1?).
    Question: I own a 2005 GPS Navigation System w/ DVD version 4.2, is there any hardware limitation in upgrading to the latest 5.2V DVD)? I ask because my Toyota Sale Guy (Northern CA) was under the impression (mis-impression?) that I may not be able to upgrade from 4.2v to 5.1v?
    Can someone tell us 4.2v DVD users if our Navigation Systems can be upgraded with the 5.1v DVD? And, what is the main difference between 4.2v and 5.1v? (I would assume more accurate mapping information).
    Thanks!!
    Marshall :rolleyes:
  7. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Someone did post how to make a backup copy. I can't seem to find it. I would like to give it a try for archival purposes.
  8. tag
    tag Senior Member
    2,526
    Chicago
  9. tag
    tag Senior Member
    2,526
    Chicago
    If you don't have something like Nero, you can use DVDDecrypter which you can download here. Pretty simple provided you have a DL DVD writer.
  10. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Seems to me there have been several threads already about the 2006 Nav system using different software than the 2004/5, and a disk from a 2006 will not work in a 2005. However, Toyota is supposedly releasing an updated disk for the 2004/5 soon. That will be just a database update. It won't improve the resolution of the screen.
  11. timtamemanmar
    timtamemanmar New Member
    Alabama
    it is now 2008 is anyone able to tell me how you know if you have lastest update for nav system.
    thanks
  12. hill
    8,897
    Just a quick FYI regarding the upgrade from 4.2 to 5.1:
    You WILL loose your ability to go into the override menu that allow NAV input while in motion. However, you can build your OWN NAV disk, using the old and new together ... by removing the "loading.kwi" file from your new 5.1 disk, and replace it with your 4.2 loading.kwi file ... it WILL still work. You will need the appropriate DVD writing hardware, and double density DVD disks, as the ISO file is over 8 gig's.
    That said, you maps will be more accurate, but not necessarily complete. Our local So. Cal community still doesn't show some communities that are less than 1.4 years old ... but the maps are more accurate than the original 2004 disk.
  13. pkrog
    pkrog New Member
    Central Texas
    My 08 has 7.1 softawre, What is their a newer version?
    What do the dealerd charge to the upgrade?
