Whining noise from driver's side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ron69424, Aug 31, 2008.
  1. ron69424
    ron69424 New Member
    75
    The last two days my 2004 has been making a whining or humming noise from the front driver's side during decelerating and braking. There also seems to be a loss of mpg and power. Also the battery does not seem to be as fully charged as normal; only about half the bars are appearing. The noise is louder when applying the brake.
    Does any of our Prius guru's know what the problem might be?
    Thanks, Ron
  2. Patrick Wong
    18,210
    6,511
    Hi Ron,
    How many miles on the odometer?
    Any warning lights on?
    I suppose you are aware of the normal inverter whine caused during regen braking; so if this is a new noise, maybe your transaxle is about to fail.
  3. ron69424
    ron69424 New Member
    75
    Thanks for your reply Patrick:
    The car has 91,500 miles. No lights on at this time. When I changed the transaxle fluid about 1000 miles ago there was nothing unusual about the old fliud or flakes or particles. The noise is simular to the regen braking inverter noise only a lot louder.
    If the inverter is starting to give up I should get some lights. Should I keep driving until I get some lights or the problem becomes more certain?
    Thanks for your input.
    Ron
  4. Patrick Wong
    18,210
    6,511
    Hi Ron,
    When you added new fluid, did you use 4 quarts of Toyota ATF WS?
    Do you see any transaxle fluid leaks, especially at the drain and fill plugs?
    Is the inverter/transaxle coolant reservoir at the full mark?
    If you don't see any obvious problems, then I suppose you can continue to drive the car until something happens. The inverter is covered under the 100K mile hybrid system warranty but the transaxle is out of warranty, unless you have extended warranty coverage.
  5. ron69424
    ron69424 New Member
    75
    Hi Patrick:
    I refilled the transaxle with slightly less than 4 qts of WS until the level was just slightly below the fill hole. The inverter coolant is to the fill mark and the coolant pump is working normally with no unusual noise. There have been no leaks anywhere.
    If it is the inverter I'm glad its acting up now while it is still under warranty. I do hope it is not the transaxle:eek:
    Thanks. Ron
  6. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    I solve the problem of whining noises from the driver's side by not allowing anyone else to drive my car :p
  7. ron69424
    ron69424 New Member
    75
    My wife and kids think they know where the whining is coming from and it's not mechanical.:tape:
  8. bwilson4web
    16,250
    As an experiment, could you find a gentle downgrade, free from traffic, and try braking both in "N" and "D" and let us know if it makes a change to the noise?
    If it has an electrical element, braking in "N" will mute the noise. If it is mechanical, it will happen with both "N" and "D".
    Is the frequency proportional to the speed of the vehicle regardless of load (aka., up hill, level, or downgrade?) This helps us separate from the engine power path from the direct drive path.
    Did you keep a sample of the transaxle oil from the last change? If the problem gets worse, I will be very interested in getting a sample for testing.
    To eliminate wheel bearings and possibly tires, does it change with a left or right hand turn? Road surface effects?
    One telling test would be if Toyota could run your car down the highway and read out the MG1 and MG2 temperature. If they are fairly close together, no problem.
    Just a suggestion but perhaps you might upgrade your profile with location and vehicle age. ... Just to make it easier to follow your progress.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Good test Bob.
    As a side note have you ever run out of gas & ran on electric until you found some gas in the life of this car?
    Or has this car seen alot of high speed high way miles? Just trying to get a baseline of symptomatology as it appears you may have one of the rare CVT failures given all the symptoms especially low power poor mpg's.
    If it is the CVT you will soon throw a Hi Volt DTC.
    But the inverter may be overheating/failing.
    Check real good for inverter coolant leak too. Coolant at correct level in the container next to the inverter? Ever had to add coolant there? Does it look and smell good and has it ever been changed?
    You waited a long time to maintain the CVT. When you finally serviced the CVT was it because it started humming?
    While engine is running is the inverter coolant circulating in the container? If coolant low look real closely around the sides and back of the inverter best you can for any red colored rust or coolant that may have leaked out of the inverter.
    Good luck & Keep us posted please.
  10. ron69424
    ron69424 New Member
    75
    Bob:
    I bought the car with 60,000 miles on it so I don't know if it was run out of gas.
    I did have an inverter pump failure and drove some miles in that condition until I replaced the pump and fluid.
    The car ran normally after that for 1,000 miles.
    I did your test down hill braking in D and N. The noise was very muted in N. There is no change in noise when turning or different road surfaces. The noise is not noticeable when accelerating or driving up hill.
    I did not save a sample of the transaxle oil but will next time if it is not too late.
    Thanks for the input. Ron
  11. ron69424
    ron69424 New Member
    75
    Ed:
    The car has had a good mix of highway and local driving since I have owned it. All the fluids are topped off with no leakage anywhere.
    I changed the CVT fluid because of what I had read here not because of any noise or problems. According to Toyota I changed it early.
    I have a scan gauge on order. Will this tell me the MG1 and MG2 temps?
    Thanks, Ron
  12. bwilson4web
    16,250
    The coolant also passes through a channel in the transaxle to pull some heat. However, the Dept. of Energy studies indicate this is a minor effect. But if the inverter coolant change left behind an air bubble, there could be local heating.
    Owch! The muted noise in "N" is not good because the inverter would not be involved. You called it whine, does the frequency vary with the speed?
    Let's see how things develop and hopefully I am wrong.
    We have seen a couple of NHW11 transaxle failure where a winding shorted. What happens is the permanent magnet in the motor becomes an unregulated generator and more and more heat is generated in the winding. Over time, this gets progressively worse and eventually fails the transaxle. The time varies but we've seen reports suggesting it can take 1-2 months.
    If you can get your local Toyota service shop to do the following test, you'll get an early confirmation of the failure:
    • run the car at highway speeds, ~55-60 mph, for 15 minutes -- to let the transaxle reach a stead-state temperature
    • use the Toyota scanner to read out MG1 and MG2 temperatures
    If the temperature difference is 30C or greater, the hot one is in trouble, serious trouble. Any temperature over 100C is pretty grim. This is only a HYPOTHESIS based upon the "N" test results. You really need the temperature reading to tell for sure.
    To extend the life, try to keep the transaxle as cool as possible: (1) slow speeds, and (2) short trips. But this is a progressive problem. If you want to accelerate the failure, try a trip of a couple of hours at 75 mph.
    Your repair options are expensive and d*mn expensive. We've seen one report of a salvage transaxle but it didn't turn out well. Rebuilding a transaxle is not trivial (aka., requires special tools and patience.) The Toyota transaxle replacement is likely to be pretty stiff. However, we know these transaxles are very robust and normally last a long time.
    I am not trying to candy-coat or scare you, just share what the symptoms suggest.
  13. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Hmm..recent inverter pump replacement has me suspicious in a good way...You could very well have an inverter failure going on. Put the car in park. Make note of exact charge level/bar count in hybrid battery on mfd..how many blue bars..Open the hood and listen to the inverter. Is it screaming or otherwise complaining or really really hot. Coolant flowing in the red inverter coolant tank? Let the car sit there running with the air on full blast for about 30 minutes. Check the battery/bar count level. Is it charging up the hybrid battery pack ok?
    BTW, the Scan gauge does not show MG temps. It only shows engine temp. The thing that checks MG temps is the Toyota toughbook diagnostic software gimmick Bob's talking about.
    But given all the symptoms you will soon throw a DTC. Let us know what it is. The Scan gauge reads DTC's on the Prius and other OBDII cars also.
  14. ron69424
    ron69424 New Member
    75
    Thanks for the advice guys.
    The noise does change frquency, pitch, and volume with speed. I think I will wait until I get the scan gauge before I do more testing.
    If the transaxle is bad I think I will try to change it out myself with a salvage unit. If it is the inverter it is still under warranty and Toyota will replace it.
    I will keep you posted of any codes or changes. Thanks, Ron
  15. gac53
    gac53 Junior Member
    Minnetonka, MN
    2002 Prius
    HelloI'm new to the "chat". I have a very similar whine from my 174,000 mile 2002.
    I will try the D and N test and see what happens.
    Just got new wheels and tires and was suspecting something there but it sounds electrical/regen to me.
    Mine whine increases with a left turn.
    Greg
  16. other car gets 10mpg
    Los Angeles
    Is this different than the light grinding noise I hear on my new 09? It kind os sounds like a tiny little air compressor charging up. It lasts about 3 seconds every few minutes.
  17. qbee42
    3,079
    Yes, that's different. What you are hearing is the brake pressure accumulator pump. The Prius can't use normal vacuum assisted power brakes, so it uses an electrical boost pump instead.
  18. other car gets 10mpg
    Los Angeles
    Thanks for the info.
  19. gac53
    gac53 Junior Member
    Minnetonka, MN
    2002 Prius
    What do you mean by "throw a DTC"? I think I missed something there.
    Greg
  20. qbee42
    3,079
    He means a trouble code from the controller. Any major problem will cause one or more controllers to log an error code, which can be retrieved with a diagnostic tool.
