Dumb question
Discussion in 'Gen 2 Prius Main Forum' started by olends, Mar 10, 2005.
  1. olends
    olends New Member
    214
    Clifton Park, NY (near Albany)
    when starting the car how long is one required to keep their foot upon the brake?
  2. jeepien
    jeepien Member
    165
    New Jersey
    Just until you hear the "ta-dah" beep, and the READY light comes on. Maybe even less.
    I think that as long as your foot was on the brake when you pushed the Power button, you're all set.
    Of course then you're going to have to put your foot back on the brake when you want to get it out of Park.
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Tah-Dahh? I usually hear 'click click' as the relays in the back go through their sequence.
    Why, did you get a hang-on-Ig-On condition?
  4. KCPrius
    KCPrius Member
    133
    Overland Park, KS
    I hear the clicks, then two beeps when it's in ready mode. After my incident of not going into gear (hasn't happened again), I'm pretty careful to wait until I hear those two beeps before putting it in gear.
  5. jeepien
    jeepien Member
    165
    New Jersey
    When the READY light comes on, there is a double beep, with the second one noticeably longer than the first. From the first time I heard it, I always associated it with the rhythm of "ta dah".
    Of course, if your seat belt's not on yet, you are treated to all sorts of annoyed beeps that would make it hard to pick one sound apart from another.
  6. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    One day I realized that I was keeping my foot squarely on the brake for a very long time. No real reason, the car's not going anywhere.
    My answer is that after you press (Power) a couple times, you should be able to remove your foot from the brake. If you remove it too soon, you might go into ACC mode. In which case, just give it a few seconds, re-apply your foot, and hit the (Power) button one more time.
    After that, just make sure you apply the brake before attempting to shift.
  7. DanMan32
    3,799
    27
    Tampa Bay, FL
    I only get one beep when I go into Ready.
