Proof of Seat height adjuster in 2010
Discussion in 'Gen 3 Prius Main Forum' started by ScarGo, Aug 25, 2008.
  1. ScarGo
    ScarGo Common Sense Conservative
    Perrysburg, Ohio
    OK look at the height differences between the two seats... Yes I know the drivers seat is pulled slightly forward.
  2. dogfriend
    7,512
    1,190
    Carmichael, CA
    Your standard of proof is much, much lower than my standard of proof.
    I think this photo only "proves":
    This engineering "mule" appears to have different seats than the current Prius.
    It does not prove:
    That this is the final configuration for the production car.
    That this will be the final configuration for the NA market (i.e. EU Prius gets an adjustable seat now, but NA Prius does not). Its a marketing issue, not an engineering issue.
  3. Tripod137
    Tripod137 New Member
    145
    Long Island
    For some reason, I can't see the picture, but does it show the seat at 2 diff heights? or just a comparison between the new Prius and the old? Maybe they have just chosen a new seat night?
  4. qbee42
    3,079
    That photo doesn't even prove that it is a Prius. I'll take it as an interesting comment, but nothing more.
  5. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    old 2002 Corolla did not have seat height adjustor and telescopic steering wheel for US Market, new 2009 Corolla has them both...
    I dont think it is odd to expect the both from Prius as well.
  6. Tchou
    Tchou Member
    161
    My 2007 Prius has driver seat height adjuster.... as all prius in Europe...
    This picture is taken from a European supposed 2010 prius (belgian licence plate). That doesn't mean that even if the european 2010 prius has Height adjustable seats that US prius will also have it.
  7. YoDaddyAlex
    YoDaddyAlex Member
    271
    the seats look nice but that redesigned dash layout, middle section, etc. looks awful!
  8. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Hasn't anyone here ordered a European seat bottom and switched it out yet? Assuming that it mates the the seat back and all you have to do is swap the upholstery?
  9. dogfriend
    7,512
    1,190
    Carmichael, CA
    The current seat design would require that you buy the complete seat frame (bottom and seat back) because it is staked and welded together. I priced the seat frame assembly once and for that kind of money (>$1900 USD for the US version IIRC) you would be better off buying a Recaro.
  10. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Is that the complete seat or just the frame? On my SC400 (also toyota), you can buy the entire seat for about $3000, or you can buy just the seat from for about $800 in which case you'd transfer the padding and leather over.
    Did you price out the minimum options just to get the seat frame only?
  11. dogfriend
    7,512
    1,190
    Carmichael, CA
    It was just for the frame, no padding or cover. The price for the cover was similarly exorbitant. Plus, you would need to order from the EU, Japan or AU and pay shipping from there to here.
  12. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Wow! That's amazing. The Prius seat frame is more than the Lexus seat frame. At the time, in 1995, the SC400 was the flagship car. Our window sticker says $58,000. That's probably $70,000 in 2008 dollars. And you're saying the Prius seat frame costs more? How many quotes did you get? I buy my Lexus parts mail order because some dealers add 2 to 300 % mark ups. I assume you got at least 3 or 4 quotes?
  13. dogfriend
    7,512
    1,190
    Carmichael, CA
    I got the quote from one of the discount OEM parts sources on the web. I tried a couple this afternoon, but I get N/A for the price now.
    Going back to your original question: I have not heard of anyone buying the seat part(s) from the EU, Japan or Australia to convert their non-adjustable seat into a height adjustable seat. You would need the complete seat frame and based on the figure that I saw for a replacement seat frame, I don't think it would be economically feasible.
  14. Tideland Prius
    16,563
    Don't forget the Prius will also have wires and such for the side airbags.
  15. patsparks
    10,664
    567
    Adelaide South Australia
    If you are in North America there is no point ordering from Japan or Australia unless you want a height adjustable passenger seat.
    If I wasn't happy with my seat I'd get a Recaro.
  16. spwolf
    3,156
    440
    Eastern Europe
    that seat is not built to be replaced completly, hence the price...
