GPS error message
Discussion in 'Gen 2 Prius Main Forum' started by VergerBill, Aug 21, 2008.
  1. VergerBill
    VergerBill New Member
    Nashville TN
    We have a 2006 Prius Package 8. Installed Coastal Tech LockPick shorlty after purchase 2 years ago. - Last night came home, GPS working OK. This morning, turned the car on and on the map screen this error: "A Program cannot be read. Please consult to a dealer. (then numerous Japanese characters)" - All other screens: Info - Consumption - Economy - Telephone - Audio - Radio - are working OK. - I have taken the Map CD out and back in, checked all connections under the seat - Any ideas, thoughts, suggestions please. - Bill, Nashville TN
  2. qbee42
    3,077
    This sounds like a failure to read the map DVD. You mentioned removing the DVD. Did the disk look clean?
    My first guess is that the DVD reader has packed it in.
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    yeah i beleive the prius repair manual states to clean the disk and or replace the disc
    and if that does not work, replace the entire drive
  4. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
  5. dianejcarter
    dianejcarter New Member
    Saratoga, CA
    a program cannot be read please consult to the dealer
    I received this message after a jump start to my auxilliary battery.
    Now the navigation won't work and I have lost several other ikons.
    I removed the DVD and reinserted as recommended by another user but it didn't work.
    Any other suggestions? I suspect it is out of warranty and I have heard they are very expensive.
  6. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    I would also try unhooking the negative terminal on the 12 volt battery, waiting 5-10 minutes and hooking it back up. You will lose all your radio presents, clock time and the auto widow will need to be reset, but this does force the DVD to reboot from scratch. Worth a try...
