REVIEW: Hymotion Battery Plug-In Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TheForce, Aug 12, 2008.
  1. zcat3
    zcat3 New Member
    117
    35
    SF Bay Area
    That's the Hybrids Plus conversion. That product actually seems to be a nicer product than the Hymotion product as it completely integrates with the car, allows regenerative braking to the Lithium pack, doesn't require removal of the spare tire, and doesn't change the display functions in any way. Unfortunately it is way more expensive.
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I just wanted to bump this thread up one more time before I post the results you all are whining about. :rolleyes:
    My commute details will be posted with the next update which should be in the next 24 hours.
    I have completed the Highway test and all EV mode test and the results were surprising. Stay tuned to find out the results. :D :p
  3. problemchild
    problemchild New Member
    429
    37
    Yawn.......
  4. sandman
    sandman Member
    277
    32
    kentucky
    I for one cannot wait..Thank you for sharing all this with us be sure and include any pictures or videos the more the better...:)
  5. Sp33dy_gr33n
    Sp33dy_gr33n New Member
    31
    Midwest
    Force - this better be one super-detailed report. All I read is how you will update soon... I'll believe it when I see it.....
  6. chinalfr2
    chinalfr2 Member
    234
    New England
    Looking forward to your update. I hope your data can convinced me to get this addon. ;)
  7. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    You Tease!
  8. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    The most anticipated information on PriusChat, can't wait to read the results. I'm sure the results will convince some and reject others. I will be back to see the early results...
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I updated my first post. Please let me know if anything is missing, needs corrected, or if you have any questions. This is not the final write up as I still have to finish my tank which will take a while.
  10. jeffreykb
    jeffreykb Junior Member
    85
    TX
    I wonder if Sammy Hagar has a Hymotion Prius yet. :) The City all EV mode test had interesting results. So you had to stop a few times to keep the stock SOC for dropping too low? It sounds like the Hymotion pack was not capable of supplying enough power for sustained EV mode.
  11. jeffreykb
    85
    TX
    I wonder if it would be possible to get a comparison of the two conversions: Hymotion and Hybrid Plus. Price, pack capacity, driving tests with numbers, etc. It would be cool if a "race" could arranged together.
    * Race may be the wrong word here...more like tests.
  12. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    This is a very nice review. It appears the pack is working beyond expectations when using good driving skills. Keep up the good work, I've really enjoyed the reviews. Maybe you will finish this tank by October!
    ---Kent
  13. JoesMorgue
    JoesMorgue Junior Member
    61
    Outside Detroit, MI
    I've heard the "transmission" only pumps the fluids when the ICE is running, and that scares me! Any comments?
    Would this installation conflict with my extended warrenty?
  14. JoesMorgue
    61
    Outside Detroit, MI
  15. douglas001001
    douglas001001 smug doug
    222
    Chicago
    Those are results I'd hoped to see! Nice work, thanks for the write up.
    In your highway test when you said you were holding 150+ with ice on, what rpm/tps/ign was the car at? Have you tried using shm at around 50 mph?
    Also, it would be neat to see how it performs if you do all accelerating with the ice and use the pack to hold speed (could you get 100mpg for 100 miles out of it at faster speeds than a stock prius?). You mentioned 20a to hold 32 mph, have you tried holding 40 mph in stealth?
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    so with traction battery assist to a small degree you are getting 6 miles per kwh...very nice. in my much lighter Zenn, i am getting 4½ miles/kwh but i will say that i drive full throttle nearly 100% of the time (heck it only goes a max of 38 mph!!)
    this is tempting since my RT commute is 14 miles...with frequent side trips to the gym making my distance bet charges to 18 miles.... i could goes months bet fillups...very tempting. i am no where near getting ready to sell my Pri... but am looking for another EV option...if Zenn comes thru with their CityZenn as advertised, that is what i will be getting, but if not, i may just get another Pri and convert
  17. Zythryn
    Zythryn Senior Member
    6,411
    4,411
    Thanks Jay.
    I (and I am sure many others) appreciate the great level of detail.
    Fantastic to see, can't wait to get mine too:)
  18. ualdriver
    ualdriver Member
    358
    66
    Midwest US
    Thanks for taking the time to do the write ups. Please post so that we know when you update your first post!
    Is there anything "bad" that could happen for running the car for 10's of miles only in EV mode?
  19. zcat3
    zcat3 New Member
    117
    35
    SF Bay Area
    Thanks for the info. Obviously you are an accomplished hypermiler, but still, those results are impressive. I fear if I drove like that on my commute I would be killed.
    Just how slowly do you have to accelerate to stay in all EV mode? When I try to accelerate in all EV mode from a stop light here in San Francisco I usually run the risk of being run over by a muni bus.
  20. Flying White Dutchman
    4,376
    313
    i see you have posted some video's now in your firts post
    nice
