$12,000... Rear-end-Collision-damage. Rerair vs. replace rear side rail assemblies??!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dbgfreeusa, Aug 22, 2008.
  1. dbgfreeusa
    dbgfreeusa New Member
    $12,000... Rear-end-Collision-damage. Repair vs. replace rear side rail assemblies??!
    We've received 2 damage estimates ranging between $9K and $12K for rear-end damage sustained from a Semi rear-ending us at a stoplight. One of the differences betwen the two was regarding the left and right side rail assemblies being replaced vs. being repaired.
    My gut feeling is that if the rails bent the way that they were designed to bend during the collision, trying to straighten them back out and expect them to perform properly in the future is asking too much.
    Our Toyota Shop has a brand new Collision Center that does have a Frame Rack.
    Any suggestions to insure our car is put back together as well as possible will be appreciated.
    My photos are double the allowable size. I'll have to figure out how to make them smaller or send links to them (any help would be appreciated).
    Thanks,
    DAVID
  2. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    The simple answer is if they are crumpled, torn, or cracked they should be replaced. That is what is stated in the Toyota Collision Repair manual. Here is a shot of my '08 that I am repairing. I replaced the damaged section of the passenger side frame rail and I straightened the drivers side rail.
  3. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Yep, they should be replaced to get the car back to its prior condition. This is a matter of safety and likely of alignment/drivability/handling as well.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    They should ABSOLUTELY be REPLACED!!! They form part of the built in CRUMPLE ZONE that is built in to your Prius to save your life. Go go back out on the road with it bent as is, well would 1 - Alignment issues. 2 - What if you get into another accident. The Crumple Zone, already being compromised, would probably fail prematurely, possibly causing you injury!!!
    If the truckers insurance balks, SUE THE CRAP out of them. They have the responsibility to make your car 100% right. What state / city do you live in??
    Here in CA when there is an accident you have FINAL say where your car is repaired! That way you do not get shoved into a cheap insurance friendly facility! I happen to have had my several wrecks, oops my bad, at a shop that is so clean and professional you could eat off the floors. Their work is impeccable!!!
    Hope things work out for you! oww!!!
    73 de Pat KK6PD
  5. dbgfreeusa
    I live in Atlanta, Georgia. I was hoping to come up with 'hard to dispute' info in writing, verifying the need to replace the rails. The Body Shop's/Insurance Company's attitude at this time is to see if the rails can be straightened first, and if that deosn't work, then replace them.
    I heartily agree that if the rails are bent or collapsed, even a little, metal-fatigue alone will not allow them to react as designed, regardless of how straight or cosmetically perfect the frame rack is able to force them to be.
    As I started writing above, I'm hoping to come up with highly respected, indisputable info in writing that backs up my feelings. I do not think that I will have a problem with the insurance company going along with me as long as I am able to come up with what I am looking for. Any ideas or sources for that info would be greatly appreciated.
    Any tips of how I can make my Adobe or Picasa photos that are twice as big as this forum's limit, miniaturized so that they can be posted and/or how I can attach a link to my photos would be appreciated as well
    Thanks,
    DAVID
  6. Celtic Blue
    2,224
    139
    Midwest
    David,
    The Toyota Collision Repair manual should be the "Bible" for this shouldn't it? Jelloslug says that it says to replace them if they are "crumpled, torn, or cracked." I think you should check with that Toyota Collision center, get the relevant page from the manual and ask for Toyota's evaluation. If they say it should be replaced under the criteria, then the insurance company is screwed. (My guess is that the dealer shop wouldn't pass up the business.) The only wiggle room I see is if "bent" is specifically excluded and Toyota/etc. agree that they are just bent. If they are just bent a little with no crumples then you might be stuck.
  7. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    I also say replace them (but I'm not in anyway qualified to have anything but a gut reaction opinion).
    I've fought with insurance companies about replace/repair decisions on safety equipment in the past. If I was the policy holder, I lost. If my car was damaged by someone else I won.
    Good luck with this and let us know what happens. Especially if you can get Toyota to make an official declaration. I'd like to be able to cite it if needed!
  8. Bobwho
    Bobwho New Member
    68
    Chicago area
    Replace or the value of your car will be much less if you only straighten them,
    I know you are not going to sell your car.
  9. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    my advice
    12,500 is almost 50 % of the value of the car, and i thought some insurance companies will automatically total it out when the damage is this high. if your insurance company will not total this out, you could try contacting the semi's insurance company, and if that does not work to your satisfaction, i would consider suing the other driver for the entire replacement value of the car.
  10. Celtic Blue
    2,224
    139
    Midwest
    It's been awhile but from what I recall totalling in Texas was 2/3 or 3/4 of its value. I had to fight for a month to get a car repaired rather than totalled some years ago. It wasn't that badly damaged and was in far better shape than what I could get comparable. I think the problem was that they could get so much in salvage out of it that they were trying to lowball me on the value and pay the totalling to pocket the difference in salvage. I wouldn't play the game as I didn't want to get some crappy smoker's car that had didn't have an immaculate interior, wasn't mechanically rock solid, had cheap unsafe tires, and lacked the aftermarket suspension/performance upgrades I had done. By the time I was through tallying what it would take for me to accept their offer (including new registration fees, new parts, etc. and the closest comparables I could find) the person who was handling the claim had been terminated and we got the car repaired.
  11. dbgfreeusa
    Does anyone happen to know what direction I may go to locate the proper Corporate Toyota Personnel who would be able to make a Formal Declaration and/or would be available to personally see and feel the rear side rails in question? I happen to be in the Atlanta Area.
    Thanks,
    DAVID
  12. Patrick Wong
    18,210
    6,514
    Hi David,
    Have you tried to access the Prius Collision Manual via techinfo.toyota.com ?
    If you invest $10 in that subscription website, maybe you can find the guidance it provides regarding your collision damage, and download/print the relevant pages if that helps your case.
    Good luck.
  13. dbgfreeusa
    Thanks fo the tip, Patrick.
    ---DAVID
  14. jelloslug
    813
    55
    Greenville, SC
    I sent you a PM about the info a while back.
  15. dbgfreeusa
    Any thoughts on whether I should pay for a Diminished Value Service. My insurance company already sent me a chck for $1500.00, which I feel is low. I'm not going to do anything with the check for the time being. I looked at an ad on this site for Collision Claim Associates, but have no idea what the best route to take at this time would be.
    Thanks,
    David
  16. tanteb & rgrpick
    tanteb & rgrpick New Member
    95
    David, I just got off the phone with my insurance person re: a much smaller issue, and below is the terminology it was suggested I use, only applied to your situation when speaking with the semi's adjustor. Btw, I am in GA also.
    Repairing bent rails that serve as part of the safety structure of your car would not meet (Insurance) "Industry Standards which require that you be made whole or indemnified by the use of at least OEM/aftermarket parts rather than refurbished(ing) /rebuilt parts. If OEM/aftermarket parts aren't available than you want new Toyota parts. Using Refurbished//rebuilt parts do not make you whole or indemnify you." (mean basically the same thing, I'd just use indemnify)
    Hopefully your "awareness of law" ;) will send them scurrying, but if the semi's insurance person says, "but putting new parts on will make it better than new." Your response, here in Georgia, might well be, "I suspect, if I have to call him, John Oxindine, the Insurance Commisioner, would rather error on the side of the innocent public, rather than on the side of the offender's carrier, and while waiting for his determination I will also have loss of use considerations to be met, on top of the rental car, after all, you're going to put me in a mid size car that gets what? 20 mpg? costing me more than twice what I pay in gas on my 45 mpg car ." Don't talk further about this, your insurance folks ought to handle it if it gets to this point.
    I had never heard of loss of use till my broker mentioned it, and I am frankly surprised that all you received was 1500 for diminution of value, and that you have already received it. Perhaps it is just an initial payment. My person said it would happen later, and my person will also, as a value added service, handle calls up the insurance ladder if I am not dealt with quickly and appropriately, without it going on my record.
    Btw, any other info on diminution of value would be appreciated.
    Hope this made sense, I'm still seething that they thought they could get away with a "rebuilt" bumper on my car, when their idiot hit me!
    Well, none of the above worked for me, lol, so I'm going to let my company do their thing. So much for wanting to take control.
  17. bibs
    bibs Junior Member
    cape cod
    go for the new!!!
    I was rear ended at speed limit on cape, my company wanted to fix up just about everything, his insurance adjuster said to go for the new.
    guess which I did
  18. NeoPrius
    NeoPrius Member
    182
    33
    Maryland USA
    (deleted)
